Hi, I am playing with docker icm with IOTSTACK and have an old conatiner with an old domoticz version.
I like to use my current database that belongs to version 2020.2 build 13091 so i need the same docker, is that posible?
I use docker-compose within iotstack so i can define the "right"container...
searching for a beta domoticz container
pvklink
- Domoticz version: latest b
Jablotron connection, Ikea
pvklink
Re: searching for a beta domoticz container
I am a little step further.
I find out that you can add tags to specify the domoticz container, like: linuxserver/domoticz:arm32v7-2020.2-ls47
My trial was: linuxserver/domoticz:stable, so that explains why i got an error when using this old container in combination with my latest database which is used by my current non-container production environment, v2020.2 build 13091.
What can i do to use my latest database, version 2020.2 build 13091 in combination with docker, which tag do i specify or do i have to update to another beta domoticz version on my current non container system first?
Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
domoticz | 2021-03-30 07:23:50.180 Status: Build Hash: b63341bc0, Date: 2020-04-26 11:47:55
domoticz | 2021-03-30 07:23:50.180 Status: Startup Path: /usr/share/domoticz/
domoticz | 2021-03-30 07:23:50.186 Error: Database incompatible with this Domoticz version. (You cannot downgrade to an old Domoticz version!)
domoticz | terminate called without an active exception
domoticz | 2021-03-30 07:23:50.187 Error: Domoticz(pid:346, tid:346('domoticz')) received fatal signal 6 (Aborted)
domoticz | 2021-03-30 07:23:50.187 Error: siginfo address=0x15a, address=0xb6ae7bcf
domoticz | 2021-03-30 07:23:50.201 Error: Failed to start gdb, will use backtrace() for printing stack frame
domoticz |
domoticz | 2021-03-30 07:23:50.203 Error: #0 /usr/bin/domoticz() [0x2db544]
domoticz | 2021-03-30 07:23:50.203 Error: #1 /usr/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x1f8 [0x2dbf00]
domoticz | 2021-03-30 07:23:50.203 Error: #2 /lib/arm-linux-gnueabihf/libc.so.6 : + 0x2a910 [0xb6ae8910]
domoticz | 2021-03-30 07:23:50.203 Error: #3 /lib/arm-linux-gnueabihf/libc.so.6 : + 0x1abe6 [0xb6ad8be6]
domoticz | 2021-03-30 07:23:50.203 Error: #4 /lib/arm-linux-gnueabihf/libc.so.6 : gsignal + 0x79 [0xb6ae7bce]
- Domoticz version: 2026.3
The official Domoticz Docker is currently Beta only, currently on v 13133 : https://www.domoticz.com/wiki/Docker
pvklink
Thanks @waltervl !
That is the right image for me!
I played a lot with docker last days, and with the below yml file (and a nodered dockerfile) i have my first setup working (a bit).
I started with a setup with IOTstack that helps you with some files and commands...
Already have these applications working
- domoticz (with hue, broadlink, zwave and rfxcom and dzvents scripts, and databaseoutside the container)
- mqtt (with nodered and domoticz, must still test this)
- nodered, with flows outside of the container
For those who want to have a first startup, see my yml below
For others, if you can check my yml file, i think there are still a number of entries that arent needed.
Part i did some guessing was the network part, dont now if this is the right setup for letting these 3 applications talk together
and my dockerfile for nodered (to add some extra nodes)
version: '3.6'
services:
domoticz:
container_name: domoticz
image: domoticz/domoticz:latest
ports:
- "82:8080"
- "6144:6144"
- "1443:1443"
- "9000:9000"
devices:
- '/dev/ttyUSB0:/dev/ttyUSB0'
- /dev/ttyACM0:/dev/ttyACM0
volumes:
- ./volumes/domoticz/data:/opt/domoticz/userdata
restart: unless-stopped
network_mode: bridge
environment:
- PUID=1000
- PGID=1000
#- LOG_PATH=/opt/domoticz/userdata/domoticz.log
mosquitto:
container_name: mosquitto
image: eclipse-mosquitto
user: "1000"
ports:
- "1883:1883"
volumes:
- ./volumes/mosquitto/data:/mosquitto/data
- ./volumes/mosquitto/log:/mosquitto/log
- ./volumes/mosquitto/pwfile:/mosquitto/pwfile
- ./services/mosquitto:/mosquitto/config:ro
nodered:
container_name: nodered
build: ./services/nodered/.
user: "0"
privileged: true
environment:
- TZ=Etc/UTC
ports:
- "1880:1880"
volumes:
- "./volumes/nodered/data:/data"
- "/var/run/docker.sock:/var/run/docker.sock"
- "/var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket"
devices:
- "/dev/gpiomem:/dev/gpiomem"
- "/dev/ttyAMA0:/dev/ttyAMA0"
- "/dev/vcio:/dev/vcio"
networks:
- iotstack_nw
logging:
options:
max-size: 5m
max-file: "3"
networks:
iotstack_nw:
# external: true
driver: bridge
ipam:
driver: default
config:
- subnet: 10.77.60.0/24
FROM nodered/node-red:latest-12
USER root
RUN apk update && apk add --no-cache eudev-dev
USER node-red
RUN cd /usr/src/node-red && npm install --save node-red-configurable-ping node-red-dashboard node-red-node-random node-red-node-email
Good it works!
A quick question: Do you use DzVents scripts from the internal event system?
I am playing with Docker too but getting errors when saving a DzVents script.
pvklink
I only use DZvents, and my scripts are stored in the database, so thats easy when using docker and having the database outside the container, that part works great!
I got everything working except the Broadlink RM2 with kodi remote plugin.
I think this plugin is not prepared for docker.
