Z-Wave MQTT question Topic is solved
mgugu
Post by mgugu »
I use a web services unit written in node js to centralise common actions of my different domoticz servers.
I need to collect all devices data including idx and node Id when relevant, for that I use mqtt messages delivered by the domoticz servers.
The question concerns the case of zwave devices for which I need to get the node Id for further actions.
I have a Qubino switch including also a thermal sensor, so I get 2 devices sharing the same node Id:
For the switch I get the following mqtt message:
"dtype" : "Light/Switch",
"hwid" : "7",
"id" : "00004701",
"idx" : 1149,
and for the sensor:
"dtype" : "Temp",
"hwid" : "7",
"id" : "18177",
"idx" : 1152,
For the switch the node Id is encapsulated in the id field: 47 is the hexa coded node Id
But for the sensor this is is something different, id = 18177 which is the hexa to decimal coded value of 4701
Does somebody know what is the logic behind ?
Thx in advance
Re: Z-Wave MQTT question
mgugu
Post by mgugu »
Thank you waltervl for the reference. Things are OK for me regarding the domoticz/devices panel since the node Id is coded coherently (4701).
But this is not reflected by the mqtt message in which the node Id is not coded accordingly.
What is the device id of the temp sensor in the device list?
I think you will have to relate that id to the id sent by MQTT (hex translation?)
From https://www.domoticz.com/wiki/Zwave#Z-W ... n_Domoticz
Domoticz DeviceID = 00 00 NODEID INSTANCEID. If this is for example Node 18 (hex 0x12) the ID could be 00 00 12 02.
mgugu
Post by mgugu »
waltervl wrote: Wednesday 05 May 2021 12:23 What is the device id of the temp sensor in the device list?
The id in device list is 4701, but via MQTT it becomes 18177 which is the decimal conversion of 4701.
OK, it is easy to back convert it but the problem is that the conversion made by MQTT is not systematic for all nodes as is shown in my first examples.
The question is how do I know if I have to back convert or not ?
Strange, I would expect something like 00004702 instead of 4701 as the other device of that node is called 00004701
And what ID is http://DomoIP:DomoPort/json.htm?type=devices&rid=IDX giving when entering both device IDX's?
Result should include following example result:
	"result": [
			"AddjMulti": 1,
			"AddjMulti2": 1,
			"AddjValue": 0,
			"AddjValue2": 0,
			"BatteryLevel": 255,
			"CustomImage": 0,
			"Data": "On",
			"Description": "Plain text",
			"DimmerType": "none",
			"Favorite": 0,
			"HardwareDisabled": false,
			"HardwareID": 3,
			"HardwareName": "virtual",
			"HardwareType": "Dummy (Does nothing, use for virtual switches only)",
			"HardwareTypeVal": 15,
			"HaveDimmer": true,
			"HaveGroupCmd": true,
			"HaveTimeout": false,
==>			"ID": "00014052",
			"Image": "Light",
			"IsSubDevice": false,
			"LastUpdate": "2021-02-10 22:47:03",
			"Level": 0,
			"LevelInt": 0,
			"MaxDimLevel": 100,
			"Name": "mySwitch",
			"Notifications": "false",
			"PlanID": "0",
			"PlanIDs": [
				0
			"Protected": false,
			"ShowNotifications": true,
			"SignalLevel": "-",
			"Status": "On",
			"StrParam1": "",
			"StrParam2": "",
			"SubType": "Switch",
			"SwitchType": "On/Off",
			"SwitchTypeVal": 0,
			"Timers": "false",
			"Type": "Light/Switch",
			"TypeImg": "lightbulb",
			"Unit": 1,
			"Used": 1,
			"UsedByCamera": false,
			"User": "Admin (IP: 192.168.192.41)",
			"XOffset": "0",
			"YOffset": "0",
			"idx": "2"
mgugu
Post by mgugu »
From a JSON point of view, everything is OK:
	"HardwareID" : 7,
	"HardwareName" : "OpenZwave",
	"HardwareTypeVal" : 21,
	"HaveTimeout" : false,
	"ID" : "4701",
But trough MQTT I get
	"dtype" : "Temp",
	"hwid" : "7",
	"id" : "18177",
	"idx" : 1152,
18177 is decimal conversion of 4701
and for dependent zwave device (same node Id) I get:
	"hwid" : "7",
	"id" : "00004701",
	"idx" : 1149,
Which is correct
Looks like some mess!
mgugu wrote: Wednesday 05 May 2021 14:03 From a JSON point of view, everything is OK:
	"HardwareID" : 7,
	"ID" : "4701",
This is not completely what I asked
Can you please give the full outcome of
http://DomoIP:DomoPort/json.htm?type=devices&rid=1149
and
http://DomoIP:DomoPort/json.htm?type=devices&rid=1152
mgugu
Post by mgugu »
Yep:
	"ActTime" : 1620234472,
	"AstrTwilightEnd" : "23:31",
	"AstrTwilightStart" : "04:07",
	"CivTwilightEnd" : "21:49",
	"CivTwilightStart" : "05:49",
	"DayLength" : "14:48",
	"NautTwilightEnd" : "22:36",
	"NautTwilightStart" : "05:02",
	"ServerTime" : "2021-05-05 19:07:52",
	"SunAtSouth" : "13:49",
	"Sunrise" : "06:25",
	"Sunset" : "21:13",
	"app_version" : "2021.1 (build 13243)",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 15,
			"Data" : "Off",
			"Description" : "",
			"DimmerType" : "none",
			"Favorite" : 0,
			"HardwareDisabled" : false,
			"HardwareID" : 7,
			"HaveDimmer" : true,
			"HaveGroupCmd" : true,
			"ID" : "00004701",
			"Image" : "Heating",
			"IsSubDevice" : false,
			"LastUpdate" : "2021-05-05 19:00:01",
			"Level" : 0,
			"LevelInt" : 0,
			"MaxDimLevel" : 100,
			"Name" : "Confort",
			"Notifications" : "false",
			"PlanID" : "9",
			"PlanIDs" :
				9
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"SubType" : "Switch",
			"SwitchType" : "On/Off",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "Light/Switch",
			"TypeImg" : "lightbulb",
			"Unit" : 1,
			"Used" : 1,
			"UsedByCamera" : false,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "1149"
	"status" : "OK",
	"title" : "Devices"
	"ActTime" : 1620234546,
	"ServerTime" : "2021-05-05 19:09:06",
	"Sunset" : "21:13",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CustomImage" : 0,
			"Data" : "21.2 C",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 7,
			"ID" : "4701",
			"LastUpdate" : "2021-05-05 19:08:03",
			"Name" : "T\u00b0RdC2",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"SubType" : "LaCrosse TX3",
			"Temp" : 21.199999999999999,
			"Timers" : "false",
			"Type" : "Temp",
			"TypeImg" : "temperature",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "1152",
			"trend" : 3
	"status" : "OK",
	"title" : "Devices"
Nice, yes you would expect that MQTT would send the text ID's "4701" and "00004701" belonging to the devices, but it does not.
I was hoping you interpreted something wrong but you did not ..... :-)
So I hope someone passes by that can enlighten this unexpected behavior. According the MQTT wiki page it should be similar as the API/Json but it is not for the ID field.
Else check the MQTT source code on github....
mgugu wrote: Tuesday 04 May 2021 10:46 Does somebody know what is the logic behind ?
I don't completely understand the logic behind it (Zwave is too complicated for me) but let me try to explain what I understand from what is causing this.
MQTT just sends the DeviceID it finds in that field in the domoticz database in table DeviceStatus.
The /json.htm?type=devices&rid=1149 and other type=devices json calls (which are also used to build the page of the devices tab) apply some logic to the DeviceID if the device is Zwave. It does conditional magic based on the value having leading zero's or not.
Below the code snippet from WebServer.cpp starting at line 9531
#ifdef WITH_OPENZWAVE
						if (pHardware != nullptr)
							if (pHardware->HwdType == HTYPE_OpenZWave)
								COpenZWave *pZWave = reinterpret_cast<COpenZWave*>(pHardware);
								unsigned long ID;
								std::stringstream s_strid;
								s_strid << std::hex << sd[1];
								s_strid >> ID;
								int nodeID = (ID & 0x0000FF00) >> 8;
								bHaveTimeout = pZWave->HasNodeFailed(nodeID);
#endif
mgugu
Post by mgugu »
OK so the conclusion at the moment is that we cannot rely on MQTT as far as node Id is concerned, only JSON provide reliable results.
I would suggest to developper to harmonize all that in a future release.
Anyway thank you very much Walter and Waaren for spending time on my question.
mgugu wrote: Thursday 06 May 2021 0:07 I would suggest to developer to harmonize all that in a future release.
Created issue 4814
Thank you @waaren!
@gizmocuz picked up your suggestion. Can you please check build >= 13251 and post your findings on github (issue 4814) ?
mgugu
Post by mgugu »
Everyhing is OK now with build 13251. MQTT reflects JSON output regarding Zwave node Id.
Thank you @gizmocuz and @rwaaren for this very quick problem resolution
