Domoticz on Synology NAS stopped working
Posted: Tuesday 06 April 2021 9:01
by Chris12
My domoticz has stopped working since a couple of days. I noticed that when my dashticz screen was keeping in the refresh screen.
By checking the domoticz website, that was unavailable too. In my synology I can see that the packages has stopped running.
When restarting, the package stopped right away.
The package I'm currently running for domoticz is the Jadahl version 2020.2.12731-8 (last/latest one I believe).
I think the domoticz package has stopped working after my synology has updated some other packages last week.
Not sure which ones are updated, but I remember it was python 3.8 (also running python 2.7 and 3.7 as a package), MariaDB and MyPHPadmin.
I allready removed python 3.8 to see if domoticz will start again, but unfortunatelly not.
How can I troubleshoot this issue? I have got root access to my NAS, so I can do "CLI stuff" to investigate.
But I'm not sure where to find the logfile of domoticz to actually see some more info what is causing this issue.
My DSM version (Synology OS) is 6.2.4-25556, so not on the DSM7 release yet.
I want to re-install the domoticz package if needed, but then I first have to find out where to find the domoticz database and dzvents script files for keeping all my settings and devices. Unfortunatelly the domoticz webpage is not working otherwise I could have done a backup there.
Maybe switching to a docker installed domoticz I can do as well directly, but then I want to have first of all the scripts and backup/database file.
Who can help me out, or point me towards the right direction?
Re: Domoticz on Synology NAS stopped working
Posted: Tuesday 06 April 2021 10:05
by Chris12
Some more info I have collected using winscp. I located the logfile of domoticz (and found the domoticz.db database and script files as well as the daily/hourly backups.
I found out that my domoticz stopped working on 2021-04-02 20:57:24.342, after that all my devices gives errors like ".....thread seems to have ended unexpectedly"
When examing the logfile after a start of the domoticz package I can see the following:
2021-04-06 09:31:42.406 Status: Domoticz V2020.2 (build 12731) (c)2012-2020 GizMoCuz
2021-04-06 09:31:42.406 Status: Build Hash: 7933f659d-modified, Date: 2020-12-06 10:22:02
2021-04-06 09:31:42.406 Status: Startup Path: /usr/local/domoticz/
2021-04-06 09:31:42.559 Sunrise: 07:03:00 SunSet: 20:23:00
2021-04-06 09:31:42.559 Day length: 13:20:00 Sun at south: 13:43:00
2021-04-06 09:31:42.559 Civil twilight start: 06:28:00 Civil twilight end: 20:57:00
2021-04-06 09:31:42.559 Nautical twilight start: 05:45:00 Nautical twilight end: 21:40:00
2021-04-06 09:31:42.559 Astronomical twilight start: 04:59:00 Astronomical twilight end: 22:26:00
2021-04-06 09:31:42.927 Status: PluginSystem: Started, Python version '3.8.6'.
2021-04-06 09:31:42.931 Active notification Subsystems: email (1/13)
2021-04-06 09:31:42.947 Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8084: bind: Address already in use
2021-04-06 09:31:42.947 Error: WebServer(HTTP) check if no other application is using port: 8084
2021-04-06 09:31:42.956 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 8443: bind: Address already in use
2021-04-06 09:31:42.956 Error: WebServer(SSL) check if no other application is using port: 8443
2021-04-06 09:31:42.956 Error: No servers are configured. Hence mydomoticz will not be started either (if configured)
2021-04-06 09:31:42.956 Error: Domoticz(pid:10312, tid:10312('domoticz')) received fatal signal 6 (Aborted)
2021-04-06 09:31:42.956 Error: siginfo address=0x2848, address=0x7f14355be907
2021-04-06 09:31:42.961 Error: Failed to start gdb, will use backtrace() for printing stack frame
2021-04-06 09:31:42.963 Error: #0 /usr/local/domoticz/bin/domoticz() [0x6d6890]
2021-04-06 09:31:42.963 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x27d [0x6d732d]
2021-04-06 09:31:42.963 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7f14369261c0]
2021-04-06 09:31:42.963 Error: #3 /lib/libc.so.6 : gsignal + 0x37 [0x7f14355be907]
2021-04-06 09:31:42.963 Error: #4 /lib/libc.so.6 : abort + 0x16a [0x7f14355bfcda]
2021-04-06 09:31:42.963 Error: #5 /usr/local/domoticz/bin/domoticz : __gnu_cxx::__verbose_terminate_handler() + 0xbf [0xc5fd2d]
2021-04-06 09:31:42.963 Error: #6 /usr/local/domoticz/bin/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x3 [0xc2ae30]
2021-04-06 09:31:42.963 Error: #7 /usr/local/domoticz/bin/domoticz : __cxxabiv1::__unexpected(void (*)()) + 0 [0xc2ae66]
2021-04-06 09:31:42.963 Error: #8 /usr/local/domoticz/bin/domoticz : main + 0x8ba [0x5ed31a]
2021-04-06 09:31:42.963 Error: #9 /lib/libc.so.6 : __libc_start_main + 0xf0 [0x7f14355ab030]
2021-04-06 09:31:42.963 Error: #10 /usr/local/domoticz/bin/domoticz() [0x61c042]
on the forum here I found some cli commands:
root@DS415:~# find /usr/local/etc/services.d -type f -exec grep -il '8084' { } \;
root@DS415:~# sudo servicetool --runtime-port-conflict-check --tcp --all-used-ports |grep 8084
IsConflict: true Port: 8084 Pid: 26144 State: TCP_LISTEN Protocol: tcp ProgramCommand: /usr/bin/sudo
IsConflict: true Port: 8084 Pid: 26143 State: TCP_LISTEN Protocol: tcp ProgramCommand: /usr/bin/bash
IsConflict: true Port: 8084 Pid: 26144 State: TCP_CLOSE_WAIT Protocol: tcp ProgramCommand: /usr/bin/sudo
IsConflict: true Port: 8084 Pid: 26143 State: TCP_CLOSE_WAIT Protocol: tcp ProgramCommand: /usr/bin/bash
root@CVR-DS415:~#
So it seems that the ports 8084 are claimed by another programm or something?
Posted: Tuesday 06 April 2021 10:49
by Chris12
Now that I have all data/settings, I tried to reinstall the domoticz package (first uninstalled) using domoticz_avoton-6.2_2020.2.12731-8.spk downloaded form jadahl website.
The installation goes fine, I let all setings for the ports default (8443/8084)
But after the installation domoticz still does not want to run.
Posted: Tuesday 06 April 2021 11:41
by Chris12
Problem solved! By uninstall domoticz package, after that rebooted my NAS, and re-installed the domoticz package using another port (8484 instead of 8084). After that domoticz worked fine. So next I uninstalled domoticz again, and re-installed is using the default ports. Domoticz now runs fine!
Restored my database file, manually installed some plugins and scripts. Everything seems to be OK right now.
