A few advice needed to improve my dash plz ;-)
Posted: Thursday 18 March 2021 13:50
by TroisSix
Hi guys,
After a long period to read the very complete tutorial and read you all, thank's a lot to the devs for their work! 8-)
I present you my board on my iPad 2, mounted on the wall with a support 3d printed ;)
MyDashticz on the wall (for forum).jpg (378.18 KiB) Viewed 3088 times
I use "Kiosk Browser for iPad" (better than a "shortcut of the dashticz page on the home page" which displays a useless bar with the battery)
But I still have a few questions that I summarized here: :)
:mrgreen: Problem solved: :mrgreen:
4. long loading of device temp: I don't know why, but I have a device temperature (only temp) which takes a lot more time than the others (temp+hum): what could be the reason? :arrow: I recreated the device in Domoticz cause it was buggy, now working.
7. hide a device? for some actions in my custom.js, I need a device to be displayed on the dashboard to be able to change another device, can we hide a device in the page? :arrow: with the 1.3.6 beta, a css class to hide the button is now working with the functions in custom.js
8. calendar: my google agenda is quite big (1.7MB) and takes a long time to be displayed (10secs), I created a script to get it every 10 minutes, and I call it with 'http://127.0.0.1/dashticz/ical/agenda_personal.ics' really faster, can i use something like 'dashticz/ical/agenda_personal.ics' instead of an url? I dont' find the good path :arrow: I confirm the path /home/pi/dashticz/ical/agenda_personal.ics is now working with the 1.3.6 beta. That may take some time for big ics files, especially when we have a lot of recurring events.
10. garbage: what is the role of the garbage, sorry I couldn't find what it is used for :p :arrow: garbage = garbage with the pickup dates
12. logs: are there some logs for Dashticz somewhere? :arrow: in DevTools, or make log
errors: I have a few errors with the dev tool, see the screenshot, what is wrong in my config? :arrow: just warnings
A few errors in DevTools of Firefox
Few errors.png (20.02 KiB) Viewed 3088 times
:?: Points to test again on my side: :oops: :?:
3. secure dashticz: how could I secure my connexion to Domoticz + Dashticz? each time I try to use the https for Domoticz (in basic-auth), it works with my firefox on my pc (thanks to cookies I presume?) but it's never working with Safari with my iPad, what is the best way to do it?
:?: Points waiting for advice: :?:
1. auto exit of browser: after a while Kiosk Browser exits alone (same behaviour with safari as a shortcut on the home page): what could be the reason? ==> the config parameter 'dashticz_refresh' with a high value (100000) isn't the trick
9. slow on iPad 2? are there some users using an iPad 2, is it also slow? or quite fast? perhaps something in my config is bad?
11. domoticz logs: when my dashticz is connected, it displays a lot of lines like "Incoming connection from 192.168.x.x" where x.x is my tablet (or my pc) How could I remove this kind of line "Incoming connection from"? see my thread viewtopic.php?f=67&t=35734&p=270385#p270385 ==> could it be possible to point another log file?
:roll: Points waiting for some checks on your side / points waiting for some improvments: :roll:
2. sleep screen: to get out of the sleep screen, if I clic anywhere on the screen, it activates the button where I clicked... How can we protect this? see my thread viewtopic.php?f=77&t=35776&p=270740#p270740
5. cameras: is it be possible to specify the dimensions width+height only in the configuration of the screen? instead of each device? see a more complete explanation viewtopic.php?f=67&t=31607&p=270548#p270548
6. cameras: is it be possible to exclude some cameras from the carousel previews?
Versions: Domoticz 2020.2 and Dashticz beta 3.7.5
See my config.js in attached file, and custom.js below (the forum refuses to attach it...)
//add custom javascript in here
// https://dashticz.readthedocs.io/en/mast ... -idx-block
// https://dashticz.readthedocs.io/en/mast ... ther-block
function afterGetDevices(){
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
/* Porte_garage avec la Lumiere_Garage_Ouvert: working with Closed/Open and Off/On */
function getStatus_PorteGarage(block){
var idx = block.idx;
var device = block.device;
if(device['Data']!="Off") { /* Porte garage ouverte = red */
$(block.mountPoint + ' > div').css('color', '#f74d4a'); /* red */
} else {
$(block.mountPoint + ' > div').css('color', 'white') /* white */
function getStatus_PorteGarageBis(block){
} else {
$(block.mountPoint + ' > div').css('color', 'white'); /* white */
/* Cams_RDC et Auto_Cameras : working */
function getStatus_Cams_RDC(block){
if(device['Data']=="Off") { /* caméras retournées = red */
} else {
function getStatus_Auto_Cameras(block){
if(device['Data']=="Off") { /* mode manuel = red */
} else {
$(block.mountPoint + ' > div').css('color', '#7bf542'); /* green */
/* Auto ouverture/fermeture des volets : working */
function getStatus_Auto_Volets(block){
if(device['Data']=="On") { /* mode auto = green */
} else {
/* Volet Room1 : working */
function getStatus_VoletRoom1Int(block){
/*var idx = block.idx;*/
/*console.log(device.Data);*/
if(parseFloat(device['Value'])==0) { /* ouvert */
Dashticz.setBlock('VoletRoom1', { textOn: 'ouvert', imageOn: 'perso/velux_ouvert.png' });
} else if( parseFloat(device['Value'])>=99 ) { /* fermé */
Dashticz.setBlock('VoletRoom1', { textOff: 'fermé', imageOff: 'perso/velux_ferme.png' });
} else if( parseFloat(device['Value'])==90 ) { /* position sieste: fermé à 90%*/
Dashticz.setBlock('VoletRoom1', { textOff: 'sieste', imageOff: 'perso/velux_p_sieste.png' });
} else if( parseFloat(device['Value'])>=50 ) { /* partiellement fermé */
Dashticz.setBlock('VoletRoom1', { textOff: 'p.fermé ' + device['Value'] + '%', imageOff: 'perso/velux_p_ferme.png' });
} else if( parseFloat(device['Value'])<50 ) { /* partiellement ouvert */
Dashticz.setBlock('VoletRoom1', { textOn: 'p.ouvert ' + device['Value'] + '%', imageOn: 'perso/velux_p_ouvert.png' });
Code working:
Dashticz.setBlock('VoletRoom1', {title: 'Room1'});
To test:
$('div[data-id="mytitle"] .dt_title').html('level 0')
Thank you for those who will be able to help me for one or several points ;-)
BR
Re: A few advice needed to improve my dash plz ;-)
Posted: Thursday 18 March 2021 18:44
by Lokonli
Thanks for the questions! Useful for others as well. I'll try to answer them.
TroisSix wrote: Thursday 18 March 2021 13:50 But I still have a few questions that I summarized here: :)
Maybe it's related to the Dashticz refresh. Can you set the config parameter 'dashticz_refresh' to a high value (100000) and retest?
There were some issues in the past with this as well. I'll check.
Outside your LAN you should use VPN.
Inside your LAN it's not really an issue.
Is it a normal block, a dial or a graph?
How is the block defined?
I started to collect the camera related remarks. They probably will be addressed in the next update.
With the new device hook function you probably don't have to add unused devices anymore. See:
https://dashticz.readthedocs.io/en/beta ... devicehook
Please start a new topic if you need some help on this.
You can hide a block by adding the following to custom.css:
div[data-id='myblock'] {
  display: none
You can load a local ics file as well. (there was a bug that a fixed today, I think).
Probably most easy to use an absolute path.
If you used manual install (no docker) then that probably is something like:
If you use the automatic install, it's a bit different. You are working inside a docker container. The dashticz folder is mounted on /var/www/html
So, in case of automatic install the path probably is:
/var/www/html/dashticz/ical/agenda_personal.ics
Mainly Dutch, Belgium, and one German city.
Trash collection dates.
If you also have a trash collection calendar for your town, I can try to add it as well
In DevTools :)
I started to add some debug functionality (preliminary). Click on the Dashticz title for an example.
If you used autoinstall you can display the Dashticz server logs with the following command:
make logs
Not really an issue. Your system tries to interprete the .tpl files as .xml files, but that doesn't work. You have this on firefox?
BR
Posted: Thursday 18 March 2021 19:17
by TroisSix
@Lokonli So great, thanks a lot for having taken all my points, I really appreciate your work and the time to help / improve 8-)
I will have to make a few modifications now lol
Answer to your questions:
3. https: yes I have an issue in my LAN, only with Safari
4. long loading of a device temp: yes it is a simple block:
blocks['Temp_Mezza'] = { idx: XXX, title: 'Mezza', image : 'perso/billard-icon.png', last_update: false, width: 4 }
7. hide: I already did that, but the custom.js cannot consider my block if it is hidden :roll:
9. ipad 2 slow? perhaps you missed this one? :P
10. garbage I will try to read some documentation about trash collection calendar cause I'm not sure what this is about: some local news of a town?
11. domoticz logs: perhaps you missed that one too :P
Thank you so much ;)
Posted: Thursday 18 March 2021 19:59
by HansieNL
10. garbage This shows icon and date for trash pickup dates.
4. For your temp device, have you tried to create a minimal Dashticz config.js with only that block to see if loading is faster?
Posted: Thursday 18 March 2021 20:39
by TroisSix
@HansieNL,
I get it now with your explanation, it's simple: garbage is garbage... I was thinking about a garbage collector a bit more complicated :lol:
Ok, I'll try for the 4.
Posted: Friday 19 March 2021 11:40
by TroisSix
@HansieNL @Lokonli
I updated to the 3.7.6 beta, and it resolved some points ;-)
Points resolved:
4. long loading of device temp: I tried a new config with only 2 devices temp, and it was still slow. I recreated this buggy temp device, then it was as fast as the others, weird it was buggy between domoticz and dashticz?
7. hide a device: with the 1.3.6 beta, a css class to hide the button is now working with the functions in custom.js
8. calendar: I confirm the path /home/pi/dashticz/ical/agenda_personal.ics is now working with the 1.3.6 beta. But on my side it still takes a few sec to be displayed :(
1. auto exit of browser: i put it to 100000
3. secure dashticz
9. slow on iPad 2?
11. domoticz logs: how can I filter the displayed logs?
2. sleep screen
5. 6. cameras: if you want more details, either see my thread about it, or I can explain again
PS: first post updated.
Posted: Friday 19 March 2021 12:56
by Lokonli
TroisSix wrote: Friday 19 March 2021 11:40 @HansieNL @Lokonli
Points resolved:
3. secure dashticz
9. slow on iPad 2?
2. sleep screen
4:
Probably your temp device was not used in Domoticz, or no favorite, then Dashticz doesn't receive the device info at startup, but only after a first update.
8. Dashticz has to filter all you calendar items. That may take some time for big ics files, especially when you have a lot of recurring events.
11. Not yet.
Posted: Friday 19 March 2021 19:12
by TroisSix
Ok.
Just tested this one:
1. auto exit of browser: i put it to 100000, but it still exit either from "afari as an app" or via "Kiosk Browser for iPad" :shock:
Other point:
11. For the logs: could it be possible to be able to select the log file we want? as an improvement? :P
Posted: Saturday 10 April 2021 14:40
by TroisSix
Hi Sander, or the team of devs,
Would you have some time to help me for the last points waiting for an help plz ? :-)
- touch on sleep screen activates the button behind
- auto exit of browser (ipad 2)
- secure my domoticz (https not working on my ipad)
- could be useful to filter the logs displayed
Dashticz is really powerful, I like it :)
Posted: Thursday 15 April 2021 18:27
by Lokonli
TroisSix wrote: Saturday 10 April 2021 14:40 Hi Sander, or the team of devs,
1) For the first point there were some fixes in the past. I'll double check what happened with those. You see this only on iPad?
2) I can't reproduce the auto exit on iPad 2. My iPad 2 is stable. I'll try to add more logging.
3) Security
Advice: Outside your LAN use VPN
What do you try to secure? Can you describe your system setup?
4) You mean this log?:
https://dashticz.readthedocs.io/en/mast ... czlog.html
You would like to filter on any text in the message, like you can do in the Domoticz log?
Posted: Thursday 15 April 2021 23:17
by Lokonli
I can reproduce the first issue. Indeed, click events in the standby screen also land in the main screen. Only in full screen mode, only on iOs,
I'll look for a fix.
Posted: Saturday 17 April 2021 9:16
by Lokonli
This has been fixed in latest beta. Can you test?
Posted: Saturday 17 April 2021 14:13
by TroisSix
Great, I will update to the latest beta 3.8.1 and keep you informed ;)
For the other points:
2. which app are you using for a fullscreen on your ipad 2?
3. just wanted to secure my access :)
4. yes, I would like to have some filter to include or exclude (example of exlusion: if a line contains a term like "user triggered", I don't want it to be displayed), do you think it could be possible? Could be useful to display different logs in different blocks: block with errors, block for specific devies, ... :)
Posted: Saturday 17 April 2021 15:07
by Lokonli
2.
In Safari I just send the link to the start screen (via the 'upload' button, then '+' to add to start screen)
4)
It is possible, but for me not very important. Feel free to clone the Dashticz repository, make the changes, and create a PR. If needed. I can help with that. It's fun :)
Posted: Saturday 17 April 2021 15:31
by TroisSix
2. I get it, but I don't want to view the bar with the battery on the top, so the shortcut as an app, isn't using the whole screen. But I remember I also got the bugs with your method. Which version of IOS do you have?
4. Let's get a try, you can pm me or send an email, and I'll look for it ;-)
