The intention of this script is that a message is sent to Telegram if the set temperature exceeds the value
Only 1 freezer is currently in use, the other 2 are under construction.
Unfortunately the script gives a failure message that I can't figure out.
Who knows the solution?
2021-06-03 23:02:57.291 Error: EventSystem: problem writing file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Temp Koelen/Vriezer.lua
2021-06-03 23:12:20.266 Error: EventSystem: problem writing file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Temp Koelen/Vriezer.lua
2021-06-04 10:30:16.258 Error: EventSystem: problem writing file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Temp Koelen/Vriezer.lua
2021-06-04 10:38:44.785 Error: EventSystem: problem writing file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Temp Koelen/Vriezer.lua
2021-06-04 10:41:20.027 Error: EventSystem: problem writing file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Temp Koelen/Vriezer.lua
2021-06-04 10:41:58.698 Error: EventSystem: problem writing file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Temp Koelen/Vriezer.lua
return
timer = {
'Every 2 minutes'
logging = {
level = domoticz.LOG_DEBUG,
marker = "Temperatuur vrieskist/vrieskast/koelkast"
execute = function(domoticz, timer)
local TempVrieskist = domoticz.devices('Vrieskist')
--local TempVrieskast = domoticz.devices('Vrieskast')
--local TempKoelkast = domoticz.devices('Koelkast')
if tonumber(TempVrieskist.rawData[1]) > -16 then
domoticz.notify('Temperatuur info', 'Temperatuur in de vrieskist is ' ..TempVrieskist.rawData[1].. ' graden. Dat is te hoog! Staat de deksel open?')
domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
--if tonumber(TempVrieskast.rawData[1]) > -15 then (under construction )
--domoticz.notify('Temperatuur info', 'Temperatuur in de vrieskast is ' ..TempVrieskast.rawData[1].. ' graden. Dat is te hoog! Staat de deur open?') (under construction )
--domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO) (under construction )
--end
--if tonumber(TempKoelkast.rawData[1]) > 6 then (under construction )
--domoticz.notify('Temperatuur info', 'Temperatuur in de koelkast is ' ..TempKoelkast.rawData[1].. ' graden. Dat is te hoog! Staat de deur open?') (under construction )
--end
