Re: Move Zigate from Raspbian to windows
Posted: Wednesday 09 June 2021 13:46
by Rfpower666
2021-06-09 13:44:21.878 Sunrise: 04:23:00 SunSet: 22:28:00
2021-06-09 13:44:21.878 Day length: 18:05:00 Sun at south: 13:26:00
2021-06-09 13:44:21.878 Civil twilight start: 03:09:00 Civil twilight end: 23:43:00
2021-06-09 13:44:21.878 There is no nautical twilight in the space of 24 hours
2021-06-09 13:44:21.878 There is no astronomical twilight in the space of 24 hours
2021-06-09 13:44:21.916 Active notification Subsystems: email, fcm (2/13)
2021-06-09 13:44:21.926 Starting shared server on: :::9980
2021-06-09 13:44:21.861 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-09 13:44:21.861 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-09 13:44:21.861 Status: Startup Path: C:\Domoticz\
2021-06-09 13:44:21.914 Status: PluginSystem: Started, Python version '3.8.6'.
2021-06-09 13:44:21.917 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-09 13:44:21.924 Status: WebServer(SSL) started on address: :: with port 443
2021-06-09 13:44:21.926 Status: TCPServer: shared server started...
2021-06-09 13:44:21.926 Status: RxQueue: queue worker started...
2021-06-09 13:44:22.086 Status: Incoming connection from: 127.0.0.1
2021-06-09 13:44:23.969 ZG hardware started.
2021-06-09 13:44:23.970 Status: ZG: (ZG) Entering work loop.
2021-06-09 13:44:23.970 Status: ZG: (ZG) Started.
2021-06-09 13:44:23.971 Status: EventSystem: reset all events...
2021-06-09 13:44:23.971 Status: NotificationSystem: thread started...
2021-06-09 13:44:23.972 Status: EventSystem: reset all device statuses...
2021-06-09 13:44:24.029 Status: Python EventSystem: Initializing event module.
2021-06-09 13:44:24.029 Status: EventSystem: Started
2021-06-09 13:44:24.029 Status: EventSystem: Queue thread started...
2021-06-09 13:44:24.439 Status: PluginSystem: 1 plugins started.
2021-06-09 13:44:24.484 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-09 13:44:24.513 Status: Zstick: Starting...
2021-06-09 13:44:24.514 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-09 13:44:25.951 Status: ZG: (ZG) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-09 13:44:25.979 Status: ZG: (ZG) enablegroupmanagement set to 1
2021-06-09 13:44:25.979 Status: ZG: (ZG) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-09 13:44:25.979 Status: ZG: (ZG) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-09 13:44:25.979 Status: ZG: (ZG) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-09 13:44:25.979 Status: ZG: (ZG) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-09 13:44:26.844 Zstick: Value_Added: Node: 28 (0x1c), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.844 Zstick: Value_Added: Node: 28 (0x1c), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.845 Zstick: Value_Added: Node: 28 (0x1c), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.845 Zstick: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.846 Zstick: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1, Index: 1
2021-06-09 13:44:26.846 Zstick: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.847 Zstick: Value_Added: Node: 30 (0x1e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2021-06-09 13:44:26.848 Zstick: Value_Added: Node: 32 (0x20), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2021-06-09 13:44:26.850 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.851 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.851 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.851 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.852 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.852 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.852 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.855 Zstick: Value_Added: Node: 35 (0x23), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.855 Zstick: Value_Added: Node: 35 (0x23), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.857 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.858 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.858 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.859 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.860 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.860 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.865 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.865 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.866 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.866 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.867 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.867 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.871 Zstick: Value_Added: Node: 37 (0x25), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.871 Zstick: Value_Added: Node: 37 (0x25), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.871 Zstick: Value_Added: Node: 37 (0x25), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.873 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.873 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.873 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.874 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.875 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.875 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.875 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.879 Zstick: Value_Added: Node: 38 (0x26), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.879 Zstick: Value_Added: Node: 38 (0x26), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.880 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.881 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.881 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.881 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.882 Zstick: Value_Added: Node: 40 (0x28), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2021-06-09 13:44:26.883 Zstick: Value_Added: Node: 40 (0x28), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.883 Zstick: Value_Added: Node: 40 (0x28), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.017 Status: ZG: (ZG) Zigate plugin stable5-5.1.003 started
2021-06-09 13:44:26.053 Status: ZG: (ZG) DeviceConf loaded
2021-06-09 13:44:26.467 Status: Zstick: A DNS Error Occurred
2021-06-09 13:44:26.467 Status: Zstick: ManufacturerSpecificDB Ready
2021-06-09 13:44:26.788 Status: Zstick: Driver Ready
2021-06-09 13:44:26.799 Status: Zstick: Unhandled class: 0x66 (NO OPERATION), NodeID: 13 (0x0d), Index: 1, Instance: 1
2021-06-09 13:44:26.884 Status: Zstick: New Node added. HomeID: 4119221429, NodeID: 26 (0x1a)
2021-06-09 13:44:28.474 ZG: (ZG) Connection open: None
2021-06-09 13:44:28.387 Status: ZG: (ZG) load ListOfDevice
2021-06-09 13:44:28.474 Status: ZG: (ZG) 9 Entries loaded from C:\Domoticz\plugins\Domoticz-Zigate\Data/DeviceList-3.txt
2021-06-09 13:44:28.476 Status: ZG: (ZG) Transport mode: USB
2021-06-09 13:44:29.913 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 7 (0x07)
2021-06-09 13:44:32.934 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 12 (0x0c)
2021-06-09 13:44:33.950 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-09 13:44:42.319 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 17 (0x11)
2021-06-09 13:44:43.333 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 18 (0x12)
2021-06-09 13:44:52.361 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 20 (0x14)
2021-06-09 13:44:53.369 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 21 (0x15)
2021-06-09 13:44:58.404 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 24 (0x18)
2021-06-09 13:45:04.451 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 27 (0x1b)
2021-06-09 13:45:05.471 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 28 (0x1c)
2021-06-09 13:45:19.999 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 31 (0x1f)
2021-06-09 13:45:23.015 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 32 (0x20)
2021-06-09 13:45:26.029 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 34 (0x22)
2021-06-09 13:45:28.077 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:28.085 Error: ZG: (ZG) [ 61] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:29.048 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 35 (0x23)
2021-06-09 13:45:29.075 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:29.081 Error: ZG: (ZG) [ 62] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:30.078 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:30.084 Error: ZG: (ZG) [ 63] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:31.076 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:31.084 Error: ZG: (ZG) [ 64] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:32.063 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 36 (0x24)
2021-06-09 13:45:32.075 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:32.084 Error: ZG: (ZG) [ 65] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:33.070 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 37 (0x25)
2021-06-09 13:45:33.064 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:33.075 Error: ZG: (ZG) [ 66] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:34.122 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:34.128 Error: ZG: (ZG) [ 67] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:35.116 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:35.121 Error: ZG: (ZG) [ 68] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:36.109 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:36.118 Error: ZG: (ZG) [ 69] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:37.101 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:37.109 Error: ZG: (ZG) [ 70] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:38.093 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:38.100 Error: ZG: (ZG) [ 71] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:39.089 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:39.102 Error: ZG: (ZG) [ 72] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:40.087 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:40.091 Error: ZG: (ZG) [ 73] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:41.091 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:41.096 Error: ZG: (ZG) [ 74] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:42.112 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 40 (0x28)
2021-06-09 13:45:42.093 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:42.102 Error: ZG: (ZG) [ 75] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:43.098 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:43.101 Error: ZG: (ZG) [ 76] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:44.099 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:44.107 Error: ZG: (ZG) [ 77] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:45.248 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-09 13:45:45.103 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:45.105 Error: ZG: (ZG) [ 78] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:46.094 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:46.101 Error: ZG: (ZG) [ 79] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:47.895 Zstick: General/kWh (kWh Meter)
2021-06-09 13:45:47.945 Zstick: General/kWh (kWh Meter)
2021-06-09 13:45:47.084 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:47.095 Error: ZG: (ZG) [ 80] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:48.078 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:48.088 Error: ZG: (ZG) [ 81] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
