Energy costs in bar graph instead of line graph
Posted: Friday 21 May 2021 22:21
by HennyN
I hope to get an answer / solution to my challenge here. I read my energy consumption with a P1 module. That works. I found a script to calculate consumption to Energy costs and it works too. However, I see a line graph in the “log” of Gas costs and I would like a bar graph the same I see with my gas consumption and my power consumption.
I see this in the log of my gas costs:
But I would like to see it like this:
So with bars.
I use this script for it and will therefore have to change something somewhere, so it does shows bars instead of lines.
Who knows the answer or gives me a hint?
        on = { timer = { 'every 15 minutes' }},
        execute = function(domoticz, device, timer)
        local vandaagKwh      = domoticz.devices('Power').counterToday
        local vandaagM3Gas    = domoticz.devices('Gas').counterToday
        local StroomKosten  = domoticz.devices('StroomKosten')
        local GasKosten     = domoticz.devices('GasKosten')
        local Kosten = domoticz.devices('TotaalEnergieKosten')
        -- Eenheidsprijs in Euro's / Kwh - M3
        local kwhPrijs = 0.22903
        local gasM3Prijs = 0.74681
        if (domoticz.time == 'Between 23:00 and 07:00') or (domoticz.day == 'Saturday') or (domoticz.day == 'Sunday') then
            kwhPrijs = 0.21024 -- Daltarief
            kwhPrijs = 0.22903 -- Normaal tarief
        -- Vaste kosten in Euro's per dag (zoals vastrecht)
        local kwhPrijsVast = 0.70132
        local gasM3PrijsVast = 0.54740
        -- Kosten berekenen
        local kwhKosten = tonumber(domoticz.utils.round( (kwhPrijs * vandaagKwh) + kwhPrijsVast,2))
        local GasM3Kosten = tonumber(domoticz.utils.round( (gasM3Prijs * vandaagM3Gas) + gasM3PrijsVast,2))
        local Kostentotaal = kwhKosten + GasM3Kosten
        -- Kosten updaten
        StroomKosten.updateCustomSensor(kwhKosten)
        GasKosten.updateCustomSensor(GasM3Kosten)
        Kosten.updateCustomSensor(Kostentotaal)
Re: Energy costs in bar graph instead of line graph
Posted: Friday 21 May 2021 23:09
by waaren
HennyN wrote: Friday 21 May 2021 22:21 I use this script for it and will therefore have to change something somewhere, so it does shows bars instead of lines.
The type of graph is defined by the device type and not by dzVents. Best to experiment with other virtual device type. From the top of my head RFX counter produce bar graphs.
Posted: Sunday 23 May 2021 21:02
by HennyN
Is it possible to define a new device-type based on an existing device type? Copy a device-type and modify it????
Posted: Sunday 23 May 2021 21:12
by HennyN
By modifing the script I came a littlebit further and now got this:
But kWh should be EUR and I have to get two decimals instead of 3 but I think I can solve that by editing the formular in the script...
Posted: Monday 24 May 2021 0:27
by waaren
HennyN wrote: Sunday 23 May 2021 21:12 But kWh should be EUR
Press the edit (aanpassen) button on the device when in the utility tab.
Posted: Monday 24 May 2021 16:54
by HennyN
Oké. Now I have still one challenge... :(
How do I get 2 decimal place every where...
I did some testing and found that I can multiply with 100 in the script and then devide by 100 in the device..
But is there a neater way, better way to do that. :?:
Meter deler.jpg (57.93 KiB) Viewed 2005 times
Posted: Monday 31 May 2021 21:43
by HennyN
STRANGE !!!!!!
In an attempt to get column graphs of the cost of gas consumption I run into strange things. If I show the costs with a custom sensor, I get € 0.78. but when I turn it into a Counter I see € 0.78 in one place but € 0.22 in the top right (or often other values that do not match.
When I look at the log I see a negative value on today Monday.
What is going on here???? What am I doing wrong?
Rare getallen Gas.jpg (35.84 KiB) Viewed 1959 times
Instellingen Counter Gas.jpg (51.38 KiB) Viewed 1959 times
Grafiek Gaskosten.jpg (53.63 KiB) Viewed 1959 times
        on = { timer = { 'every 5 minutes' }},
        local TotaalKosten  = domoticz.devices('EnergieKosten')
        local KostenE       = domoticz.devices('KostenElektra')
        local KostenG       = domoticz.devices('KostenGas')
        local KostenET      = domoticz.devices('KostenEnergie')
        -- Kosten berekenen
        local KwhKosten = tonumber(domoticz.utils.round( (kwhPrijs * vandaagKwh) + kwhPrijsVast,2))
        local KostenTotaal = KwhKosten + GasM3Kosten
        local KwhKostenCount = 100 * KwhKosten
        local GasM3KostenCount = 100 * GasM3Kosten
	    local KostenTotaalCount = 100 * KostenTotaal
        -- Kosten updaten
        StroomKosten.updateCustomSensor(KwhKosten)
        TotaalKosten.updateCustomSensor(KostenTotaal)
        KostenE.updateCounter(KwhKostenCount)
        KostenG.updateCounter(GasM3KostenCount)
        KostenET.updateCounter(KostenTotaalCount)
Posted: Tuesday 01 June 2021 8:42
by waaren
HennyN wrote: Monday 31 May 2021 21:43 in the top right (or often other values that do not match.
Top right corner should show (max. today value )- (max yesterday value )
