Error dzVents Daily at Midnight
Posted: Thursday 18 March 2021 9:37
by rwblinn
noticed that the Domoticz log gives daily at midnight following error related to dzVents. During the day no errors. Not sure when this started.
After the errors, dzVents runs OK?
After reboot or restarting Domoticz, the log shows no errors.
Checked: disc space = OK (25%), memory = OK (26%)
Running: Domoticz 2020.2 stable on a Raspberry Pi 3B+ with Raspberry OS 5.10.17-v7+ #1403.
Any idea what the cause could be?
2021-03-17 00:00:00.629 Error: dzVents: Error: (3.0.2) module 'global_data' not found:
2021-03-17 00:00:00.629 no field package.preload['global_data']
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/dzVents/runtime/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/dzVents/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/scripts/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/../lua/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/data/global_data.lua'
2021-03-17 00:00:00.629 no file '/home/pi/domoticz/scripts/dzVents/modules/global_data.lua'
2021-03-17 00:00:00.629 no file '/usr/local/share/lua/5.3/global_data.lua'
2021-03-17 00:00:00.629 no file '/usr/local/share/lua/5.3/global_data/init.lua'
2021-03-17 00:00:00.629 no file '/usr/local/lib/lua/5.3/global_data.lua'
2021-03-17 00:00:00.629 no file '/usr/local/lib/lua/5.3/global_data/init.lua'
2021-03-17 00:00:00.629 no file '/usr/share/lua/5.3/global_data.lua'
2021-03-17 00:00:00.629 no file '/usr/share/lua/5.3/global_data/init.lua'
2021-03-17 00:00:00.629 no file './global_data.lua'
2021-03-17 00:00:00.629 no file './global_data/init.lua'
2021-03-17 00:00:00.629 no file '/usr/local/lib/lua/5.3/global_data.so'
2021-03-17 00:00:00.629 no file '/usr/lib/arm-linux-gnueabihf/lua/5.3/global_data.so'
2021-03-17 00:00:00.629 no file '/usr/lib/lua/5.3/global_data.so'
2021-03-17 00:00:00.629 no file '/usr/local/lib/lua/5.3/loadall.so'
2021-03-17 00:00:00.629 no file './global_data.so'
2021-03-17 00:00:00.630 Error: dzVents: Error: (3.0.2) module 'battery_check_domoticz' not found:
2021-03-17 00:00:00.630 no field package.preload['battery_check_domoticz']
2021-03-17 00:00:00.630 no file '/home/pi/domoticz/scripts/dzVents/battery_check_domoticz.lua'
and so on for every script...
The Domoticz log (snippet) when restarting Domoticz = all working fine:
2021-03-18 09:32:36.105 Status: EventSystem: reset all events...
2021-03-18 09:32:36.109 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/electric_usage_house.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/daylight_info.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/global_data.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/postbox_notifier.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/stock_quotes.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/homematic_dutycycle_monitor.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dwd_uvi.lua
2021-03-18 09:32:36.110 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dwd_pollen.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/garage_door_check.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/keydates_update.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/homematic_thermostat_setpoint.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/homematic_thermostat_sync.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/homematic_thermostat_onoff.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/somfy_control.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/hue_control.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/river_elbe_level.lua
2021-03-18 09:32:36.111 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/bme280_devices_update.lua
2021-03-18 09:32:36.112 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/remote_control.lua
2021-03-18 09:32:36.112 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/battery_check_domoticz.lua
2021-03-18 09:32:36.112 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/battery_check_homematic.lua
2021-03-18 09:32:36.112 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/covid_info.lua
2021-03-18 09:32:36.112 Status: EventSystem: reset all device statuses...
2021-03-18 09:32:36.260 Status: Python EventSystem: Initalizing event module.
2021-03-18 09:32:36.260 Status: EventSystem: Started
2021-03-18 09:32:36.260 Status: EventSystem: Queue thread started...
2021-03-18 09:32:36.425 Status: PluginSystem: Entering work loop.
Re: Error dzVents Daily at Midnight
Posted: Thursday 18 March 2021 12:00
by waaren
rwblinn wrote: Thursday 18 March 2021 9:37 noticed that the Domoticz log gives daily at midnight following error related to dzVents. During the day no errors. Not sure when this started.
Thx. for reporting.
This is probably because of a race condition. At midnight all dzVents scripts (including global_data.lua ) are refreshed on the filesystem.
All files in <domoticz dir>/scripts/dzVents/generated_scripts with a lua extension are deleted and recreated from the domoticz database.
This process normally takes less then 0.1 seconds but it can happen that the global_data.lua is not yet recreated when it is needed by one of the other scripts.
I need to do some checks to see under what circumstances it produces this error. Might take some time because in my region we only have one midnight every 24 hours :)
Do you have all of your dzVents scripts in the Events page under 'My automation scripts' or do you also use the <domoticz dir>/scripts/dzVents/scripts folder?
For test:
could you please move your global_data.lua from <domoticz dir>/scripts/dzVents/generated_scripts to <domoticz dir>/scripts/dzVents/scripts
(the files in the latter directory are processed in the same way by dzVents but will not be refreshed at midnight)
Posted: Thursday 18 March 2021 12:21
by rwblinn
thanks for picking up.
Regarding your advice:
For test: could you please move your global_data.lua from <domoticz dir>/scripts/dzVents/generated_scripts to <domoticz dir>/scripts/dzVents/scripts
FIRST ACTION TAKEN
* Stopped Domoticz
* Moved global_data
* Checked = No global_data in folder generated_scripts
* Restarted Domoticz
* A new global_data file was created in generated scripts folder
* Domoticz log error: dzVents: Error: (3.0.2) There is already an external script with the name "global_data.lua". Please rename in the internal script.
NEXT ACTION:
* Did not stop Domoticz, let it run.
* Moved global_data again > No error message.
Will let it run and see what happens at midnight.
Do not have any other scripts in the scripts folder except a JSON file with data used by one of the dzVents events.
Posted: Friday 19 March 2021 10:56
by rwblinn
Update
The test failed because (as expected) all dzVents scripts got rebuild at midnight including global_data.
Since midnight two global_data scripts resulting in the error - deleted the one in the scripts folder to get rid of the error messages.
To note which might help seeking for a solution:
Some of the dzVents events are custom events triggered (rather) regular by external systems, like HomematicIP CCU.
If the state of a HomematicIP device changes, the Homematic scripts sends a HTTP API/JSON request (CustomEvent) to Domoticz.
Posted: Friday 19 March 2021 11:29
by waaren
rwblinn wrote: Friday 19 March 2021 10:56 The test failed because (as expected) all dzVents scripts got rebuild at midnight including global_data.
Thx. for the update.
If you set the state of global_data in the internal_event editor to 'Off' it will not be rebuild at midnight or at a domoticz (re)start.
I am testing a patch using an extra check for the situation where/if the problem persists even with the external global_data.lua
If the patch does pass all tests successfully, I will probably implement it in one of the next builds.
Posted: Friday 19 March 2021 11:51
by rwblinn
Thx for clarification and action taken.
Have moved global_data and set to OFF. Lets see what happens at 0000.
Posted: Saturday 20 March 2021 13:30
by rwblinn
Just to confirm no issues at 0000 having global_data in the scripts instead generated scripts folder.
Posted: Saturday 20 March 2021 14:39
by Antori91
waaren wrote: Thursday 18 March 2021 12:00
Hello Waaren,
I've already posted here about this. Still curious to know what motivates the Domoticz technical team to implement this feature? Generating the file when saving the DzVents script from the internal editor seems to be enough. Why a refresh process every night?
Posted: Saturday 20 March 2021 14:41
by waaren
rwblinn wrote: Saturday 20 March 2021 13:30 Just to confirm no issues at 0000 having global_data in the scripts instead generated scripts folder.
Thx for the feedback!
To allow the global_data.lua to live in the generated_scripts folder (and more important stored in the database), I created a patch to retry the load of a module when it is not yet written to the file system.
I tested the patch on my systems and will merge it into a next build but if you are interested, I can also post a patched version for EventHelper.lua for your version.
Posted: Saturday 20 March 2021 14:57
by waaren
Antori91 wrote: Saturday 20 March 2021 14:39 I've already posted here about this. Still curious to know what motivates the Domoticz technical team to implement this feature? Generating the file when saving the DzVents script from the internal editor seems to be enough. Why a refresh process every night?
It seems my previous answer for this was not complete enough.
"It's part of the refresh routine. It is also done at every domoticz start and on every activate, delete, deactivate, change and create of a script when done from the internal editor. The process delete all files in the generated script dir and rebuild them."
The idea behind this is that when domoticz starts it only is aware of the current database. It does not have any knowledge about previous situations. It can be started with an empty database or with a restored database from a day, a week or a year ago or one from a different system.
Scripts created by another version of database, left behind in the generated_scripts folder, could then potential be very harmful for the current database. So that's why the refresh routine is designed. In an ideal world it would not be needed to activate this refresh routine at midnight but it is possible to modify the contents of the generated_scripts folder and/or the database directly and not via the event editor and for these type of situations the refresh routine is also executed once a day (at midnight).
Hope this clarifies.
Posted: Saturday 20 March 2021 15:08
by Antori91
Thanks Waaren. I understand now.
Indeed, if for example you restore a database with scripts stored in it, it is nice (and safe) that Domoticz generates all the files for you.
Posted: Sunday 21 March 2021 9:12
by rwblinn
waaren wrote: Saturday 20 March 2021 14:41 I tested the patch on my systems and will merge it into a next build but if you are interested, I can also post a patched version for EventHelper.lua for your version.
Thx for fixing and please post the patched version EventHelper.lua.
Appreciated.
Re: Error dzVents Daily at Midnight  [Solved]
Posted: Sunday 21 March 2021 21:05
by waaren
rwblinn wrote: Sunday 21 March 2021 9:12 please post the patched version EventHelper.lua.
Find below the patched <domoticz dir>/dzVents/runtime/EventHelpers.lua
Only when on for V2020.2 !! (aka stable)
local _ = require('lodash')
local GLOBAL_DATA_MODULE = 'global_data'
local utils = require('Utils')
local persistence = require('persistence')
local HTTPResponse = require('HTTPResponse')
local Timer = require('Timer')
local Security = require('Security')
local SystemEvent = require('SystemEvent')
local CustomEvent = require('CustomEvent')
local HistoricalStorage = require('HistoricalStorage')
local function EventHelpers(domoticz, mainMethod)
	local globalsDefinition
	local currentPath = globalvariables['script_path']
	if (_G.TESTMODE) then
		-- make sure you run the tests from the tests folder !!!!
		_G.scriptsFolderPath = currentPath .. 'scripts'
		package.path =
			currentPath .. 'scripts/?.lua;' ..
			currentPath .. 'data/?.lua;' ..
			currentPath .. '/../?.lua;' ..
			package.path
	local webRoot = globalvariables['domoticz_webroot']
	local _url = 'http://127.0.0.1:' .. (tostring(globalvariables['domoticz_listening_port']) or "8080")
	local settings = {
		['Log level'] = tonumber(globalvariables['dzVents_log_level']) or 1,
		['Domoticz url'] = _url,
		url = url,
		webRoot = tostring(webRoot),
		serverPort = globalvariables['domoticz_listening_port'] or '8080',
		dzVentsVersion = globalvariables.dzVents_version,
		domoticzVersion = globalvariables.domoticz_version,
		location = {
			name = utils.urlDecode(globalvariables['domoticz_title'] or "Domoticz"),
			latitude = globalvariables.latitude or 0,
			longitude = globalvariables.longitude or 0,
	if (webRoot ~= '' and webRoot ~= nil) then
		settings['Domoticz url'] = settings['Domoticz url'] .. '/' .. tostring(webRoot)
	_G.logLevel = settings['Log level']
	if (domoticz == nil) then
		local Domoticz = require('Domoticz')
		domoticz = Domoticz(settings)
	local self = {
		['utils'] = utils, -- convenient for testing and stubbing
		['domoticz'] = domoticz,
		['settings'] = settings,
		self.scriptsFolderPath = scriptsFolderPath
		self.dataFolderPath = _G.dataFolderPath
		function self._getUtilsInstance()
			return utils
	function self.getStorageContext(storageDef, module)
		local storageContext = {}
		local fileStorage, value, ok
		--require('lodash').print(1, storageDef)
		if (storageDef ~= nil) then
			-- load the datafile for this module
			ok, fileStorage = pcall(require, module)
			if type(fileStorage) == boolean then
				utils.log('Problem with module: ' .. module, utils.LOG_ERROR)
			package.loaded[module] = nil -- no caching
			if (ok) then
				-- only transfer data as defined in storageDef
				for _var, _def in pairs(storageDef) do
					local var, def
					if (type(_var) == 'number' and type(_def) == 'string') then
						var = _def
						def = {}
						var = _var
						def = _def
					if (def.history ~= nil and def.history == true) then
						storageContext[var] = HistoricalStorage(fileStorage[var], def.maxItems, def.maxHours, def.maxMinutes, def.getValue)
						if (fileStorage[var] == nil) then
							-- obviously this is a var that was added later
							-- initialize it
							storageContext[var] = def.initial
							storageContext[var] = fileStorage[var]
					local var, def
						var = _def
						def = {}
						var = _var
						def = _def
					--require('lodash').print('>', var, def, '<')
						-- no initial value, just an empty history
						if (def.initial ~= nil) then
							storageContext[var] = nil
		storageContext.initialize = function(varName)
			if (storageContext[varName] ~= nil and storageDef[varName].history == nil ) then
				storageContext[varName] = storageDef[varName].initial
		fileStorage = nil
		return storageContext
	function self.writeStorageContext(storageDef, dataFilePath, dataFileModuleName, storageContext)
		local data = {}
			-- transfer only stuf as described in storageDef
			for var, def in pairs(storageDef) do
				if (type(var) == 'number' and type(def) == 'string') then
					data[def] = storageContext[def]
						data[var] = storageContext[var]._getForStorage()
			local ok, err = pcall(persistence.store, dataFilePath, data)
			-- make sure there is no cache for this 'data' module
			package.loaded[dataFileModuleName] = nil
			if (not ok) then
				utils.log('There was a problem writing the storage values', utils.LOG_ERROR)
				utils.log(err, utils.LOG_ERROR)
	local function getEventInfo(eventHandler, mode)
		local res = {}
		res.type = mode
		res.scriptName = eventHandler.name
		if (eventHandler.trigger ~= nil) then
			res.trigger = eventHandler.trigger
		return res
	local function deprecationWarning(moduleName, key, value, quoted)
		local msg
		if quoted then
			msg = 'dzVents deprecation warning: please use "on = { [\'' .. key .. '\'] = { \'' .. tostring(value) .. '\' } }". Module: ' .. moduleName
			msg = 'dzVents deprecation warning: please use "on = { [\'' .. key .. '\'] = { ' .. tostring(value) .. ' } }". Module: ' .. moduleName
		utils.log(msg, utils.LOG_ERROR)
	function self.callEventHandler(eventHandler, subject)
		local useStorage = false
		if (eventHandler['execute'] ~= nil) then
			-- Prepare storage
			if (eventHandler.data ~= nil) then
				useStorage = true
				local localStorageContext = self.getStorageContext(eventHandler.data, eventHandler.dataFileName)
				if (localStorageContext) then
					self.domoticz.data = localStorageContext
					self.domoticz.data = {}
			if (globalsDefinition) then
				local globalStorageContext = self.getStorageContext(globalsDefinition, '__data_global_data')
				self.domoticz.globalData = globalStorageContext
				self.domoticz.globalData = {}
			-- Run script
			local ok, res, info
			local baseType = subject and subject.baseType or ''
			if (baseType == domoticz.BASETYPE_DEVICE) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_DEVICE)
				ok, res = pcall(eventHandler['execute'], self.domoticz, subject, info)
			elseif (baseType == domoticz.BASETYPE_VARIABLE) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_VARIABLE)
			elseif (baseType == domoticz.BASETYPE_SECURITY) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_SECURITY)
				local security = Security(self.domoticz, info.trigger)
				ok, res = pcall(eventHandler['execute'], self.domoticz, security, info)
			elseif (baseType == domoticz.BASETYPE_SCENE or baseType == domoticz.BASETYPE_GROUP) then
				if (baseType == domoticz.BASETYPE_SCENE) then
					info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_SCENE)
					info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_GROUP)
			elseif (baseType == domoticz.BASETYPE_HTTP_RESPONSE) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_HTTPRESPONSE)
				info.trigger = subject.callback
				local response = HTTPResponse(self.domoticz, subject)
				ok, res = pcall(eventHandler['execute'], self.domoticz, response, info)
			elseif (baseType == domoticz.BASETYPE_SYSTEM_EVENT) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_DOMOTICZ)
				info.trigger = subject.type
				local dze = SystemEvent(self.domoticz, subject)
				ok, res = pcall(eventHandler['execute'], self.domoticz, dze, info)
			elseif (baseType == domoticz.BASETYPE_CUSTOM_EVENT) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_CUSTOM)
				local custom = CustomEvent(self.domoticz, subject)
				ok, res = pcall(eventHandler['execute'], self.domoticz, custom, info)
				-- timer
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_TIMER)
				local timer = Timer(self.domoticz, info.trigger)
				ok, res = pcall(eventHandler['execute'], self.domoticz, timer, info)
			if (ok) then
				-- Persist storage
				if (useStorage) then
					self.writeStorageContext(eventHandler.data,
						eventHandler.dataFilePath,
						eventHandler.dataFileName,
						self.domoticz.data)
					self.writeStorageContext(globalsDefinition,
						_G.dataFolderPath .. '/__data_global_data.lua',
						_G.dataFolderPath .. '/__data_global_data',
						self.domoticz.globalData)
				self.domoticz.data = nil
				self.domoticz.globalData = nil
				return res
				utils.log('An error occurred when calling event handler ' .. eventHandler.name, utils.LOG_ERROR)
				utils.log(res, utils.LOG_ERROR) -- error info
			utils.log('No "execute" function found in event handler ' .. eventHandler, utils.LOG_ERROR)
	function self.scandir(directory, type)
		local pos, len
		local i, t, popen = 0, {}, io.popen
		local sep = string.sub(package.config, 1, 1)
		local cmd
		local namesLookup = {}
		if (directory == nil) then
			return {}
		if (sep == '/') then
			cmd = 'ls -a "' .. directory .. '"'
			-- assume windows for now
			cmd = 'dir "' .. directory .. '" /B'
		t = {}
		local pfile = popen(cmd)
		for filename in pfile:lines() do
			pos, len = string.find(filename, '.lua', 1, true)
			if (pos and pos > 0 and filename:sub(1, 1) ~= '.' and len == string.len(filename)) then
				local name = string.sub(filename, 1, pos - 1)
				table.insert(t, {
					['type'] = type,
					['name'] = name
				namesLookup[name] = true -- for quick lookup for filename
				--utils.log('Found module in ' .. directory .. ' folder: ' .. t[#t].name, utils.LOG_DEBUG)
		pfile:close()
		return t, namesLookup
	function self.processTimeRuleFunction(fn)
		local ok, res = pcall(fn, self.domoticz)
		if (not ok) then
			utils.log('Error executing custom timer function.', utils.LOG_ERROR)
				print(res)
			return false
		return res
	function self.handleEvents(events, subject)
		local originalLogLevel = _G.logLevel -- a script can override the level
		local function restoreLogging()
			_G.logLevel = originalLogLevel
			_G.logMarker = nil
		if (type(events) ~= 'table') then
			restoreLogging()
			return
		for eventIdx, eventHandler in pairs(events) do
			if (eventHandler.logging) then
				if (eventHandler.logging.level ~= nil) then
					_G.logLevel = eventHandler.logging.level
				if (eventHandler.logging.marker ~= nil) then
					_G.logMarker = eventHandler.logging.marker
			local moduleLabel
			local moduleLabelInfo = ''
			local triggerInfo
			local scriptType = eventHandler.type == 'external' and 'external script: ' or 'internal script: '
			if (eventHandler.type == 'external') then
				moduleLabel = eventHandler.name .. '.lua'
				moduleLabel = eventHandler.name .. ''
			domoticz.moduleLabel = eventHandler.name:gsub('%.lua','') -- used in dynamic logmarker
				moduleLabelInfo = ' Device: "' .. subject.name .. ' (' .. subject.hardwareName .. ')", Index: ' .. tostring(subject.id)
				moduleLabelInfo = ' Variable: "' .. subject.name .. '" Index: ' .. tostring(subject.id)
				moduleLabelInfo = ' Security: "' .. subject.name .. '"'
				moduleLabelInfo = (subject.baseType == 'scene' and ' Scene' or ' Group') .. ': "' .. subject.name .. '", Index: ' .. tostring(subject.id)
				moduleLabelInfo = ' HTTPResponse: "' .. subject.callback .. '"'
				moduleLabelInfo = ' Domoticz event: "' .. subject.name .. '"'
				moduleLabelInfo = ' Custom event: "' .. subject.name .. '"'
			triggerInfo = eventHandler.trigger and ( ', trigger: "' .. eventHandler.trigger .. '"' ) or ''
			local clockTimeStampAtStart = os.clock()
			local timeStampAtStart = os.time()
			utils.log('------ Start ' .. scriptType .. moduleLabel ..':' .. moduleLabelInfo .. triggerInfo, utils.LOG_MODULE_EXEC_INFO)
			local clockTimeSpend = os.clock() - clockTimeStampAtStart
			local realTimeSpend = os.time() - timeStampAtStart
			if realTimeSpend > 9 or clockTimeSpend > 7 then
				utils.log('------ Finished ' .. moduleLabel .. ' after >' .. realTimeSpend .. ' seconds. (using '.. tostring(clockTimeSpend):sub(1,5) .. ' seconds CPU time !)' , utils.LOG_ERROR)
			elseif realTimeSpend > 6 or clockTimeSpend > 5 then
				utils.log('------ Finished ' .. moduleLabel .. ' after >' .. realTimeSpend .. ' seconds. (using '.. tostring(clockTimeSpend):sub(1,5) .. ' seconds CPU time !)' , utils.LOG_FORCE)
				utils.log('------ Finished ' .. moduleLabel , utils.LOG_MODULE_EXEC_INFO)
			restoreLogging()
	function self.processTimeRules(timeRules, testTime)
		-- accepts a table of timeDefs, if one of them matches with the
		-- current time, then it returns true
		-- otherwise it returns false
		local now
		if (testTime == nil) then
			now = self.domoticz.time
			now = testTime
		for i, _rule in pairs(timeRules) do
			if (type(_rule) == 'function') then
				return self.processTimeRuleFunction(_rule), 'function'
			local rule = string.lower(_rule)
			if (now.matchesRule(rule)) then
				return true, rule
		return false
	function self.checkSecurity(securityDefs, security)
		for i, def in pairs(securityDefs) do
			if (def == security) then
				return true, def
		return false
	local function addBindingEvent(bindings, event, module)
		if (bindings[event] == nil) then
			bindings[event] = {}
		table.insert(bindings[event], module)
	local function loadEventScripts()
		local scripts = {}
		local errModules = {}
		local internalScripts
		local requireTimeout, ok, diskScripts, externalNames, moduleName, i, event, j, err
		local modules = {}
		local scripts = {}
		ok, diskScripts, externalNames = pcall(self.scandir, _G.scriptsFolderPath, 'external')
		if (not ok) then
			utils.log(diskScripts, utils.LOG_ERROR)
			modules = diskScripts
		ok = true
		ok, internalScripts = pcall(self.scandir, _G.generatedScriptsFolderPath, 'internal')
		if (not ok) then
			utils.log(internalScripts, utils.LOG_ERROR)
			for i, internal in pairs(internalScripts) do
				if (externalNames[internal.name]) then
					-- oops already there, skipping
					utils.log('There is already an external script with the name "' .. internal.name .. '.lua". Please rename in the internal script.', utils.LOG_ERROR)
					table.insert(modules, internal)
		-- extract global_data module and make sure it is the first in the list
		-- because then peeps can create some globals available everywhere before the other modules load
		local globalIx
		for i, moduleInfo in pairs(modules) do
			if (moduleInfo.name == GLOBAL_DATA_MODULE) then
				globalIx = i
				break
		if (globalIx ~= nil and globalIx > 1) then
			local globalModule = modules[globalIx]
			table.remove(modules, globalIx)
			table.insert(modules, 1, globalModule)
		function self.wait(time)
			local isWindows = string.sub(package.config, 1, 1) ~= '/'
			local delayCommand = ( isWindows and 'timeout /T 1' ) or 'sleep 1'
			local duration = os.time() + ( time or 1 )
			while os.time() < duration do os.execute(delayCommand) end
		function self.tryRequire(moduleName, requireTimeout, location)
			local ok = true
			ok, module = pcall(require, moduleName)
			if ( ok and module ) or requireTimeout < 1 or not(tostring(module):match('^module')) then
				return ok, module, requireTimeout
			elseif not(ok) then
				while not(ok) and requireTimeout > 0 do
					utils.log('Loading of ' .. location .. ' script "'.. moduleName .. '.lua" failed. Retrying in a second.', utils.LOG_FORCE)
					if not(_G.TESTMODE) then self.wait(1) end
					if not(ok) then
						requireTimeout = requireTimeout - 1
		for i, moduleInfo in ipairs(modules) do
			local module, skip
			local moduleName = moduleInfo.name
			local logScript = (moduleInfo.type == 'external' and 'Script ' or 'Internal script ')
			_G.domoticz = {
				['LOG_INFO'] = utils.LOG_INFO,
				['LOG_MODULE_EXEC_INFO'] = utils.LOG_MODULE_EXEC_INFO,
				['LOG_DEBUG'] = utils.LOG_DEBUG,
				['LOG_ERROR'] = utils.LOG_ERROR,
				['SECURITY_DISARMED'] = self.domoticz.SECURITY_DISARMED,
				['SECURITY_ARMEDAWAY'] = self.domoticz.SECURITY_ARMEDAWAY,
				['SECURITY_ARMEDHOME'] = self.domoticz.SECURITY_ARMEDHOME,
			ok = true
			ok, module, requireTimeout = self.tryRequire(moduleName, ( requireTimeout or 3 ), moduleInfo.type )
			_G.domoticz = nil
			if (ok) then
				if (moduleName == GLOBAL_DATA_MODULE) then
					if (module.data ~= nil) then
						globalsDefinition = module.data
							self.globalsDefinition = globalsDefinition
					if (module.helpers ~= nil) then
						self.domoticz.helpers = module.helpers
					if (type(module) == 'table') then
						skip = false
						if (module.active ~= nil) then
							local active = false
							if (type(module.active) == 'function') then
								active = module.active(self.domoticz)
							if (not active) then
								skip = true
						if (not skip) then
							if (module.on ~= nil and module['execute'] ~= nil) then
								module.name = moduleName
								module.type = moduleInfo.type
								module.dataFileName = '__data_' .. moduleName
								module.dataFilePath = _G.dataFolderPath .. '/__data_' .. moduleName .. '.lua'
								table.insert(scripts, module)
								utils.log(logScript .. moduleName .. '.lua has no "on" and/or "execute" section, not a dzVents module. Skipping', utils.LOG_DEBUG)
								--table.insert(errModules, moduleName)
						utils.log(logScript .. moduleName .. '.lua is not a dzVents module. Skipping', utils.LOG_DEBUG)
				utils.log(module, utils.LOG_ERROR)
		return scripts, errModules
	function self.getEventBindings(mode, testTime)
		local bindings = {}
		local ok, i, event, j, device, err
		local modules = {}
		if not self.scripts then
			self.scripts, self.errModules = loadEventScripts()
		if (mode == nil) then mode = 'device' end
		for i, module in pairs(self.scripts) do
			local logScript = (module.type == 'external' and 'Script ' or 'Internal script ')
			for j, event in pairs(module.on) do
				if (not (type(j) == 'string' or type(event) == 'table')) then
					utils.log(logScript .. module.name .. '.lua has a malformed on-section. Check the documentation. Skipping', utils.LOG_DEBUG)
					if (mode == 'timer' and j == 'timer') then
						-- { ['timer'] = { 'every minute ', 'every hour' } }
						local triggered, def = self.processTimeRules(event)
						if (triggered) then
							-- this one can be executed
							module.trigger = def
							event.type = 'timer'
							table.insert(bindings, module)
					elseif (mode == 'device' and j == 'devices') then
						-- { ['devices'] = { 'devA', ['devB'] = { ..timedefs }, .. }
						for devIdx, devName in pairs(event) do
							-- detect if devName is of the form ['devB'] = { 'every hour' }
							if (type(devName) == 'table') then
								local triggered, def = self.processTimeRules(devName, testTime)
								if (triggered) then
									addBindingEvent(bindings, devIdx, module)
								-- a single device name (or id)
								addBindingEvent(bindings, devName, module)
					elseif (mode == 'scenegroups' and (j == 'scenes' or j == 'groups')) then
						-- { ['scenes'] = { 'scA', ['scB'] = { ..timedefs }, .. }
						for devIdx, scgrpName in pairs(event) do
							-- detect if scgrpName is of the form ['devB'] = { 'every hour' }
							if (type(scgrpName) == 'table') then
								local triggered, def = self.processTimeRules(scgrpName, testTime)
								if (triggered) then
								-- a single scene or group name (or id)
								addBindingEvent(bindings, scgrpName, module)
					elseif (mode == 'variable' and j == 'variables') then
						-- { ['variables'] = { 'varA', 'varB' }
						for varIdx, varName in pairs(event) do
							addBindingEvent(bindings, varName, module)
					elseif (mode == 'security' and j == 'security') then
						local triggered, def = self.checkSecurity(event, self.domoticz.security)
						if (triggered) then
					elseif (mode == 'httpResponse' and j == 'httpResponses') then
						-- { ['httpResponses'] = { 'callbackA', 'callbackB' }
						for i, callbackName in pairs(event) do
							addBindingEvent(bindings, callbackName, module)
					elseif (mode == 'system' and j == 'system') then
						-- { ['system'] = { 'start', 'end' }
						for evtIdx, systemEvent in pairs(event) do
							-- detect if system is of the form ['start'] = { 'every hour' }
							if (type(systemEvent) == 'table') then
								local triggered, def = self.processTimeRules(systemEvent, testTime)
								if (triggered) then
									addBindingEvent(bindings, evtIdx, module)
								-- a single system event
								addBindingEvent(bindings, systemEvent, module)
					elseif (mode == 'customEvents' and j == 'customEvents') then
						-- { customEvents = { 'myEvent', ['anotherEvent'] = { ... timeDefs ... } }
						for evtIdx, customEventName in pairs(event) do
							-- detect if customEvent is of the form ['myEvent'] = { 'every hour' }
							if (type(customEventName) == 'table') then
								local triggered, def = self.processTimeRules(customEventName, testTime)
								if (triggered) then
								-- a single custom event
								addBindingEvent(bindings, customEventName, module)
		return bindings, self.errModules
	function self.dumpCommandArray(commandArray, fromIndex, force)
		local printed = false
		local level = utils.LOG_DEBUG
		if (fromIndex == nil) then
			fromIndex = 1
		if (force == true and force ~= nil or globalvariables['testmode'] == true) then
			level = utils.LOG_INFO
		for k, v in pairs(commandArray) do
			if ((fromIndex ~= nil and k >= fromIndex) or fromIndex == nil) then
				if (not printed) then
					utils.log('Commands sent to Domoticz: ', level)
				if (type(v) == 'table') then
					for kk, vv in pairs(v) do
						utils.log('- ' .. kk .. ' = ' .. _.str(vv), level)
					utils.log(k .. ' = ' .. v, level)
				printed = true
		if (printed) then utils.log('=====================================================', level) end
	function self.findScriptForTarget(target, allEventScripts)
		local modules
		-- only search for named and wildcard triggers,
		-- id is done later
		for scriptTrigger, scripts in pairs(allEventScripts) do
			if (string.find(scriptTrigger, '*')) then -- a wild-card was used
				scriptTrigger = ('^' .. scriptTrigger:gsub("[%^$]","."):gsub("*", ".*") .. '$')
				local function sMatch(text, match) -- specialized sanitized match function to allow combination of Lua magic chars in wildcards
					local sanitizedMatch = match:gsub("([%%%(%)%[%]%+%-%?])", "%%%1") -- escaping all 'magic' chars except *, ., ^ and $
					return text:match(sanitizedMatch)
				if sMatch(target, scriptTrigger) then
					if modules == nil then modules = {} end
					for i, mod in pairs(scripts) do
						table.insert(modules, mod)
				if (scriptTrigger == target) then
					-- there is trigger for this target
		return modules
	function self.dispatchDeviceEventsToScripts(domoticz)
		if (domoticz == nil) then -- you can pass a domoticz object for testing purposes
			domoticz = self.domoticz
		local allEventScripts = self.getEventBindings()
		domoticz.changedDevices().forEach( function(device)
			local scriptsToExecute = self.findScriptForTarget(device.name, allEventScripts)
			local idScripts = allEventScripts[device.id]
			local caSize = _.size(self.domoticz.commandArray)
			if (idScripts ~= nil) then
				-- merge id scripts with name scripts
				if (scriptsToExecute == nil) then
					scriptsToExecute = {}
				for i, mod in pairs(idScripts) do
					table.insert(scriptsToExecute, mod)
			if (scriptsToExecute ~= nil) then
				utils.log('Handling events for: "' .. device.name .. '", value: "' .. tostring(device.state) .. '"', utils.LOG_MODULE_EXEC_INFO)
				self.handleEvents(scriptsToExecute, device)
				self.dumpCommandArray(self.domoticz.commandArray, caSize + 1)
		end)
		return self.domoticz.commandArray
	function self.dispatchSceneGroupEventsToScripts(domoticz)
		local allEventScripts = self.getEventBindings('scenegroups')
		local processItem = function(item, loglabel)
			utils.log(loglabel .. '-event for: ' .. item.name .. ' value: ' .. tostring(item.state), utils.LOG_DEBUG)
			local scriptsToExecute = self.findScriptForTarget(item.name, allEventScripts)
			local idScripts = allEventScripts[item.id]
				utils.log('Handling events for: "' .. item.name .. '", value: "' .. tostring(item.state) .. '"', utils.LOG_MODULE_EXEC_INFO)
				self.handleEvents(scriptsToExecute, item)
		domoticz.changedScenes().forEach(function(scene)
			processItem(scene, 'Scene')
		end)
		domoticz.changedGroups().forEach(function(group)
			processItem(group, 'Group')
		end)
	function self.dispatchTimerEventsToScripts()
		local scriptsToExecute = self.getEventBindings('timer')
		self.handleEvents(scriptsToExecute)
		self.dumpCommandArray(self.domoticz.commandArray)
	function self.dispatchSecurityEventsToScripts()
		local updates =_G.securityupdates
		if (updates ~= nil) then
			for i, securityState in pairs(updates) do
				local security = {
					baseType = domoticz.BASETYPE_SECURITY,
					name = securityState
				self.domoticz.security = securityState
				local scriptsToExecute = self.getEventBindings('security', nil)
				self.handleEvents(scriptsToExecute, security)
	function self.dispatchVariableEventsToScripts(domoticz)
		local allEventScripts = self.getEventBindings('variable')
		domoticz.changedVariables().forEach(function(variable)
			-- first search by name
			local scriptsToExecute = self.findScriptForTarget(variable.name, allEventScripts)
				-- search by id
				scriptsToExecute = allEventScripts[variable.id]
				utils.log('Handling variable-events for: "' .. variable.name .. '", value: "' .. tostring(variable.value) .. '"', utils.LOG_MODULE_EXEC_INFO)
				self.handleEvents(scriptsToExecute, variable)
		end)
	function self.dispatchHTTPResponseEventsToScripts(domoticz)
		local httpResponseScripts = self.getEventBindings('httpResponse')
		local responses =_G.httpresponse
		if (responses ~= nil) then
			for i, response in pairs(responses) do
				response.baseType = domoticz.BASETYPE_HTTP_RESPONSE
				local callback = response.callback
				local scriptsToExecute = self.findScriptForTarget(callback, httpResponseScripts)
					utils.log('Handling httpResponse-events for: "' .. callback .. '"', utils.LOG_MODULE_EXEC_INFO)
					self.handleEvents(scriptsToExecute, response)
	function self.dispatchSystemEventsToScripts(domoticz)
		if (_G.notification == nil) then
			return
		local systemEventScripts = self.getEventBindings('system', nil)
		local systemEvents =_G.notification.domoticz
		if (systemEvents ~= nil) then
			for i, event in pairs(systemEvents) do
				event.name = SystemEvent(self.domoticz, event)["type"]
				if event.name == nil then
					utils.log('System event "' .. event.type .. '" is not supported yet.', utils.LOG_ERROR)
					event.baseType = domoticz.BASETYPE_SYSTEM_EVENT
					local scriptsToExecute = self.findScriptForTarget(event.name, systemEventScripts)
						utils.log('Handling system event for: "' .. event.name .. '"', utils.LOG_MODULE_EXEC_INFO)
						self.handleEvents(scriptsToExecute, event)
	function self.dispatchCustomEventsToScripts(domoticz)
			return
		local customEventScripts = self.getEventBindings('customEvents', nil)
		local customEvents = _G.notification.customevent
		if (customEvents ~= nil) then
			for i, customEvent in pairs(customEvents) do
				customEvent.name = customEvent.data.name
				customEvent.baseType = domoticz.BASETYPE_CUSTOM_EVENT
				local scriptsToExecute = self.findScriptForTarget(customEvent.name, customEventScripts)
					utils.log('Handling Domoticz custom event for: "' .. customEvent.name .. '"', utils.LOG_MODULE_EXEC_INFO)
					self.handleEvents(scriptsToExecute, customEvent)
	function self.getEventSummary(domoticz)
		local items = {}
		local length = 0
			table.insert(items, '- Device: ' .. device.name)
			length = length + 1
		end)
			table.insert(items, '- Variable: ' .. variable.name)
			length = length + 1
		end)
		local securityUpdates =_G.securityupdates
		if (securityUpdates ~= nil) then
			for i, securityState in pairs(securityUpdates) do
				table.insert(items, '- Security: ' .. securityState)
				length = length + 1
			table.insert(items, '- Scene: ' .. scene.name)
			length = length + 1
		end)
			table.insert(items, '- Group: ' .. group.name)
			length = length + 1
		end)
				table.insert(items, '- HTTPResponse: ' .. response.callback)
				length = length + 1
		local domoticzEvents = _G.notification and _G.notification.domoticz or nil
		if (domoticzEvents ~= nil) then
			for i, domoticzEvent in pairs(domoticzEvents) do
				table.insert(items, '- Domoticz: ' .. domoticzEvent.type) -- .. ' - ' .. domoticzEvent.status)
				length = length + 1
		local customEvents = _G.notification and _G.notification.customEvents or nil
		if (dcustomEvents ~= nil) then
				table.insert(items, '- Custom: ' .. customEvent.type) -- .. ' - ' .. customEvent.status)
				length = length + 1
		return items, length;
	return self
return EventHelpers
Posted: Wednesday 24 March 2021 9:00
by rwblinn
Update
Patch implemented = running smooth since few days on the production system 2020.2 stable.
Thx for help.
Posted: Wednesday 24 March 2021 9:17
by waaren
rwblinn wrote: Wednesday 24 March 2021 9:00 Patch implemented = running smooth since few days on the production system 2020.2 stable.
Thx for testing and feedback. The patch is now also in recent builds.
