since yesterday, I get errors with the zigate plugin version 4.11.017, firmware 031a (tried to upgrade the firmware before, but I didn't succeed)
AFAIK, all zigbee stuff is available, works fine, detects open/close, ...
Log file attached (added .txt for the upload)
How can I find out what sensor is behaving badly?
Any help greatly appreciated!
Thanks.
Kind regards,
Geert
errors with zigate
geertvercamer
- Target OS: -
errors with zigate
- errors.json.txt
- (37.42 KiB) Downloaded 55 times
Re: errors with zigate
SO if I'm not mistaken you are now on firmware 31c
Looks like the ShortId of the device causing this timeout is: f3f2
You can eventually go to the Web UI
--> Management
---> Device Management and search for f3f2
--> Management
geertvercamer
- Target OS: -
that's right, pipiche, 31c. (Must be clumsy me, but I never managed to update)
The device has been installed over a month ago, it is a light switch: Zigate - lumi.switch.b1lacn02_Voltage-00158d0005c14e51-01 Bathroom Lights
It does work, though.
I made a script that when the bathroom door opens, the lights toggle (on <-> off), working ok although it takes the switch sometimes 3 seconds or more to react. Domoticz receives the door sensor info almost instantly and sends the command straight away, but it takes a while before the switch reacts.
Besides the delay, any idea on what I can try to solve the problem?
I also see this a lot in the log: Proxy: Error, reconnecting (Connection timed out)
I don't think this has anything to do with ZiGate, does it?
