Synchronize switches
snarf71
Post by snarf71 »
Hey,
I have a script that sync's 2 switches, works fine but after 1 or 2 weeks the switches bigins to flicker (on/off) very fast.
I have to reboot the pi to stop the flickering.
Does someone have a solution or other script?
-- variabeles
local Switch1 = 'Firstfloor'
local Switch2 = 'Secondfloor'
-- sync switches
for deviceName,deviceValue in pairs(devicechanged) do
    if (deviceName == Switch1) then
        if (deviceValue ~= otherdevices[Switch2]) then
            commandArray[Switch2] = deviceValue
    elseif (deviceName == Switch2) then
        if (deviceValue ~= otherdevices[Switch1]) then
            commandArray[Switch1] = deviceValue
Re: Synchronize switches
Do not use the elseif but again a normal if while checking the devices.
Although not sure it is really the solution. This kind of sync is asking for trouble: the update of 1 switch will trigger the update of another. Which can trigger the first switch again if domoticz is not changing the device list fast enough.
snarf71
Post by snarf71 »
waltervl wrote: Monday 08 March 2021 22:30 Do not use the elseif but again a normal if while checking the devices.
Thanks Walter, I'm going to give it a try. Do you know another solution to sync devices?
Sorry but I fail to see the logic of this answer. Maybe I overlook something but I don't see how changing the elseif to an if would help here.
snarf71 wrote: Monday 08 March 2021 19:08 Does someone have a solution or other script?
use the NOTRIGGER option like in below example.
hotel =
{   -- master      slave
    Firstfloor = 'Secondfloor',
    Secondfloor = 'Firstfloor',
for device, value in pairs(devicechanged) do
    if hotel[device] then
        print('Hotel: State of device ' .. device .. ' changed. Updating ' .. hotel[device] .. ' to ' .. value  )
        commandArray[ hotel[device] ] = value .. ' NOTRIGGER'
Thank you @waaren, could not find the logic myself too.
