Smoke detector reset
sieth
Post by sieth »
Hello community,
I have a problem with resetting my smoke detectors (433Mhz)
They switch on perfectly, I can reset the detectors and they seem to reset the devices.
They turn "Off" but when I run a script (LUA) to check if they are "Off" the script runs as if they are turned on.
Restarting Domoticz does the trick. Then the script sees the detectors in the "Off" status.
Do I miss something here? Is this a bug?
Thanks in advance!
Keith
Re: Smoke detector reset
sieth wrote: Wednesday 05 May 2021 14:58 I have a problem with resetting my smoke detectors (433Mhz)
Can you try after a reset of your smoke detector from a Lua / dzVents script using
http://<domoticz IP: domoticz port>/json.htm?type=command&param=resetsecuritystatus&idx=<IDX>&switchcmd=Normal
Maybe a next script will see the state of the detector as 'Off' or as 'normal' after this?
sieth
Post by sieth »
Waaren,
thank you for replying.
I tried all the json commands found in the wiki.
It did nothing, the script saw the detector "On".
Restarting Domoticz is currently my only solution. :geek:
Greeting's,
Keith
sieth wrote: Wednesday 05 May 2021 16:43 I tried all the json commands found in the wiki.
A copy of the device states is send to the script before execution and the values in that copy will not change during execution of the script.
Please share the script so we can help troubleshooting.
sieth
Post by sieth »
Very simple script.
When smoke detected, lights should turn on.
When detector has been reset, the lights are turned off manually.
if otherdevices['Detector1']=="On" or otherdevices['Detector2']=="On"
then
    if otherdevices['Light1']=="Off" then
    commandArray[#commandArray+1]={['Light1']="On"}
    if otherdevices['Light2']=="Off" then
    commandArray[#commandArray+1]={['Light2']="On"}
print("Smoke")
sieth wrote: Wednesday 05 May 2021 18:47 When smoke detected, lights should turn on.
Below test Lua will act on active smoke detectors and will reset the active ones after a set amount of seconds.
local detectors = { 'smoke' , 'testSmoke' } -- Name of your detectors
local dzPort = 8080 -- domoticz port
local resetTime = 30 -- in seconds
for idx, detector in ipairs(detectors) do
    if otherdevices[detector] == "On" then
        local resetURL = 'http://127.0.0.1:' .. dzPort ..'/json.htm?type=command&param=resetsecuritystatus&idx=' .. otherdevices_idx[detector] .. '&switchcmd=Normal'
        -- requires Local Networks (no username/password): to be set to 127.0.0.*;::1
        commandArray[#commandArray + 1] = { ['Alarm licht'] = "On" }
        commandArray[#commandArray + 1] = { OpenURL = resetURL .. ' AFTER ' .. ( resetTime + idx )  }
        commandArray[#commandArray + 1] = { [detector] = 'Off AFTER ' .. ( resetTime + 2 + idx ) }
        print('Smoke detected. Reset ' .. detector .. ' in ' .. (resetTime + 2 + idx ) .. ' seconds')
        print(detector .. ' not active (' .. otherdevices[detector] .. ')')
sieth
Post by sieth »
Thank you for helping me.
I tried your method but this was my log:
2021-05-06 11:17:12.548 Status: LUA: Smoke detected. Reset Rookmelder UPS in 33 seconds
2021-05-06 11:17:12.548 Status: LUA: Rookmelder Garage not active (Off)
2021-05-06 11:17:12.548 Status: EventSystem: Fetching URL http://127.0.0.1:8084/json.htm?type=com ... cmd=Normal after 31.0 seconds...
2021-05-06 11:17:12.562 Status: LUA: Smoke detected. Reset Rookmelder UPS in 33 seconds
2021-05-06 11:17:12.562 Status: LUA: Rookmelder Garage not active (Off)
2021-05-06 11:17:12.562 Status: EventSystem: Fetching URL http://127.0.0.1:8084/json.htm?type=com ... cmd=Normal after 31.0 seconds...
2021-05-06 11:17:13.873 Status: LUA: Smoke detected. Reset Rookmelder UPS in 33 seconds
2021-05-06 11:17:13.873 Status: LUA: Rookmelder Garage not active (Off)
2021-05-06 11:17:13.873 Status: EventSystem: Fetching URL http://127.0.0.1:8084/json.htm?type=com ... cmd=Normal after 31.0 seconds...
2021-05-06 11:17:13.887 Status: LUA: Smoke detected. Reset Rookmelder UPS in 33 seconds
2021-05-06 11:17:13.887 Status: LUA: Rookmelder Garage not active (Off)
2021-05-06 11:17:13.887 Status: EventSystem: Fetching URL http://127.0.0.1:8084/json.htm?type=com ... cmd=Normal after 31.0 seconds...
2021-05-06 11:17:14.053 Status: LUA: Smoke detected. Reset Rookmelder UPS in 33 seconds
2021-05-06 11:17:14.053 Status: LUA: Rookmelder Garage not active (Off)
2021-05-06 11:17:14.053 Status: EventSystem: Fetching URL http://127.0.0.1:8084/json.htm?type=com ... cmd=Normal after 31.0 seconds...
It kept going on forever. No reset was given.
Strange.
I've did a manual reset of the smoke detector but no change there...
:?: :geek:
sieth wrote: Thursday 06 May 2021 11:19 I tried your method but this was my log:
I double checked this on my installation (2021.1 build 13249) and the script works as expected.
What is the last seen time on the smoke detector before, during and after an execution cycle? (you may have to [ctrl] r to refresh the switch tab page)
Did you check this?
sieth
Post by sieth »
Did you check this?
Yes this is always configured on my setup.
I use domoticz for years but this strange issue I cannot explain.
When activating the smoke detector I checked the status of the device with json just to be sure:
http://ip:port/json.htm?type=devices&rid=idx --> "Status" : "On"
When deactivating/resetting
http://ip:port/json.htm?type=devices&rid=idx --> "Status" : "Off"
Everything seems turned "Off", only the scripted says it's "On"
Tried everything...
Very strange
sieth wrote: Thursday 06 May 2021 13:31 Tried everything...
Very strange
Can you show the complete result of
maybe I see something that is different from my setup and could explain why it does not work for you?
sieth
Post by sieth »
Ok, this are the outputs:
Smokedetector = On
	"ActTime" : 1620316718,
	"AstrTwilightEnd" : "23:48",
	"AstrTwilightStart" : "03:33",
	"CivTwilightEnd" : "21:52",
	"CivTwilightStart" : "05:29",
	"DayLength" : "15:05",
	"NautTwilightEnd" : "22:43",
	"NautTwilightStart" : "04:38",
	"ServerTime" : "2021-05-06 17:58:38",
	"SunAtSouth" : "13:40",
	"Sunrise" : "06:08",
	"Sunset" : "21:13",
	"app_version" : "2021.1 (build 13226)",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 0,
			"Data" : "On",
			"Description" : "",
			"DimmerType" : "none",
			"Favorite" : 0,
			"HardwareDisabled" : false,
			"HardwareID" : 9,
			"HardwareName" : "433MHz",
			"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
			"HardwareTypeVal" : 1,
			"HaveDimmer" : false,
			"HaveGroupCmd" : false,
			"HaveTimeout" : false,
			"ID" : "ED120B",
			"Image" : "Light",
			"IsSubDevice" : false,
			"LastUpdate" : "2021-05-06 13:31:49",
			"Level" : 0,
			"LevelInt" : 377,
			"MaxDimLevel" : 0,
			"Name" : "Rookmelder UPS",
			"Notifications" : "true",
			"PlanID" : "10",
			"PlanIDs" :
				10
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"Status" : "On",
			"StrParam1" : "",
			"StrParam2" : "",
			"SubType" : "PT2262",
			"SwitchType" : "Smoke Detector",
			"SwitchTypeVal" : 5,
			"Timers" : "false",
			"Type" : "Lighting 4",
			"TypeImg" : "smoke",
			"Unit" : 0,
			"Used" : 1,
			"UsedByCamera" : false,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "186"
	"status" : "OK",
	"title" : "Devices"
Smoke detector = off
	"ActTime" : 1620316810,
	"ServerTime" : "2021-05-06 18:00:10",
	"Sunset" : "21:13",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CustomImage" : 0,
			"Data" : "Off",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 9,
			"ID" : "ED120B",
			"Image" : "Light",
			"Level" : 0,
			"LevelInt" : 377,
			"MaxDimLevel" : 0,
			"PlanID" : "10",
			"PlanIDs" :
				10
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"Timers" : "false",
			"Unit" : 0,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "186"
	"status" : "OK",
	"title" : "Devices"
sieth wrote: Thursday 06 May 2021 18:00 Ok, this are the outputs:
Checked against mine but do not see any differences that could explain different behavior.
sieth
Post by sieth »
Let's blame it on the 433MHz smoke detectors. :lol:
I'll just restart domoticz when they were activated.
No problem.
Thanks for helping me!
Keith
manjh
Post by manjh »
sieth wrote: Friday 07 May 2021 10:48 Let's blame it on the 433MHz smoke detectors. :lol:
No problem.
Keith
Which brand are the detectors?
I am considering buying four KAKU detectors, but before I do that want to make sure they work properly with Domoticz!
Hans
sieth
Post by sieth »
They are from Aliexpress
https://a.aliexpress.com/_mrwQPxD
:) greetings
manjh
Post by manjh »
sieth wrote: Wednesday 22 September 2021 15:22 They are from Aliexpress
:) greetings
Thanks. I looked at the description, and it looks like a good deal. I read that you get four detectors for 23 or 24 Euro?
Hans
Domoticz version: 2025.1
manjh wrote: Saturday 25 September 2021 9:32
:) greetings
Watch out for extra taxes and transport fees when buying something from outside Europe! New rules being implemented from 1st of July.
manjh
Post by manjh »
Yes, I know. But the product description at AliExpress now states "VAT included", so I assume this makes it safe to order without additional cost, right?
Hans
I did not try it yet. According this article (in dutch) it should be possible: https://nos.nl/l/2384698
sieth
Post by sieth »
manjh wrote: Monday 27 September 2021 22:06 Yes, I know. But the product description at AliExpress now states "VAT included", so I assume this makes it safe to order without additional cost, right?
Indeed, works perfectly.
No additional costs.
For me the new rules are better.
You can now buy to 150€ without hidden costs.
Ordered several things and they all arrived.
