3 Phase meter
willem9136
Domoticz version: 2026.2
3 Phase meter
Post by willem9136 »
I'm preparing a Domoticz setup for someone else.
It turns out they have a 3 phase meter Landis & Gyr E350.
I have a 1 phase meter so I can't test the 3 phase environment at my place.
Domoticsz runs on a PI-3B+ and using the P1 over USB and an inverter and an FTDI into the USB0 port.
This setup runs fine at my place.
However I wonder what will happen when I bring the meter into the 3 phase environment.
Will automatically the L1, L2 and L3 meters show up in the Devices window of Domoticz?
Who can tell me if I have to do extra things in the configuration for using this 3 phase meter setup?
And an additional question, Is the Landis&Gyr E350 also having an inverted P1 output?
erem
Domoticz version: 2021.1
Re: 3 Phase meter
Post by erem »
willem9136 wrote: Wednesday 17 March 2021 10:59 However I wonder what will happen when I bring the meter into the 3 phase environment.
Yes, the missing devices will be created automagically.
if not, just delete and recreate the hardware
willem9136 wrote: Wednesday 17 March 2021 10:59 Who can tell me if I have to do extra things in the configuration for using this 3 phase meter setup?
nothing to do
willem9136 wrote: Wednesday 17 March 2021 10:59 And an additional question, Is the Landis&Gyr E350 also having an inverted P1 output?
yes, inverted. you may need a 1k pullup between pin 2 and 5 at the meter, try without first.
17-03-2021 11-16-48.jpg (19.58 KiB) Viewed 639 times
Regards,
Rob
willem9136
Re: 3 Phase meter
Thanks Rob.
