SOLVED On/Off Switch->Telegram Cam snapshot + text
McJohn
Post by McJohn »
Could somebody please help me with this script.
What I want is when:
Switch is On -> Telegram Cam snapshot + Text: Security ON
Switch is Off -> Telegram Cam snapshot + Text: Security OFF
This script below is working well. But it works only when the switch "AlarmLed" goes on.
And there is no text above or below the picture.
So, what should be added to the script?
Thanks in advance for all the support.
John
       devices = {'AlarmLed'},
        if(device.state == 'On') then
            local teleTok   = '111111111111111111111BBBBBBBBBBBBBBBBB'
            local chatId    = '-1234567890'
            local snapFile  = '/home/pi/domoticz/scripts/camera_'
            local domoReq   = 'http://192.168.178.231:8080/raspberry.cgi'
            local camName   = 'Frontdoor'
            os.execute('wget -O "'..snapFile..camName..'.jpg" "'..domoReq..'"')
            os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendPhoto?chat_id='..chatId..'" -F photo="@'..snapFile..camName..'.jpg"')
os.execute("rm " ..snapFile..camName..'.jpg')
Re: On/Off Switch->Telegram Cam snapshot + text
McJohn wrote: Monday 24 May 2021 13:02 This script below is working well. But it works only when the switch "AlarmLed" goes on.
No idea how to add text to the snapshot but below version should send something on state == 'On' and on state == 'Off'
        if device.state == 'On' then
        elseif device.state == 'Off' then
McJohn
Post by McJohn »
Thank you sooo much for the very quick reply, On/Off with sending the Telegram snapshot works perfect!
I have an URL for an HTTP command to add the text but I don't know where it has to insert into the script (and which command it has to be)
(This URL works in a browser; it send the text to a Telegram device)
https://api.telegram.org/bot11111111111111BBBBBBBBB/sendMessage?chat_id=1234567890&text=Security ON
and
https://api.telegram.org/bot11111111111111BBBBBBBBB/sendMessage?chat_id=1234567890&text=Security OFF
Do you have an idea where I have to place this text and what command I have to use?
Thanks in advance!
McJohn
Post by McJohn »
Got the text addition working!
The method with the HTTP URL is I think not the best solution (in comparison with with the os.execute('curl command) but it's working now.
Edit the script with:
local url1		= 'https://api.telegram.org/bot111111BBBB/sendMessage?chat_id=1234567890&text=Security ON'
local url2		= 'https://api.telegram.org/bot111111BBBB/sendMessage?chat_id=1234567890&text=Security OFF'
and further on with:
            domoticz.openURL(url1)
            domoticz.openURL(url2)
Thanks for listening and your terrific support.
McJohn
Post by McJohn »
PS: instead of the above code for text addition, this one is also working well into the script:
os.execute('curl -s -X POST "https://api.telegram.org/bot111111111BBBBBBB/sendMessage?chat_id=123456789&text=Security OFF"')
(and also for the ON state).
