Konke switch and Zigate
Posted: Friday 12 March 2021 11:10
I'm observing somehow strange behaviour with Konke button switch (Model 3AFE170100510001). Every 5 minutes I see update in the log:
2021-03-07 19:34:13.591 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 19:39:15.959 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 19:44:18.324 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 19:49:20.686 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 19:54:23.051 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 19:59:25.402 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 20:04:27.769 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
2021-03-07 20:09:30.131 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 0:00
This is "Single click" state and that means that also action that is set for "Single click" will be executed every 5 minutes despite the fact that nobody is touching the button.
If I then press it twice (double click, value 1:00) and leave the button alone - this starts happening:
2021-03-12 10:38:14.826 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
2021-03-12 10:43:17.147 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
2021-03-12 10:48:19.484 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
2021-03-12 10:53:21.821 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
2021-03-12 10:58:24.152 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
2021-03-12 11:03:26.483 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
2021-03-12 11:08:28.822 Python Plugin System: (Zigate) UpdateDevice - (Konke switch) 1:10
It starts repeating the last state and "simulating" that I pressed the button.
I have several Aqara switches connected to the same Zigate controller, but their behaviour is "update when you press it". Is this a normal behaviour for Konke device?
Connected to Zigate controller, Plugin: 4.12.203 Firmware: 031d
Cheers, Jan
Cheers, Jan
