ESP8266 + BME280 to domoticz over JSON and HTTP
Posted: Thursday 11 March 2021 13:30
by svd71
I made a sensor based on the BME280 and tried to translate it data via moscquitto-brocker:
mosquitto_pub -h 192.168.1.32 -t 'domoticz/in' -m '{"idx":"8","nvalue":"0","svalue":"22;0;60;0;820;0"}'
what is wrong?
Trying to send data via HTTP with description from domoticz-wiki:
can someone explain me, what I did wrong?
Thank you for any advise.
Re: ESP8266 + BME280 to domoticz over JSON and HTTP
Posted: Thursday 11 March 2021 14:07
by waaren
svd71 wrote: Thursday 11 March 2021 13:30 can someone explain me, what I did wrong?
Mind the quotes..
The mosquitto command should be
mosquitto_pub -h 192.168.1.32 -t 'domoticz/in' -m '{"idx":8,"nvalue":0,"svalue":"22;0;60;0;820;0"}'
and the curl
curl "http://192.168.1.32:801/json...."
Posted: Thursday 11 March 2021 14:55
by svd71
Thank you very mucht. The json is worked fine. What about "a nil value (field '?')" in the log?
And HTTP did not help:
Posted: Thursday 11 March 2021 17:12
by waaren
svd71 wrote: Thursday 11 March 2021 14:55 Thank you very much. The json is worked fine. What about "a nil value (field '?')" in the log?
the nil value message comes from one of your Lua or Blockly scripts hard to tell what causes this without the script code.
You (again) forgot the quotes around the http string.
Please post your log / results as text and not as pictures. Thx !
