Removing (non marked) failed devices?
Posted: Sunday 16 May 2021 8:39
In the times of OZW 1.4, to remove nodes that were obviously failed (no more communication possible to trigger device exclusion, for instance because of HW failure or some device bug) but not market as "dead" by controller, I was doing this:
-Stop domoticz/zwave.
-Edit zwcfgXXX.xml, find node and remove it's whole COMMAND_CLASS_WAKE_UP section.
-Restart domoticz.
Then, at the end of modules interview (a few mn), failed nodes were marked "dead" by controller and could be remove using z-wave control panel:
- "Remove failed node" controller operation.
Problem: No more "dead" flag at domoticz restart after config edit+all node query ending, so removing such failed nodes does not work anymore.
If someone have a working solution for this: Have a Fibaro KeyFob that did not worked after Domoticz 2021.1 upgrade (from old stable v4.10717), showing zeroed IDs & not solved by wake-up etc... even exclusion was not possible: Had to factory reset it & worked after re-inclusion.
But no exclusion possible & not marked "dead", even after trying here-upper tip that used to work = help needed!
Thanks.
-Restart domoticz.
Thanks.
