dashticz and docker
pvklink
Domoticz version: latest b
dashticz and docker
Post by pvklink »
I like to install my rpi/domotica environment as much as possible with docker.
Is it possible to include the install of dashticz, apache/php or ngninx fully by docker compose and a dockerfile ?
i tried to make a start with the 2 files (abd more dockerfiles for the rest)
( i already have the latest domoticz, mqtt and node-red working by docker)
version: '3.6'
services:
  domoticz:
    container_name: domoticz
    build: ./services/domoticz/.
    #image: domoticz/domoticz:latest
    ports:
    - "82:8080"
    - "6144:6144"
    - "1443:1443"
    - "9000:9000"
    devices:
    - '/dev/ttyUSB0:/dev/ttyUSB0'
    volumes:
    - ./volumes/domoticz/data:/opt/domoticz/userdata
    restart: unless-stopped
    network_mode: bridge
    environment:
    - PUID=1000
    - PGID=1000
    #- LOG_PATH=/opt/domoticz/userdata/domoticz.log
  dashticz:
    container_name: dashticz
    build: ./services/dashticz/.
    ports:
    - "90:90"
    volumes:
    - ./volumes/dashticz:/opt/????
  mosquitto:
    container_name: mosquitto
    image: eclipse-mosquitto
    user: "1000"
    ports:
    - "1883:1883"
    volumes:
    - ./volumes/mosquitto/data:/mosquitto/data
    - ./volumes/mosquitto/log:/mosquitto/log
    - ./volumes/mosquitto/pwfile:/mosquitto/pwfile
    - ./volumes/mosquitto:/mosquitto/config:ro
  nodered:
    container_name: nodered
    build: ./services/nodered/.
    user: "0"
    privileged: true
    environment:
      - TZ=Etc/UTC
    ports:
      - "1880:1880"
    volumes:
      - "./volumes/nodered/data:/data"
      - "/var/run/docker.sock:/var/run/docker.sock"
      - "/var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket"
    devices:
      - "/dev/gpiomem:/dev/gpiomem"
      - "/dev/ttyAMA0:/dev/ttyAMA0"
      - "/dev/vcio:/dev/vcio"
    networks:
      - iotstack_nw
    logging:
      options:
        max-size: 5m
        max-file: "3"
networks:
  iotstack_nw:
    # external: true
    driver: bridge
    ipam:
      driver: default
      config:
        - subnet: 10.77.60.0/24
# Dockerfile for Dashticz
FROM nginx
USER root
RUN apt-get update
RUN apt-get install -y nginx --no-install-recommends
RUN apt-get install git
# Remove the default Nginx configuration file
RUN rm -v /etc/nginx/nginx.conf
# Copy a configuration file from the current directory
COPY nginx.conf /etc/nginx/
RUN rm -rf /usr/share/nginx/html/
# Append "daemon off;" to the beginning of the configuration
RUN echo "daemon off;" >> /etc/nginx/nginx.conf
# Expose ports
EXPOSE 90
# Set the default command to execute
# when creating a new container
CMD service nginx start
Jablotron connection, Ikea
Lokonli
Re: dashticz and docker
Post by Lokonli »
That should be possible.
Dashticz makes use of PHP in the webserver, so you should include that into your image.
And you need to mount a writable folder custom/ for the config files (CONFIG.js, custom.css, custom.js).
That should be sufficient.
Maybe a parameter for selecting beta or master.
The auto-install script also makes use of a Dockerimage, but in fact only for the php-webserver functionality. Dashticz itself is installed via git clone on the host directly. That makes updating Dashticz a bit easier.
pvklink
Post by pvklink »
Indeed, the auto-install script is great for installing dashticz (webserver/php).
But i started a way to install all my component as a docker via one compose file and dockerfiles per application...
Was inspired by IOTstack (beta)... :-)
i already have the casco in place (compose an dockerfile and volumes , one for dashticz...
Now figuring out the right content for the composefile and the dashtic/apache/php file.
Think i need a formal apache/php image file as a start via a dockerfile and add dashticz to it..
I could need some help, so if someone has parts of code for me, that would be appreciated. :-)
Only played for two weeks with docker and stil strugling which software/packets has to be installed
Lokonli
Post by Lokonli »
Did some experiments myself.
Create the following docker file, named 'dashticz.docker':
FROM php:7.4-apache
ARG tz="Europe/Amsterdam"
RUN printf "[PHP]\ndate.timezone = $tz\n" > /usr/local/etc/php/conf.d/tzone.ini && \
mv "$PHP_INI_DIR/php.ini-production" "$PHP_INI_DIR/php.ini"
RUN apt update && apt install git -y
RUN echo "if [ ! -f /var/www/html/version.txt ]; then git clone --depth 1 --branch beta  https://github.com/Dashticz/dashticz /var/www/html; chmod -R a+rw /var/www/html/custom; chmod -R a+rw /var/www/html/img;fi; apache2-foreground" > /usr/bin/init.sh && chmod +x /usr/bin/init.sh
CMD ["/usr/bin/init.sh"]
SHELL ["/bin/bash", "-c"]
and the following docker-compose.yaml:
version: "3.5"
services:
  dashticz:
    build:
      context: .
      dockerfile: dashticz.docker
    container_name: "dt38"
    ports:
      - "8200:80"
    restart: always
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - type: bind
        source: ./dashticz/
        target: /var/www/html/
Create a folder 'dashticz'.
Build and start the Dashticz container:
sudo docker-compose up
create your CONFIG.js in ./dashticz/custom/CONFIG.js
This way you still can hack the Dashticz sources in the dashticz tree, if needed.
I've hardly any docker experience, so I guess the scripts can be improved. Suggestions are more than welcome :)
pvklink
Post by pvklink »
Cool ! gonna test it!
I am busy with passwords with mqtt docker container and that part succeeded!
I will post all my stuff how to install a domotica environment with docker (after installing a default OS+ docker) when i got everything working.
i got domoticz, hue, zwave, rfxcom, dzvents mqtt en nodered 99% ready.All the config files and data are outside the containers and one click to update them all!
Last part is broadlink (ready, no errors but not working, is lot of python install shit in dockerfile)
and.. your setup, gonna try !!! cant wait...
pvklink
Post by pvklink »
Ok, i included your code in my configs, so i had to adjust a little bit..
Good news :-) and bad news..
a. Compose batch for all packets/apps went without errors, and all dockers started!
b. Dashticz volumes files were created...
When i start dashticz with: http://192.168.20.38/dashticz/index.html i got a no found...
When ik look at IOTstack log option i see: 192.168.1.10 (is my pc), but after GET and before /dashticz there is no IP !
dashticz | 192.168.1.10 - - [11/Apr/2021:20:35:25 +0200] "GET /dashticz/index.html HTTP/1.1" 404 492 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:87.0) Gecko/20100101 Firefox/87.0"
my compose file
version: '3.6'
services:
  domoticz:
    ports:
    - "82:8080"
    - "6144:6144"
    - "1443:1443"
    - "9000:9000"
    devices:
    volumes:
    environment:
    - PUID=1000
    - PGID=1000
  dashticz:
    #context: .
    restart: always
    ports:
      - "80:80"
    volumes:
      - type: bind
        source: ./volumes/dashticz/
  motion:
    container_name: motion
    image: motionproject/motion:latest
    #build: ./services/motion/.
    ports:
   # camera and streamports
    - "7999:7999"
    - "8081:8081"
    - "8082:8082"
    - "8083:8083"
    - "8084:8084"
    - "8085:8085"
    - "8087:8087"
    volumes:
      - "./volumes/motion/config:/usr/local/etc/motion"
      - "./volumes/motion/storage:/var/lib/motion"
    environment:
      - TZ=Etc/UTC
    networks:
      - iotstack_nw
  mosquitto:
    user: "1000"
    ports:
    - "1883:1883"
    volumes:
    - ./volumes/mosquitto/config:/mosquitto/config:ro
  nodered:
    user: "0"
    privileged: true
    environment:
      - TZ=Etc/UTC
    ports:
      - "1880:1880"
    volumes:
    devices:
    networks:
      - iotstack_nw
    logging:
      options:
        max-size: 5m
        max-file: "3"
networks:
  iotstack_nw:
    # external: true
    driver: bridge
    ipam:
      driver: default
      config:
my Dockerfile
FROM php:7.4-apache
Lokonli
Post by Lokonli »
pvklink
Post by pvklink »
Another part working on Docker!
you are great!
Tomorrow trying to get the last two
motion
and
a pain in the ass: broadlink
Lokonli
Post by Lokonli »
Did you look at motioneye already instead of motion?
Verstuurd vanaf mijn AC2003 met Tapatalk
pvklink
Post by pvklink »
:-) was another idea on the backlist...
But if motioneye also can (just like motion)
- record data from videostreams
- activate a http string when motion is enable (enable a domoticz device with that)
Then i start with motion-eye
Lokonli
Post by Lokonli »
yes. And it has a nice web interface.
pvklink
Post by pvklink »
ok, you got me...:-)
And how do you see the integration with dashticz ?
My current situation:
- Motion: grab video, storage on nas
- Dashticz show flows from cams
Lokonli
Post by Lokonli »
Install motion-eye with docker-compose:
version: "3.5"
services:
  motioneye:
    image: ccrisan/motioneye:master-amd64  # Change to ccrisan/motioneye:master-armhf for ARM chips (Pi etc.)
    ports:
      - "8901:8081"
      - "8765:8765"
    restart: always
    volumes:
      - ./etc_motioneye:/etc/motioneye
      - ./var_lib_motioneye:/var/lib/motioneye
For each camera you have to forward an additional port, starting at 8081.
At port 8765 the motioneye web interface will run.
You may have to create the two motioneye volumes in the current folder first.
You will have three links per camera.
(One for snapshot, one for MJPEG, one for embedded frame)
You have to use the url with the ports that are valid for the host, not for the container. So, with my port mapping, that will become something like:
Snapshot: http://my-ip:8765/picture/1/current/
mjpeg: http://my-ip:8901
You can use the snapshot url in a Dashticz button. (and the mjpeg stream as well).
Both will work within the camera block as well.
To trigger on motion, create a virtual switch in Domoticz.
Enable motion notification in MotionEye:
As webhook url use:
http://domoticz-ip:8080/json.htm?type=command&param=switchlight&idx=1099&switchcmd=On
You have to whitelist the MotionEye IP-address within Domoticz. MotionEye is running in a Docker container. I had to whitelist the following IP range:
172.26.*.*
in domoticz you can see the camera as well. Configure the Domoticz camera as follows:
domoticz cam.jpg (44.82 KiB) Viewed 1871 times
(replace host-ip with the correct host ip, without http, without port number)
pvklink
Post by pvklink »
Got motion also working in docker,
So now the
- motion-eye and
- broadlink
I tried motion-eye myself, but worked once and after that i could not add cams
Gonna try your setup...
pvklink
Post by pvklink »
Your motioneye docker version, works! :-) :-) :-)
Manual is great, got two cams working
Gonna play with it to integrate it in dashticz, with motion and dashticz i had to enter the username and password, i think that solved too now with motioneye...:-)
Another thing to check is how to stop the motioneye recording when a certain switch in domoticz is on or off. (example off from home, security on)
Option is to stop the motioneye docker entirely..
i have 6 apps ready ! and all data and configs outside docker on one share, easy to recover
(you did also a large and nasty part! THANKS for that @lokonli)
Last one is the most difficult, because it installs without error, but does not work... the broadlink plugin in domoticz!
I did a post for this in another part of the forum.. but i think broadlink and docker is not used much...
pvklink
Post by pvklink »
@lokonli
in case you are also playing with docker:
I have 90% working with one compose file and some of them have a dockerfile
all separate dockers with external storage and some of them can communicate with each other
- mysql
- mosquitto
- phpmyadmin
- domoticz
- dashticz
- motioneye
- motion
- nodered
so with one click install (after copied the datatree with all configparams en databases)
To do:
- plugin broadlink (ready but not working)
pvklink
Post by pvklink »
Hi, I have my cams now in motioneye (via a docker) as you advised, and that works great!
I tried to integrate these two cams in dashticz , but i have to scroll to see the second cam that is presented below the first cam...
Is there a way to show them both in one (part off a) screen and when clicking , only the one that is selected?
blocks["webcams"] =
type: "camera",
cameras:[
{title: "Tuinview",imageUrl: "http://192.168.20.32:8901",},
{title: "Straatview",imageUrl: "http://192.168.20.32:8902",},
width: 12,
height: 500,
refresh: 3,
traytimeout: 3,
slidedelay: 3,
forcerefresh: 1,
columns['video']= {blocks: ['webcams'], width: 10}
screens['tablet'] = {maxwidth: 1024,maxheight: 768}
screens['tablet'][1] = {background: 'bg1.jpg', columns: ['home1','home2']}
screens['tablet'][2] = {background: 'bg1.jpg', columns: ['sec1','sec2']}
screens['tablet'][3] = {background: 'bg1.jpg', columns: ['media1','media2']}
screens['tablet'][4] = {background: 'bg1.jpg', columns: ['irrigatie']}
screens['tablet'][5] = {background: 'bg1.jpg', columns: ['sensor1','sensor2']}
screens['tablet'][6] = {background: 'bg1.jpg', columns: ['video']}
ArnovP
Domoticz version: 4.9700
Post by ArnovP »
pvklink wrote: Monday 12 April 2021 21:47
Do you have a solution for this? I don't work with Docker, I have MotionEyeOS and Domoticz on 2 seperate Raspberries....
edit:
I found something myself: https://github.com/ccrisan/motioneyeos/issues/1778
