Tibber / GraphQL into Domoticz
DeVille70
Post by DeVille70 »
I use the Tibber electric company, which offers an API using GraphQL ( https://developer.tibber.com/docs/overview ) for subscribing to electical data (power, consumption, etc).
I have no experience with with APIs in general and not all GraphQL. How can I access this API, and get current power usage into Domoticz?
Any help appreciated. Thanks.
FireWizard
Re: Tibber / GraphQL into Domoticz
Post by FireWizard »
Hi, @DeVille70
I would suggest, that you install Mosquitto as MQTT broker and configure in Domoticz the MQTT Client Gateway with Lan Interface. Next step is to install Node Red, as there is a node available for Tibber.
See: https://flows.nodered.org/node/node-red ... tibber-api
With NR you can make a flow and push the data over MQTT to Domoticz.
If you need support in creating the flow, let me know.
Here did someone create a Python plugin that you could use https://github.com/flopp999/Tibber-Domoticz
DeVille70
Post by DeVille70 »
Thanks, FireWizard and waltervl, for your proposals. I'll have a look into both options.
DeVille70
Post by DeVille70 »
I went for flopp999''s plugin. Really nice and responsive guy - he amended plugin as per my request, and it works just great.
