I have written 2 plugins for Domoticz. I am using github.com for my code.
Now I want to be able to run some tests on my plugins.
I want to start with flake8, this is a test that check if your code is with "correct" design, like 4 space indent.
The problem that I have is that flake8 is also checking that a variable is defined, which Parameters[""] isn't, because that variable is coming from Domoticz.
Anyone that have written a plugin and have a working workflow for Github?
Python Plugin how to use pytest
- Domoticz version: 2026.3
Re: Python Plugin how to use pytest
You better post this in the Python section..
I saw a merge by @cclaus about lint, perhaps he knows the answer https://github.com/domoticz/domoticz/pull/4720
There is also an issue on github mentioning the same issue (I think....).
https://github.com/domoticz/domoticz/issues/4724
Flopp
- Target OS: -
Re: Python Plugin how to use pytest[solved]
Thank you. Claus started to help me with this problem but I never understood himwaltervl wrote: Monday 22 March 2021 21:53 You better post this in the Python section..
You were right, I found the solution in his merge request, thank you for getting me to look at Claus code again
from Domoticz import Devices, Parameters
