Adding my Westinghouse-fan to Domoticz
Posted: Tuesday 30 March 2021 21:39
by EdwinK
I've asked this before, in the projects board, but that didn't get any answer. Maybe not many people look in there. I don't know, but here I go:
I've got a Westinghouse fan with a RF controller (77841B remote) and a RFXcom.com transciever. I want to control this fan from within Domoticz but no matter what I put in the fields, I can't get it to work.
Some time ago I connected the RFXcom transciever to my Windowslaptop, and noticed this:
11-2-2021 12:36:43:241= Fan command: 08 17 04 0F 00 00 01 02 00
Packettype = Fan
subtype = Westinghouse
Sequence nbr = 15
ID = SW1=Off, SW2=Off, SW3=Off, SW4=On
Command = MED
Signal level = +10 dBm
11-2-2021 12:36:43:718= 0402010F00
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 15
response = ACK, data correct transmitted
If needed I can try and attach the RFXcom to the laptop again to test things out, but I hope that we can have the fan working before long.
Re: Adding my fan to Domoticz
Posted: Wednesday 31 March 2021 6:56
by kiddigital
Hook up your RFXcom receiver to domoticz and make sure it works.
Use the hardware settings screen of the RFXcom to activate all the needed protocols.
Make sure you have ‘add new devices’ enabled in the settings of Domoticz.
Look at the Devices tab if any new devices appear coming from the RFXcom. Use your fan remote to toggle the fan a few times.
Keep an eye on the Domoticz log the see what is happening in the background.
Good luck.
Posted: Wednesday 31 March 2021 9:49
by EdwinK
Have tried that before. Didn't help
Trying to contact RFX.com als for the protocol used.
Posted: Wednesday 31 March 2021 13:00
by EdwinK
31-3-2021 01:00:10:010= Get Status: 0D 00 00 0B 02 00 1C 00 00 00 00 00 00 00
31-3-2021 01:00:10:319= 1401000B0253192ACC270001031C04524658434F4D
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 11
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1025
Firmware Type = Ext2
Transmit power = 10dBm
Hardware version = 1.3 RFXtrx433E
Undec off
Imagintronix disabled
Byron SX enabled
RSL disabled
Lighting4 enabled
FineOffset disabled
Rubicson enabled
AE Blyss disabled
BlindsTx enabled
BlindsT0 enabled
Legrand disabled
La Crosse enabled
Hideki enabled
AD LightwaveRF disabled
Mertik disabled
Visonic disabled
ATI,Cartelectroni disabled
Oregon Scientific enabled
Meiantech disabled
HomeEasy EU disabled
AC enabled
ARC enabled
X10 enabled
HomeConfort,Fan disabled
KeeLoq disabled
31-3-2021 12:58:51:739= Fan command: 08 17 04 0A 00 00 00 03 00
Packettype = Fan
Sequence nbr = 10
ID = SW1=Off, SW2=Off, SW3=Off, SW4=Off
Command = LOW
31-3-2021 12:58:52:275= 0402010A00
Sequence nbr = 10
