dzVents script not triggered by PIR status On, but triggered by status Off
Posted: Monday 03 May 2021 22:31
Hello, I have a problem that I've been running into for the past week or so.
I don't know if it is a coincidence that I updated my Domoticz to the most recent version around the same time.
My script was running (kind of) flawless until then and now it isn't.
That being said, I don't know whether this is a dzVents issue or rathers something to do with the behavior my PIR(s).
It seems that my script is only triggered when a PIR changes its status to "Off" and not on the status change to "On". Which is unfortunate, because I use it to do stuff immediately following the detection of motion.
This is the script that I use to flip a virtual switch named 'BewegingWoonkamerTimeout'. It used to flip the switch immediately when motion was detected, but since a week or so I noticed quite an annoying delay in this process. Tonight I got the time to look further into it and I discovered that it seems that this code does not flip the switch when the PIR status changes to "On", but it does flip the switch when the PIR status changes to "Off".
Looking more closely into the log, I gather that the PIR changing status to "On" does not even trigger the script. Although the script is set to be triggered on devices = {'PIR WK*'}, it seems that only the status change to "Off", 30 seconds after being set to "On", does trigger the above script. And there's my delay.
These are the relevant lines of the logfile:
So here's my question, taking into account that I did not change anything in my scripts in the past few weeks: is this change in behavior caused by dzVents or a dzVents update, or should I replace my PIR and see if that is the problem?
The PIR is a Fibaro motion sensor (not the most recent version).
--[[ livingroomMotionHelper.lua
This script flips the Dummy switch named 'BewegingWoonkamerTimeout' when one of the PIR WK sensors
(the PIR's in the WoonKamer) detects motion.
When none of the PIR's has been active for 10 minutes, the Dummy switches is flipped to off status.
The status of the Dummy switch is used in the conditionalMotion script that relies on this
for determining whether the lights can be switched off.
original source: https://www.domoticz.com/forum/viewtopic.php?t=30136
return
on =
devices = {'PIR WK*'}, -- triggered by PIRs in the livingroom
timer = {'every minute'},
logging =
level = domoticz.LOG_ERROR, -- Select one of LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE to override system log level
marker = "### livingroomMotionHelper ###"
execute = function(dz,trigger,triggerInfo)
local active = 0
local motionActive = dz.devices('BewegingWoonkamerTimeout')
-- filter devices on name
dz.devices().filter(function(dv)
return (dv.name):match('PIR WK')
-- filter result on lastUpdate
end).filter(function(dv)
return dv.lastUpdate.minutesAgo <= 10
-- act on result
end).forEach(function(dv)
active = active + 1
--dz.log(dv.name .. '; status ==>> ' .. dv.state .. '; last Updated: ' .. dv.lastUpdate.rawDate ..', ' ..dv.lastUpdate.rawTime ,dz.LOG_FORCE)
end)
if active == 0 then
motionActive.switchOff().checkFirst()
motionActive.switchOn().checkFirst()
dz.log('BewegingWoonkamerTimeout aangezet',dz.LOG_FORCE)
--dz.log('Aantal actieve devices = ' .. active,dz.LOG_FORCE)
}These are the relevant lines of the logfile:
2021-05-03 22:23:14.430 Aeon Z-Stick: Light/Switch (PIR WK FIB3)
2021-05-03 22:23:14.594 Status: dzVents: Info: Handling events for: "PIR WK FIB3", value: "On"
[... nothing happens here ...]
2021-05-03 22:23:48.876 Aeon Z-Stick: Light/Switch (PIR WK FIB3)
2021-05-03 22:23:49.126 Dummy: Lighting 1 (BewegingWoonkamerTimeout)
2021-05-03 22:23:49.037 Status: dzVents: Info: Handling events for: "PIR WK FIB3", value: "Off"
2021-05-03 22:23:49.115 Status: dzVents: !Info: ### livingroomMotionHelper ###: BewegingWoonkamerTimeout aan
2021-05-03 22:23:49.118 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.luaThe PIR is a Fibaro motion sensor (not the most recent version).
