Problem with utils.stringSplit
Posted: Monday 17 May 2021 12:10
by Sagitarius
Hi Team,
had a first look on utils.stringSplit an copied the script below from forum, but it does not
work, I always get
2021-05-17 08:54:00.332 Status: dzVents: Error (2.4.19): ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:12: attempt to call field 'stringSplit' (a nil value)
Can one of you assist?
BTW I tested some more scripts found at this forum, get always the same error message
Many thanks.
    active = true,
        timer =
            'every 1 minutes'
	execute = function(dz)
    local myString = "A-B-C-D"
   myTable = dz.utils.stringSplit(myString,"-")
    for idx, val in pairs(myTable) do
     dz.log(idx..val)
Re: Problem with utils.stringSplit
Posted: Monday 17 May 2021 13:03
by waaren
Sagitarius wrote: Monday 17 May 2021 12:10 ad a first look on utils.stringSplit an copied the script below from forum, but it does not work, I always get
The version you are on is much too old to give proper support on.
What you could do is include the current utils.stringSplit function directly in your script; ike below example.
    active = true,
        timer =
            'every 1 minutes'
        local function stringSplit(text, sep, convertNumber, convertNil)
            if not(text) then return {} end
            local sep = sep or '%s'
            local include = '+'
            if convertNil then include = '*' end
            local t = {}
            for str in string.gmatch(text, "([^" ..sep.. "]" .. include .. ")" ) do
                if convertNil and str == '' then str = convertNil end
                table.insert(t, ( convertNumber and tonumber(str) ) or str)
            return t
       local myTable = stringSplit(myString,"-")
            dz.log(idx .. ': ' .. val)
