Switching an ventilator with aqara humidity sensor Topic is solved
Fredom
Post by Fredom »
Dear members
The script as it is now works fine,
but there is no check if all values are at a normal level
The 'Humidity sensor 'Garagekamer' is an aqara humidity sensor.
The 'Ventilator wasdroger' is an kaku switch (433.90Mhz)
The script should turn on the 'Ventilator wasdroger' when the temp is above 25 degrees or the humidity is above 55%.
Whichever comes first
Switch off again when the temp drops below 25 degrees or below 55% moisture.
Is this possible?
This is mij script now
return
    on =
        devices =
            'Humidity sensor Garagekamer'
    logging =
        level  = domoticz.LOG_DEBUG,
        marker = 'Ventilator wasdroger',
    execute   = function(dz, device)
    local fan = dz.devices('Ventilator wasdroger')
       if  (device.name == 'Humidity sensor Garagekamer' and device.temperature >= 25) then
            fan.switchOn()
            fan.switchOff().afterMin(120)
Fredom
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
Re: Switching an ventilator with aqara humidity sensor
Fredom wrote: Friday 21 May 2021 17:24 The script should turn on the 'Ventilator wasdroger' when the temp is above 25 degrees or the humidity is above 55%.
Something like below?
return
    on =
        devices =
    logging =
        if ( device.temperature < 25 or device.humidity < 55 ) and fan.state == 'On' then
            fan.switchOff()
        elseif ( device.temperature >= 25 or device.humidity >= 55 )  and  fan.state == 'Off' then
            fan.switchOn()
Fredom
Post by Fredom »
waaren wrote: Friday 21 May 2021 19:51
return
    on =
        devices =
    logging =
            fan.switchOff()
            fan.switchOn()
Super it works perfectly.
Thanks again for your help
Fredom
Yours sincerely,
Fred
