Split measured value
Posted: Friday 05 March 2021 17:32
by Knibor
I have a device called "Electric (Instant+Counter)". I want to create a new device that only shows the counter value. Can someone give me an example of how to do this in dzVents?
Thank you very much
Re: Split measured value
Posted: Friday 05 March 2021 17:41
by waaren
Knibor wrote: Friday 05 March 2021 17:32
What kind of device should the target be? A text device or a counter or a custom sensor or something else?
Posted: Saturday 06 March 2021 11:12
by Knibor
I currently have a device of the type "General, kWh".
This device gives me two values. The first is the current solar energy and the second is the value of today's total solar energy in kWh. I would like a separate device that only displays the kWh generated by the solar panels today. The device I would like to use is of the Text device.
Re: Split measured value [Solved]
Posted: Saturday 06 March 2021 12:33
by waaren
Knibor wrote: Saturday 06 March 2021 11:12
Could look like script below
return
on =
devices =
2515, -- change to idx of your solar device
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all is ok
marker = 'solar to text',
execute = function(dz, item)
local solar = dz.devices('solar energy today') -- change to name of your text device
local currentText = solar.text
local newtext = item.counterToday .. ' kWh'
if currentText ~= newtext then
solar.updateText(newtext)
Posted: Tuesday 09 March 2021 19:10
by Knibor
Thanks a lot for the script. It works now.
