How to restore deleted device items (zigbee2mqt)?
Posted: Sunday 21 March 2021 8:19
in an attempt to fix a zigbee2mqt device that didn't update anymore, I deleted the items (link quality, battery, voltage, switch, etc) that belonged to the device.
Subsequently, I wanted to repair the device assuming the items would be restored and the update should work again.
Unfortunately, that didn't work out that well. I have also removed the device and repaired. The device will appear again but not the related items .
How can I restore the items?
I don't know if this is related, but some of these items appeared in the log as "Python Plugin System: (Zigbee2MQTT) Device is in blacklist, skipped."
Searching for "Blacklist" and "Zigbee2mqtt" didn't help me as there is very little knowledge about the blacklist to find. I have tried to find the file related to blacklist on my Raspberry using grep on the device id but no clue so far.
Hope someone to have a solution to restore the items of the device.
Many thanks in advance.
Regards,
Wolly
Regards,
Wolly
