I am new to this, so bare with me...
I have installed domoticz in combination with Zigbee2MQTT ( and node red and homebridge).
I have paired my new door sensor but when the contacts are together the status in Domotics says 'Open''
And when i remove the contact the status says 'Closed'.
But it is the other way around! Can i fix this somewhere?
In MQTT i See the msgs.... Contacts together is 'True', contacts away is 'False' so there is a translation somewhere in Domoticz?
Can someone help me with this?
Thanks in advance
Edwin
Zigbee Door sensor SNTZ007 - status swapped?
EddyDomoticz
EddyDomoticz
Re: Zigbee Door sensor SNTZ007 - status swapped?
It is solved now, it think with an update of the plugin 'Zigbee2MQTT' within Domoticz.
anyway, SOLVED.
anyway, SOLVED.
