Control a garage port with Arduino via Domoticz
Posted: Tuesday 04 May 2021 19:28
by LordMax
Hi!
I am trying to control my garage port with an Arduino. I have a Domoticz windows server running controlling all lights and sensors in my house and I want to add my garage port to the system, the gate works like if it gets a puls it opens/closes and if it gets another pulse while opening/closing it stops, then goes the reversed way. I have a Relay to control the pulse but how do I "connect" it to domoticz?
Thanks beforehand!
Best regards Max
Re: Control a garage port with Arduino via Domoticz
Posted: Tuesday 04 May 2021 19:38
What kind of wireless gateways to Domoticz do you have? Because that save you some money to buy a new gateway. Wifi is off course 1 of the possibility but there is also zigbee, zwave, RF etc.
Posted: Tuesday 04 May 2021 19:45
by zygios
You need Arduino with Ethernet shield + Relay or more simple would be to buy ESP8266 and connect relay (on ESP8266 install espeasy firmware with works perfectly with Domoticz.
Posted: Tuesday 04 May 2021 19:46
by LordMax
I have a Arduino D1 Mini Pro (based on ESP-8266EX) and a relay
Posted: Tuesday 04 May 2021 22:19
If it is compatible with ESPEASY you have a domoticz interface with that.
Posted: Tuesday 04 May 2021 22:26
by LordMax
Ok, I will give it a try! Wish me good luck :)
Posted: Monday 12 July 2021 17:49
by LordMax
I just got it working! I had to wait for the arduino. It was easy to setup and works flawless. Thanks for the help!
Posted: Monday 12 July 2021 20:14
Good to hear! What was your method you used, with Espeasy?
Posted: Sunday 06 August 2023 18:07
by tvurce
How to do that without espeasy? Because i have on this esp32 another sensors etc. reporting to domoticz and i want to drive relay with the same esp32 through domoticz.
