How to send P1 history to Influxdb
Posted: Friday 28 May 2021 13:51
by hemant5400z
I just started to use Influxd however it is showing me the data from when the influx connections was ativated. Domoticz has the data from day1 started the P1 connection.
Is there a way to push all data to Influx DB?
Thanks,
Hemant
Re: How to send P1 history to Influxdb
Posted: Friday 04 June 2021 13:29
by hemant5400z
Nobody :(
The Live Data works fine, i'm currently using DSMR which has an export function, but want to stick with Domoticz data including history.
This is how it currently looks using Influx and Grafana.
Posted: Friday 04 June 2021 16:39
by waltervl
You could make an export to Excel/csv according this topic https://domoticz.com/forum/viewtopic.ph ... 54#p259154
And then find a way to import it into Influxdb
Or use the SQLlite plugin of Grafana and then you dont have to send anything to influx but directly graph the data out of domoticz database:
viewtopic.php?f=21&t=35101
