Fibaro FGRM222 Roller Shutter
Knibor
Domoticz version: Stable
Post by Knibor »
Hello all,
After the Domoticz stable update, almost everything works.
However, I can't get 1 device to work anymore.
It is a Fibaro FGRM222 Roller Shutter. If I go to the Node management and then control panel. Then I can open and close the roller shutter. In Domoticz the device shows the status open or closed, but I cannot open or close the roller shutter with the Domoticz device. If I open or close the roller shutter then I get the message in Domoticz "Error sending switch command, check device/hardware (idx=531) !"
What can I do to solve this problem?
noqaut
Re: Fibaro FGRM222 Roller Shutter
Post by noqaut »
I am interested in the status after 3 years, I run into the same problem with the roller shutter 3
