Charging home battery
hclardij
Post by hclardij »
Hi guru's,
I am noob to Domoticz and programming and want to achieve the following:
- I have solar panels that supply a surplus of power during the day; I can read power values from the inverter as well as from the powermeter.
- I have build a 48v 2kWh battery, I have several chargers, but for this example lets assume it has 250 Watt capacity
- I have a couple of Tasmota plugs that I can switch on and of from Domoticz
- Since I am completely new to programming I thought II use blockly; I already managed to switch on the plugs in the evening and so on.
My idea was to take the reading from the power meter and use: if power < -250 , then switch on the charger.
By the looks the negative value is not accepted.
Any clues are highly appreciated.
TIA
jake
Re: Charging home battery
Post by jake »
I have no solution for your blockly, you better place s screenshot of your existing one.
I have created a script that simulates such a battery, you could try that one too see what the real battery is supposed to do in your situation
https://github.com/jakenl/domoticz_solarbattery
hclardij
Post by hclardij »
Hmm,...I do have some questions that I will put in your post.
Screenshot of my current blockly is attached
Screen Shot 2021-04-26 at 20.50.16.png (66.23 KiB) Viewed 1096 times
jake
Post by jake »
Do you use a p1 meter for the electricity? Can you see somewhere what the actual power is, when you deliver power to the grid? I'd say it should work with negative values.
hclardij
Post by hclardij »
Yes I do have a meter with P1 and I can see the actual value; If it is a negative number I am delivering to the grid.
Screen Shot 2021-04-28 at 11.21.56.png (185.3 KiB) Viewed 1055 times
hclardij
Post by hclardij »
So I did some testing and found out that the value has to be greater than 0. 0 is failing, but 0.001 is working.
My guess is that blockly is to limited in its capabilities.
