Attempt to concatenate a table value  [SOLVED]
AYAMY
Post by AYAMY »
I have several Tplink hs110 ( meters ) in my house.
Each meter tracks this kind of data
	"ActTime" : 1619516296,
	"AstrTwilightEnd" : "21:46",
	"AstrTwilightStart" : "04:16",
	"CivTwilightEnd" : "20:29",
	"CivTwilightStart" : "05:33",
	"DayLength" : "13:55",
	"NautTwilightEnd" : "21:06",
	"NautTwilightStart" : "04:56",
	"ServerTime" : "2021-04-27 11:38:16",
	"SunAtSouth" : "13:01",
	"Sunrise" : "06:03",
	"Sunset" : "19:58",
	"app_version" : "2021.1",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CounterToday" : "0.002 kWh",
			"CustomImage" : 0,
			"Data" : "8.884 kWh",
			"Description" : "",
			"EnergyMeterMode" : "",
			"Favorite" : 1,
			"HardwareDisabled" : false,
			"HardwareID" : 15,
			"HardwareName" : "Lavastoviglie",
			"HardwareType" : "TP-Link Wi-Fi Smart Plug HS100/HS110",
			"HardwareTypeVal" : 94,
			"HaveTimeout" : false,
			"ID" : "000F0004",
			"LastUpdate" : "2021-04-27 11:37:41",
			"Name" : "Lavastoviglie -  kWh",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "kWh",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "General",
			"TypeImg" : "current",
			"Unit" : 4,
			"Usage" : "0.3 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "133"
	"status" : "OK",
	"title" : "Devices"
I want to sum the value of Power of each meters and update a dummy device (custom type) with this code
	    timer = { 'every 1 minutes' }
	    local APower = domoticz.devices(129)       -- Acquario Ciano luce frontale  -  kWh -- IDX 129
	    local BPower = domoticz.devices(133)       -- Lavastoviglie -  kWh -- IDX 133
	    local CPower = domoticz.devices(137)       -- Forno -  kWh -- IDX 137
	    local DPower = domoticz.devices(141)       -- Acquario Fluval Amtra Orion -  kWh -- IDX 141
	    local EPower = domoticz.devices(146)       -- Acquario Fluval Fitostimolante - kWh -- IDX 146
	    local FPower = domoticz.devices(150)       -- Acquario Ciano Luce Bianca -  kWh -- IDX 150
	    local GPower = domoticz.devices(154)       -- Servizio - kWh -- IDX 154 usato per l'acquario Caridine
	    local HPower = domoticz.devices(158)       -- Acquario Ciano Flusso - kWh IDX 158
	    local IPower = domoticz.devices(890)       -- Daiking Living Heat kWh -- IDX 890
	    local LPower = domoticz.devices(891)       -- Daiking Living Cool kWh -- IDX 891
	    local MPower = domoticz.devices(892)       -- Daiking Bedroom Heat kWh -- IDX 892
	    local NPower = domoticz.devices(892)       -- Daiking Bedroom Cool kWh -- IDX 893
	    local totalUsage = domoticz.devices(909)  -- total of All IDX DEVICES  power meter
	    print ('######################################################')
	    print ('Device value:' .. APower.WhActual + BPower.WhActual + CPower.WhActual + DPower.WhActual + EPower.WhActual + FPower.WhActual + GPower.WhActual + HPower.WhActual + IPower.WhActual + LPower.WhActual + MPower.WhActual + NPower.WhActual)
	    totalUsage.updateCustomSensor(	APower.WhActual + BPower.WhActual + CPower.WhActual + DPower.WhActual + EPower.WhActual + FPower.WhActual + GPower.WhActual + HPower.WhActual + IPower.WhActual + LPower.WhActual + MPower.WhActual + NPower.WhActual)
        print ('Device value:' .. totalUsage)
but in the log i see
2021-04-27 11:47:00.288 Error: dzVents: Error: (3.1.7) An error occurred when calling event handler CalcoloUsagePerCustom
2021-04-27 11:47:00.288 Error: dzVents: Error: (3.1.7) ...ipts/dzVents/generated_scripts/CalcoloUsagePerCustom.lua:27: attempt to concatenate a table value (local 'totalUsage')
attempt to concatenate a table value (local 'totalUsage') what's the problem ? :?:
AYAMY
Re: Attempt to concatenate a table value  [SOLVED]
Post by AYAMY »
sorry....
solved...
remove this
AYAMY wrote: Tuesday 27 April 2021 12:02
remove this
There is one device used twice in your example. (local NPower = domoticz.devices(892) -- Daiking Bedroom Cool kWh -- IDX 893)
You could also try
        local myDevices =
            129, 133, 137, 141, 146, 150, 154, 158, 890, 891, 892, 893
        local sumWhActual = 0
        for _,idx in ipairs(myDevices) do
            sumWhActual = sumWhActual + domoticz.devices(idx).WhActual
        totalUsage.updateCustomSensor( sumWhActual)
        print ('New device value for ' .. totalUsage.name .. ': ' .. sumWhActual)
AYAMY
Post by AYAMY »
thanks it works !!! ;)
