P1 smart meter log sending a day
Posted: Wednesday 03 March 2021 20:13
by kozzen
How can i get a log detail every day from the day before automaticly on mail in a file ?
(so from 00.00 to 23:59 and 59 seconds ( so from the hole day) off the power (usage 1/2 and return 1/2) and the gas )
Re: P1 smart meter log sending a day
Posted: Wednesday 03 March 2021 23:00
As a file needs some extra work but the log as text in an email be similar as example DzVents script in viewtopic.php?t=27982
Why would you need something like this? You can make reports from the report function of Domoticz.
If you want to use these files to make your own database you could also use the DataPush options like https://www.domoticz.com/wiki/HttpLink
Posted: Thursday 04 March 2021 1:19
by waaren
kozzen wrote: Wednesday 03 March 2021 20:13 How can i get a log detail every day from the day before automaticly on mail in a file ?
below dzVents script will send yesterdays log detail of the P1 energy meter as attached file in JSON format.
__________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
___________________________________________________________________________________________________________________________
        Script to send history data as mail attachment
        requires:
            dzVents >= 3.1.0 (domoticz V2020.2 build >= 12771 )
            installed mail on os level (linux only)
        History:
        20210303 initial release
local scriptVar = 'mailHistory'
return
    on =
        timer =
          'at 00:02', -- shortly after midnight to ensure shortlog contains 24 hours of yesterdays data.
        shellCommandResponses =
            scriptVar,
        httpResponses =
            scriptVar,
    data =
        'tempFile',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
        marker = scriptVar,
    execute = function(dz, item)
        --- Your settings below this line
        local powerIDX = 35  -- change to idx of your P1 energy device
        local emailTo = '[email protected]'
        local subject = 'power log'
        --- No changes required below this line
        local function getDeviceLog(idx)
            dz.openURL(
                url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=day&idx=' .. powerIDX,
                callback = scriptVar,
        local function selectRecords(t)
            local yesterday = os.date("%Y-%m-%d",os.time()-24*60*60)
            local res = {}
            for index, record in ipairs(t) do
                if record.d:find(yesterday, 1, true) then
                    table.insert(res, record)
            return dz.utils.toJSON(res)
        local function makeFile(t)
            dz.data.tempFile = os.tmpname()
            file = io.open(dz.data.tempFile, 'w')
            file:write( selectRecords(t))
            file:close()
        local function mailFile(f)
            dz.executeShellCommand(
                command = 'mail -A ' .. f .. ' -s "' .. subject .. '" '  .. emailTo .. ' < /dev/null 2> /dev/null ',
                timeout = 20,
        -- main
        if item.isTimer then
            getDeviceLog(powerIDX)
        elseif item.isHTTPResponse then
            if item.json then
                makeFile(item.json.result)
                mailFile(dz.data.tempFile)
                dz.log('Problem retrieving data ' , dz.LOG_ERROR)
                dz.log(item, dz.LOG_DEBUG)
        elseif item.isShellCommandResponse then
            if not(item.ok) then
                dz.log('Problem with shellCommand ' , dz.LOG_ERROR)
                os.execute('rm ' .. dz.data.tempFile)
Posted: Thursday 04 March 2021 20:51
by kozzen
waaren wrote: Thursday 04 March 2021 1:19
timeout = 20,
i'm getting the folowing error
2021-03-04 20:43:00.683 Error: dzVents: Error: (3.0.2) mailHistory: An error occurred when calling event handler Script #1
2021-03-04 20:43:00.683 Error: dzVents: Error: (3.0.2) mailHistory: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:84: attempt to call a nil value (field 'executeShellCommand')
emailto is changed into my email adresses
POWERidx is changed to 1
Posted: Thursday 04 March 2021 20:53
by waaren
kozzen wrote: Thursday 04 March 2021 20:51 i'm getting the folowing error
In the comments...
requires:
Posted: Thursday 04 March 2021 21:44
by kozzen
How can i update to this 3.1.0, already used check for update or ./updaterelease
Posted: Thursday 04 March 2021 21:48
by waaren
kozzen wrote: Thursday 04 March 2021 21:44 How can i update to this 3.1.0, already used check for update or ./updaterelease
After making a backup of your domoticz directory (without the backup sub directory) you can do from within the domoticz directory
 sudo ./updatebeta
This will bring your version to the latest build including the latest dzVents version.
Posted: Thursday 04 March 2021 22:03
by kozzen
waaren wrote: Thursday 04 March 2021 21:48
 sudo ./updatebeta
thanks, did the update bubt now getting the following error in my mailbox or in the log
2021-03-04 21:56:00.947 Error: dzVents: Error: (3.1.5) mailHistory: Problem with shellCommand
Posted: Thursday 04 March 2021 22:16
by waaren
kozzen wrote: Thursday 04 March 2021 22:03
Can you show all log lines from the start of the script until this error and the debug lines after it ?
The domoticz log will show what mail command is send from domoticz to the shell. If you have that command working from the CLI, domoticz should also work.
It should look like below (with a different file name in /tmp and a different Email address).
mail -A /tmp/lua_Ob8JBf -s "power log" [email protected] < /dev/null 2> /dev/null
Posted: Thursday 04 March 2021 22:21
by kozzen
2021-03-04 21:56:00.417 Status: dzVents: Info: mailHistory: ------ Start internal script: Script #1:, trigger: "at 21:56"
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: url = http://127.0.0.1:8080/json.htm?type=gra ... =day&idx=1
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: method = GET
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: post data = nil
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: headers = nil
2021-03-04 21:56:00.418 Status: dzVents: Debug: mailHistory: OpenURL: callback = mailHistory
2021-03-04 21:56:00.418 Status: dzVents: Info: mailHistory: ------ Finished Script #1
2021-03-04 21:56:00.419 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-03-04 21:56:00.668 Status: dzVents: Info: Handling httpResponse-events for: "mailHistory"
2021-03-04 21:56:00.668 Status: dzVents: Info: mailHistory: ------ Start internal script: Script #1: HTTPResponse: "mailHistory"
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellCommand: command = mail -A /tmp/lua_C851pY -s "power log" [email protected] < /dev/null 2> /dev/null
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellCommand: callback = mailHistory
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellCommand: timeout = 20
2021-03-04 21:56:00.791 Status: dzVents: Debug: mailHistory: ExecuteShellcommand: path = /home/pi/domoticz/scripts/dzVents/data/
2021-03-04 21:56:00.793 Status: dzVents: Info: mailHistory: ------ Finished Script #1
2021-03-04 21:56:00.793 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-03-04 21:56:00.946 Status: dzVents: Info: Handling shellcommandResponse-events for: "mailHistory"
2021-03-04 21:56:00.946 Status: dzVents: Info: mailHistory: ------ Start internal script: Script #1: ShellCommandResponse: "mailHistory"
2021-03-04 21:56:00.948 Status: dzVents: Debug: mailHistory: {["dump"]=function, ["errorText"]="", ["timeoutOccurred"]=false, ["isHTTPResponse"]=false, ["isScene"]=false, ["isCustomEvent"]=false, ["statusText"]="", ["isSystem"]=false, ["trigger"]="mailHistory", ["baseType"]="shellcommandResponse", ["isXML"]=false, ["isHardware"]=false, ["isDevice"]=false, ["hasLines"]=false, ["data"]="", ["isJSON"]=false, ["isVariable"]=false, ["ok"]=false, ["isGroup"]=false, ["isTimer"]=false, ["isSecurity"]=false, ["callback"]="mailHistory", ["statusCode"]=127, ["isShellCommandResponse"]=true, ["shellCommandResponse"]="mailHistory"}
2021-03-04 21:56:00.949 Status: dzVents: Info: mailHistory: ------ Finished Script #1
2021-03-04 21:57:01.643 Status: Notification sent (Email)
Posted: Thursday 04 March 2021 22:38
by waaren
kozzen wrote: Thursday 04 March 2021 22:21 mail -A /tmp/lua_C851pY -s "power log" [email protected] < /dev/null
What do do see when you give this command from the CLI ?
What do you see when do a cat tmp/lua_C851pY
returncode 127 is most of the time "command not found"
Posted: Thursday 04 March 2021 23:26
by kozzen
when i type this
i get nothing no fault
cat tmp/lua_C851pY
i get permission denied
Posted: Thursday 04 March 2021 23:39
by waaren
kozzen wrote: Thursday 04 March 2021 23:26 when i type this
cat tmp/lua_C851pY
I suggested something else
if cat tmp/lua_C851pY gives you a permission denied then use
sudo cat tmp/lua_C851pY
Best to first get the mail command with attachment from the Command Line fixed. There are multiple ways to set that up.
To do this is not specific domoticz so you might want to look at specialized Linux forums to get that working.
