Page 1 of 2
Cannot get dzVents to trigger
Posted: Sunday 11 April 2021 16:53
by Sjoko
I cannot get an dzVents script to be triggered.
I want to handle status change of a dummy switch.
This is my script:
-- eventTestSwich.lua
		devices = {
			113
	logging =   {   level     =   domoticz.LOG_INFO,
                    marker    =   "I am eventTestSwich script....."    },
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_FORCE)
Nothing appears in the log.
The following test script does work:
-- Alive.lua
    on      =   {
        timer           = { "every minute" },
        devices         = {	74, 113 },
                    marker    =   "I am alive....."    },
    execute = function(dz)
        dz.log("You will see this every minute until you deactivate", dz.LOG_FORCE)
Settings->Setup->Other
dzVents: enabled
Log Level: Errros + minimal execution info + generic info
I'm using:
raspberryPi
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: None
Re: Cannot get dzVents to trigger
Posted: Sunday 11 April 2021 17:07
by waaren
Sjoko wrote: Sunday 11 April 2021 16:53 I cannot get an dzVents script to be triggered.
Only explanation I can think of is a wrong id.
Can you try again with below version?
return
    on =
        devices =
    logging =
        marker = "I am eventTestSwich script.....",
    execute = function(dz, item)
        dz.log('Device ' .. item.name .. ' (' .. item.id .. ') triggered this script', domoticz.LOG_FORCE)
Posted: Sunday 11 April 2021 21:07
by Sjoko
The wildcard '*'' results in the logging of one device with id 110 in the log.
When I flip the switch device 103, the event is not triggered.
Device 103 and 100 are of exactly the same type 'type Light/Switch, Switch, On/Off'
I read in some old posts that there might be a conflict with other scripts, if I understood correctly. I'm using multiple blockly scripts.
Posted: Sunday 11 April 2021 21:20
by waaren
Sjoko wrote: Sunday 11 April 2021 21:07 The wildcard '*'' results in the logging of one device with id 110 in the log.
I have never experienced a conflict between Blockly and dzVents scripts.
Are device 103 and 100 set to active? (Are the arrows on devices tab blue?)
Posted: Monday 12 April 2021 18:16
by Piacco
In your first post you spreak about device 113 in the other post is it 103, could that be the problem?
Posted: Monday 12 April 2021 23:05
by Sjoko
The dummy (problem) switch has Idx 113.
I mistakenly mentioned 103, should have been 113.
Sorry about the confusion.
by Sjoko
How can I debug this ?
Posted: Monday 12 April 2021 23:08
by waaren
Sjoko wrote:How can I debug this ?
Can you share a screenshot of your devices tab?
Posted: Monday 12 April 2021 23:14
by Sjoko
Yes they are blue
As mentioned earlier, typos on the idx, should have been 113 and 110, scripts are fine.
Both are blue, only 110 appears in the log (due to wildcard)
Posted: Tuesday 13 April 2021 0:01
by waaren
Sjoko wrote: Monday 12 April 2021 23:14 Both are blue, only 110 appears in the log (due to wildcard)
Can you share the result of the following http calls from within your browser?
http://<domoticz IP:domoticz port/json.htm?type=devices&rid=113
http://<domoticz IP:domoticz port/json.htm?type=hardware
Posted: Wednesday 14 April 2021 22:22
by Sjoko
http://pi:8080/json.htm?type=devices&rid=113
	"ActTime" : 1618431602,
	"AstrTwilightEnd" : "22:42",
	"AstrTwilightStart" : "04:29",
	"CivTwilightEnd" : "21:07",
	"CivTwilightStart" : "06:04",
	"DayLength" : "13:52",
	"NautTwilightEnd" : "21:52",
	"NautTwilightStart" : "05:19",
	"ServerTime" : "2021-04-14 22:20:02",
	"SunAtSouth" : "13:35",
	"Sunrise" : "06:39",
	"Sunset" : "20:31",
	"app_version" : "2020.2",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 0,
			"Data" : "Off",
			"Description" : "",
			"DimmerType" : "none",
			"Favorite" : 0,
			"HardwareID" : 36,
			"HardwareName" : "eventTestSwich",
			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
			"HardwareTypeVal" : 15,
			"HaveDimmer" : true,
			"HaveGroupCmd" : true,
			"HaveTimeout" : false,
			"ID" : "000140C1",
			"Image" : "Light",
			"IsSubDevice" : false,
			"LastUpdate" : "2021-04-12 23:01:15",
			"Level" : 0,
			"LevelInt" : 0,
			"MaxDimLevel" : 100,
			"Name" : "eventTestSwich",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"SubType" : "Switch",
			"SwitchType" : "On/Off",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "Light/Switch",
			"TypeImg" : "lightbulb",
			"Unit" : 1,
			"Used" : 1,
			"UsedByCamera" : false,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "113"
	"status" : "OK",
	"title" : "Devices"
Posted: Wednesday 14 April 2021 22:24
by Sjoko
http://pi:8080/json.htm?type=hardware
	"result" :
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "slimmeMeter",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "/dev/ttyUSB1",
			"Type" : 4,
			"Username" : "",
			"idx" : "1"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Zutphen ForecastIO",
			"Password" : "52.114666,6.212721",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 25,
			"Username" : "7b463cedffd859f7b0d062053313007a",
			"idx" : "2"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Motherboard",
			"Password" : "",
			"Port" : 1,
			"SerialPort" : "",
			"Type" : 23,
			"Username" : "",
			"idx" : "3"
			"Address" : "pi-doeke.vk.guepin.com",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "pi-doeke",
			"Password" : "0772251107ef60d3971d2831939e529e",
			"Port" : 6144,
			"SerialPort" : "6144",
			"Type" : 3,
			"Username" : "admin",
			"idx" : "4"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "false",
			"Extra" : "",
			"Mode1" : 60,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "evohome",
			"Password" : "S,Q$8(X>`Mg;GoWtg",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 75,
			"Username" : "[email protected]",
			"idx" : "5"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 25,
			"idx" : "6"
			"Address" : "cheap.vk.guepin.com",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 30,
			"Mode2" : 1000,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "LMS Cheap",
			"Password" : "",
			"Port" : 9000,
			"SerialPort" : "9000",
			"Type" : 60,
			"Username" : "",
			"idx" : "7"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "GemBird2",
			"Password" : "",
			"Port" : 1,
			"SerialPort" : "1",
			"Type" : 15,
			"Username" : "",
			"idx" : "9"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "kerstboomLaterUit",
			"Password" : "",
			"Port" : 1,
			"SerialPort" : "1",
			"Type" : 15,
			"Username" : "",
			"idx" : "10"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 83,
			"Mode2" : 25,
			"Mode3" : 2,
			"Mode4" : 0,
			"Mode5" : 4,
			"Mode6" : 0,
			"Name" : "RFXtrx433",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "/dev/ttyUSB0",
			"Type" : 1,
			"Username" : "",
			"idx" : "11",
			"noiselvl" : 0,
			"version" : "Ext2/1025"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "isBuitenLichtAan",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "12"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "doTonyKomtThuis",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "13"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "isTonyThuis",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "14"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "doTonyGaatWeg",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "15"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "doBuitenlichtAanIndienNodig",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "16"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "doBuitentlichtUit",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "17"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "MySunIsUpBinnen",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "18"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 25,
			"Username" : "562a99a62bf2df0455cf222297eb47b4",
			"idx" : "19"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "schemeringBinnen",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "20"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "BuitenlichAanLaten",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "21"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "GarageLichtAuto",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "22"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Scene Binnen Lichten Auto",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "23"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "24"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "ping-dummies",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "25"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "GarageLichtAutoContinues",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "26"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "TonyGeoIPThuis",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "27"
			"Address" : "localhost",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 1,
			"Mode2" : 0,
			"Mode3" : 1,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "MQTT_vonderkamp",
			"Password" : "",
			"Port" : 1883,
			"SerialPort" : "1883",
			"Type" : 43,
			"Username" : "",
			"idx" : "28"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Sonoff-1",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "30"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Sonoff-2",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "31"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Sonoff-3",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "32"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "Sonoff-4",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "33"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Name" : "TonyInDeBuurt",
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "34"
			"Address" : "",
			"DataTimeout" : 0,
			"Enabled" : "true",
			"Extra" : "",
			"Mode1" : 0,
			"Mode2" : 0,
			"Mode3" : 0,
			"Mode4" : 0,
			"Mode5" : 0,
			"Mode6" : 0,
			"Password" : "",
			"Port" : 0,
			"SerialPort" : "",
			"Type" : 15,
			"Username" : "",
			"idx" : "36"
	"status" : "OK",
	"title" : "Hardware"
Posted: Wednesday 14 April 2021 23:22
by waaren
Sjoko wrote: Wednesday 14 April 2021 22:22
Result does look as expected.
Can you temporary switch on debug log for dzVents and inspect the file after a minute or a device change?
<domoticz dir>/scripts/dzVents/domoticzData.lua
All active devices in domoticz should be listed in this file.
Posted: Saturday 17 April 2021 21:12
by Sjoko
I have attached the generated file.
After activating the debug, I hit the switch 'eventTestSwich'from off to on to off to on to off.
I peeked in the file, but dunno what to look for.
Hope this helps
Posted: Saturday 17 April 2021 22:28
by waaren
Sjoko wrote: Saturday 17 April 2021 21:12 I peeked in the file, but dunno what to look for.
Hope this helps
All looks normal. No clue why an update to device 113 does not trigger the script. II tested the exact setup on 2020.2 but cannot replicate the issue. It might be worthwhile the create another virtual switch with a different name or to upgrade to 2021.1
Posted: Thursday 22 April 2021 21:26
by Sjoko
Really appreciate your help.
I figured to do an update earlier, but when I hit the 'check for update' I get 'No Update Available !...'
Posted: Thursday 22 April 2021 21:44
by waaren
Sjoko wrote: Thursday 22 April 2021 21:26 I figured to do an update earlier, but when I hit the 'check for update' I get 'No Update Available !...'
What do you see when (from the command line) you try
cd <domoticz dir>
sudo service domoticz stop
sudo mkdir -p backups
timestamp=$(date +%Y%m%d_%H%M%S)
sudo tar --exclude backups -czf backups/domoticz_backup_$timestamp.tar.gz . # make backup
sudo ./updaterelease
Posted: Tuesday 11 May 2021 13:54
by Sjoko
I found some time to try your last remark.
Updating to the latest version by commandline helped.
The event is now triggered when I hit the switch with id 113.
It looks like I can get on now with my script.
thanks a bunch
Posted: Thursday 27 May 2021 11:12
by Sjoko
Maybe I cheered a bit too early.
It appears that after some time, the event processing gets delayed.
The delay seems to increase with time, until it seems that at some point in time, nothing seems happens anymore or it is untracable what is (not) happening.
Restarting domoticz solves this, however only for a very limited amount of time.
This illustrates what is happening (from the log):
11:00:51 restart
11:01:15 switch-on
11:01:33 trigger-On
11:02:36 switch-off
11:03:22 trigger-off
11:04:14 switch-on
11:07:41 trigger-off
can you help ?
Posted: Thursday 27 May 2021 12:04
by waaren
Sjoko wrote: Thursday 27 May 2021 11:12 can you help ?
You might want to switch on debug logging. (see the wiki )
