How to stop Blinds when a Door Contact is open
gschmidt
Post by gschmidt »
I have Blinds (RFXtrx433XL - Type DC106) at the second floor which doesn't have an autostop function.
So if the window is open and the Blind command is "Close" it may get broken.
Now I also have a "Door Contact" (Zigbee2mqtt) device which I have attached to the window behind the Blinds.
Is it possible with dzVents to only open or close the Blinds if the "Door Contact" is closed?
Or "Stop" the Blinds (and if possible go back to "Open") when the "Door Contact" is set to "Open"?
I tried with following script but nothing happens when I first "Open" the "Door Contact" and "Close" the "Blinds" (not attached yet to the window ofcourse):
--- Rolluik security dzVents script
return
    on =
        devices =
            'Raam Sensor',
    logging =
        level = domoticz.LOG_ERROR,
        marker = 'Rolluik Security Raam Sensor',
    execute = function(dz, item)
        local luik = dz.devices('Luik 1')
        dz.log(luik.name .. ' (' .. luik.baseType ..') State is ' .. luik.state ,dz.LOG_DEBUG )
        dz.log(item.name .. ' (' .. item.baseType ..') State is ' .. item.state ,dz.LOG_DEBUG )
        if item.isDevice and item.state == 'Open' and luik.state == 'Close' then
            luik.cancelQueuedCommands()
            luik.Stop().checkFirst()
            luik.Open().checkFirst()afterSec(1)
But this is in the log:
2021-05-20 21:02:04.827 RFXtrx433XL: Blinds (Luik 1)
2021-05-20 21:02:07.674 Status: dzVents: Info: Handling events for: "Raam Sensor", value: "Open"
2021-05-20 21:02:10.818 Status: dzVents: Info: Handling events for: "Raam Sensor", value: "Closed"
2021-05-20 21:02:12.939 RFXtrx433XL: Blinds (Luik 1)
2021-05-20 21:02:27.552 Status: dzVents: Info: Handling events for: "Raam Sensor", value: "Open"
2021-05-20 21:02:33.831 RFXtrx433XL: Blinds (Luik 1)
2021-05-20 21:02:35.031 RFXtrx433XL: Blinds (Luik 1)
2021-05-20 21:02:42.230 Status: dzVents: Info: Handling events for: "Raam Sensor", value: "Closed"
Re: How to stop a Shutter when doorcontact is open
gschmidt wrote: Thursday 20 May 2021 21:13 I tried with following script but nothing happens when I first "Open" the "Door Contact" and "Close" the "Blinds" (not attached yet to the window ofcourse):
Made some small adjustments to the script. It might not directly solve the issue but it will show some more information.
(if you set the logging level to domoticz.LOG_ERROR it will only show errors)
return
    on =
        devices =
            'Raam Sensor',
    logging =
        level = domoticz.LOG_DEBUG,
        if item.isDevice and item.state == 'Open' and luik.state == 'Closed' then
            luik.stop()
            luik.open().afterSec(1)
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Maybe a stupid comment, but is the script now activated bij de "Raam Sensor" and not by "Luik" ?
    on =
        devices =
            'Raam Sensor',
So it must be
    on =
        devices =
            'Luik 1',
gschmidt
Post by gschmidt »
waaren wrote: Thursday 20 May 2021 21:38
return
    on =
        devices =
            'Raam Sensor',
    logging =
            luik.Stop()
            luik.Open().afterSec(1)
I have changed the code and switched the devices to
    on =
        devices =
            'Luik 1',
    logging =
        local sensor = dz.devices('Raam Sensor')
        dz.log(sensor.name .. ' (' .. sensor.baseType ..') State is ' .. sensor.state ,dz.LOG_DEBUG )
        -- if item.isDevice and item.state == 'Open' and luik.state == 'Closed' then
        if item.isDevice and item.state == 'Closed' and sensor.state == 'Open' then
            item.cancelQueuedCommands()
            item.Stop()
            item.Open().afterSec(1)
Not working....The log produces the following Error
2021-05-21 16:06:17.541 Status: dzVents: Info: Rolluik Security Raam Sensor: ------ Start internal script: Rolluik_Security: Device: "Luik 1 (RFXtrx433XL)", Index: 41
2021-05-21 16:06:17.542 Status: dzVents: Debug: Rolluik Security Raam Sensor: Processing device-adapter for Raam Sensor: Switch device adapter
2021-05-21 16:06:17.542 Status: dzVents: Debug: Rolluik Security Raam Sensor: Raam Sensor (device) State is Open
2021-05-21 16:06:17.542 Status: dzVents: Debug: Rolluik Security Raam Sensor: Luik 1 (device) State is Closed
2021-05-21 16:06:17.542 Status: dzVents: Info: Rolluik Security Raam Sensor: ------ Finished Rolluik_Security
2021-05-21 16:06:17.543 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-05-21 16:06:17.542 Error: dzVents: Error: (3.1.8) Rolluik Security Raam Sensor: An error occurred when calling event handler Rolluik_Security
2021-05-21 16:06:17.542 Error: dzVents: Error: (3.1.8) Rolluik Security Raam Sensor: ...z/scripts/dzVents/generated_scripts/Rolluik_Security.lua:28: attempt to call a nil value (field 'Stop')
2021-05-21 16:06:22.380 RFXtrx433XL: Blinds (Luik 1)
2021-05-21 16:06:22.548 Status: dzVents: Info: Handling events for: "Luik 1", value: "Stopped"
madpatrick
Re: How to stop Blinds when a Door Contact is open
What type of switch do you have selected in Domoticz for Luik 1 ?
For a Stop function you need to selected type : Venetians Blinds instead of Blinds (inverterted)
Venetian blinds has the stop function
gschmidt wrote: Friday 21 May 2021 16:22 Not working....The log produces the following Error
All dzVents methods and functions use camelCase (so every single one starts with lowercase)
Edited my previous post to reflect this.
gschmidt
Post by gschmidt »
waaren wrote: Friday 21 May 2021 19:13
Working, thanx! but the devices must be switched like madpatrik said.
Here the final Code
    on =
        devices =
            'Luik 1',
    logging =
        dz.log(sensor.name .. ' (' .. sensor.baseType ..') State is ' .. sensor.state ,dz.LOG_INFO )
        dz.log(item.name .. ' (' .. item.baseType ..') State is ' .. item.state ,dz.LOG_INFO )
            item.stop()
            item.open().afterSec(1)
            dz.notify('Luik 1','Het raam staat open, daarom is het rolluik weer geopend!', dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM)
