Aqara temperature/humidity sensor not updating
Posted: Friday 19 March 2021 19:17
I am running a zigbee network for a few months now, with zigbee2mqtt(z2m) and the domoticz domoticz-zigbee2mqtt-plugin.
All devices work excelent, except for my 2 aqara temperature/humidity sensors.
They are correctly connected to the zigbee coordinator. I see very regular updates from the sensors in the z2m logs.
I even see the update timestamp in the list in domoticz when I check in the z2m plugin list of devices.
But the connected devices in Domoticz don't show the updated temperature/humidity readings. The latest update there is from a month or so back.
So the issue seems to be at the domoticz side, either in the plugin, or domoticz itself.
No resetting and repairing has helped sofar. Does anyone have (had) similar issues?
Any suggestion to get the devices to show the updated readings correctly in Domoticz?
I found one similar issue https://github.com/Koenkk/zigbee2mqtt/issues/3603.
Any help/hint/suggestion is welcome.
Bert
Bert
