Page 1 of 2
Need help for understand dzVents
Posted: Monday 22 February 2021 9:48
by albebert
Hello there,
Since the Yamah plugin is not working anymore ( :'() i'm trying to do that i wan't with virtual switch and dzvents.
but i'm a sysadmin not a developer so difficult for me.
So can anyone help me to do 2 simple things please ?
that i wan't :
- a timer trigger that check the yamaha amp status and change the virtual switch (dimmer) according to amp status.
- change volume of amp when i change it on the dimmer virtual switch.
- change the dimmer volume according to amp volume
- add a selector to switch betweens input (and change it when input is changed directly on amp)
The amp work with http GET (and some POST) and return JSON.
for example in order to get status :
curl -s http://ampli-salon/YamahaExtendedContro ... /getStatus
return :
{"response_code":0,"power":"standby","sleep":0,"volume":76,"mute":false,"max_volume":161,"input":"hdmi5","distribution_enable":true,"sound_program":"surr_decoder","surr_decoder_type":"dts_neo6_cinema","direct":false,"enhancer":true,"tone_control":{"mode":"manual","bass":3,"treble":0},"link_control":"standard","link_audio_delay":"audio_sync","link_audio_quality":"uncompressed","disable_flags":0,"actual_volume":{"mode":"db","value":-42.5,"unit":"dB"},"contents_display":false}
so the interesting value are :
.power (standby or on)
.volume
.input
so i started by creating a event in domoticz UI using http request
		timer = {
			'every 1 minutes' -- just an example to trigger the request
		httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://ampli-salon/YamahaExtendedControl/v1/main/getStatus',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local status = item.json.power  -- just an example
					-- update some device in Domoticz
					domoticz.devices('Ampli - Zone 1').updateText(someValue)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
so if anyone can help me to do this..
Thanks i advance
Re: Need help for understant dzvents
Posted: Monday 22 February 2021 10:18
by waaren
albebert wrote: Monday 22 February 2021 9:48 The amp work with http GET (and some POST) and return JSON.
Hope this initial script will help to get you going.
local scriptVar = 'Yamaha'
        timer =
            'every minute' -- just an example to trigger the request
        httpResponses =
            scriptVar
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        local testing = true
		local maxVolume = 161
        local volume = dz.devices('Yamaha volume') -- switch (dimmer)
        local input = dz.devices('Yamaha input') -- selector switch with all possible input strings as levels
        if item.isTimer then
            dz.openURL({
                callback = scriptVar,
            return
        if testing then
            item.json = dz.utils.fromJSON('{"response_code":0,"power":"standby","sleep":0,"volume":76,"mute":false,"max_volume":161,"input":"hdmi5","distribution_enable":true,"sound_program":"surr_decoder","surr_decoder_type":"dts_neo6_cinema","direct":false,"enhancer":true,"tone_control":{"mode":"manual","bass":3,"treble":0},"link_control":"standard","link_audio_delay":"audio_sync","link_audio_quality":"uncompressed","disable_flags":0,"actual_volume":{"mode":"db","value":-42.5,"unit":"dB"},"contents_display":false}')
            dz.utils.dumpTable(item.json) -- just for test / debug
        if item.isHTTPResponse and item.json then
            volume.dimTo(math.floor(item.json.volume / maxVolume)).silent()
            input.switchSelector(item.json.input).silent()
            dz.log('There was a problem handling the request ', domoticz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
Posted: Monday 22 February 2021 11:05
by albebert
Ok it's work !
just a litle problem with volume max volume on amp is 161 so when volume is at max on amp, dimmer is at 61%.
i've added htttp query on selector
so for now, selector is working great, power too.
so need to ajust dimmer volume to amp volume, and control amp volume from dimmer volume.
Posted: Monday 22 February 2021 11:07
albebert wrote: Monday 22 February 2021 9:48 Hello there,
What Yamaha plugin is not working anymore? This one: https://github.com/thomas-villagers/domoticz-yamaha ?
I do not find any reference on the forum that a yamaha plugin is not working anymore...
Posted: Monday 22 February 2021 11:19
by albebert
waltervl wrote: Monday 22 February 2021 11:07
yes this plugin,
i'm not alone that have a problem.
and now, my old domoticz is not working anymore with this plugin :
2021-02-22 11:16:34.984 Error: (Ampli Salon): Async Read Exception (192.168.200.67:50000): 104, Connection reset by peer
2021-02-22 11:16:35.009 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.010 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.011 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.012 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.014 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.015 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.016 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.017 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.018 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.019 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
2021-02-22 11:16:35.020 Error: Python Plugin System: (Ampli Salon) No transport, write directive to 'Yamaha connection' ignored.
i d'ont know why, issu open on git but no response from dev :'(
so i manage to bypass this
edit : for info there is a thread on forum : https://domoticz.com/forum/viewtopic.ph ... ha#p263641
Posted: Monday 22 February 2021 12:36
by waaren
albebert wrote: Monday 22 February 2021 11:05 just a litle problem with volume max volume on amp is 161 so when volume is at max on amp, dimmer is at 61%.
Adjusted the above script to convert ampVolume ( 0 - 161 ) to dimLevel ( 0 - 100 )
Posted: Monday 22 February 2021 14:19
by albebert
waaren wrote: Monday 22 February 2021 12:36
thanks ! (i've do this to achieve same thing : volume.dimTo(item.json.volume/161*100).silent() )
so now a little problem, when i change dimmer level, amp goes ON, but the script seems to change level each time, so if amp is off, when the script run, it goes ON.
there is a way to change this ? (if dimmer volume change don't power on) or i think that we can add an condition like this :
if item.isHTTPResponse and item.json and item.json.power = on then
and the last thing, need to change amp volume when i change dimmer volume.
Posted: Monday 22 February 2021 14:40
by waaren
albebert wrote: Monday 22 February 2021 14:19 so now a little problem, when i change dimmer level, amp goes ON, but the script seems to change level each time, so if amp is off, when the script run, it goes ON.
No but maybe you can split the functionality. So one dimmer to display the volume and one switch to switch power of the amp?
What is the url to set the amp volume?
Posted: Monday 22 February 2021 14:43
by albebert
there is the url http://ampli-salon/YamahaExtendedContro ... ?volume=50
i'm testing a thing but no luck
            if item.json.power == on then
            volume.quietOn()
            volume.quietOff()
the "if item.json.power == on then" does not math (i've the dump table in log so i enter in first if but not in the second.
edit : ok with right syntax it's work "item.json.power == "on' "
if amp is off, script d'ont update dimmer volume (not needed) ! :)
Posted: Monday 22 February 2021 15:13
by waaren
albebert wrote: Monday 22 February 2021 14:43 there is the url http://ampli-salon/YamahaExtendedContro ... ?volume=50
For setting the volume based on dimmer
Something like ?
        timer =
        devices =
            ''Yamaha volume',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
            dz.openURL({
        elseif item.isDevice then
            dz.openURL('http://ampli-salon/YamahaExtendedControl/v1/main/setVolume?volume=' .. (math.floor( item.level * maxVolume / 100) ))
        elseif item.isHTTPResponse and item.json then
Posted: Monday 22 February 2021 15:33
by albebert
hum i think that another script that react to dimmer change is better no ?
Posted: Monday 22 February 2021 15:44
by waaren
albebert wrote: Monday 22 February 2021 15:33 hum i think that another script that react to dimmer change is better no ?
Why ?
Posted: Monday 22 February 2021 15:48
by albebert
because it can react on change not after 1 minute.
i think
Posted: Monday 22 February 2021 15:54
by waaren
albebert wrote: Monday 22 February 2021 15:48 because it can react on change not after 1 minute. i think
That's why I added the devices = in the on Section. The script now also reacts immediately on a device change
Posted: Monday 22 February 2021 16:33
by albebert
sorry missed that !
so i tested, and amp goes of after 1 minute :/
amp is on, don't touch anything, but dimmer is set to 0 so power off
021-02-22 16:30:00.531 Status: dzVents: Debug: - OpenURL = {["_trigger"]="Yamaha", ["method"]="GET", ["URL"]="http://192.168.200.67/YamahaExtendedCon ... /getStatus"}
2021-02-22 16:30:00.533 Status: dzVents: Debug: =====================================================
2021-02-22 16:30:00.535 Status: EventSystem: Script event triggered: /opt/domoticz/dzVents/runtime/dzVents.lua
2021-02-22 16:30:00.684 Status: dzVents: Debug: Dumping domoticz data to /opt/domoticz/scripts/dzVents/domoticzData.lua
2021-02-22 16:30:00.770 Status: dzVents: Debug: dzVents version: 3.1.4
2021-02-22 16:30:00.772 Status: dzVents: Debug: Event triggers:
2021-02-22 16:30:00.773 Status: dzVents: Debug: - HTTPResponse: Yamaha
2021-02-22 16:30:00.847 Status: dzVents: Info: Handling httpResponse-events for: "Yamaha"
2021-02-22 16:30:00.849 Status: dzVents: Info: Yamaha: ------ Start internal script: dzvent ampli main: HTTPResponse: "Yamaha"
2021-02-22 16:30:00.904 Status: dzVents: Debug: Yamaha: Processing device-adapter for Ampli - Zone 1: Switch device adapter
2021-02-22 16:30:00.908 Status: dzVents: Debug: Yamaha: Processing device-adapter for Ampli Input: Switch device adapter
2021-02-22 16:30:00.909 Status: dzVents: Debug: Yamaha: Constructed timed-command: Set Level 0
2021-02-22 16:30:00.911 Status: dzVents: Debug: Yamaha: Constructed timed-command: Set Level 0 NOTRIGGER
2021-02-22 16:30:00.913 Status: dzVents: Debug: Yamaha: Constructed timed-command: Set Level 70
2021-02-22 16:30:00.915 Status: dzVents: Debug: Yamaha: Constructed timed-command: Set Level 70 NOTRIGGER
2021-02-22 16:30:00.918 Status: dzVents: Info: Yamaha: ------ Finished dzvent ampli main
2021-02-22 16:30:00.920 Status: dzVents: !Info: Yamaha: Debug: Writing module summary to /opt/domoticz/scripts/dzVents/module.log
2021-02-22 16:30:00.923 Status: dzVents: Debug: Commands sent to Domoticz:
2021-02-22 16:30:00.925 Status: dzVents: Debug: - Ampli - Zone 1 = Set Level 0 NOTRIGGER
2021-02-22 16:30:00.926 Status: dzVents: Debug: - Ampli Input = Set Level 70 NOTRIGGER
2021-02-22 16:30:00.928 Status: dzVents: Debug: =====================================================
2021-02-22 16:30:00.933 Status: EventSystem: Script event triggered: /opt/domoticz/dzVents/runtime/dzVents.lua
2021-02-22 16:30:00.977 Dummy: Light/Switch (Ampli - Zone 1)
2021-02-22 16:30:01.012 Dummy: Light/Switch (Ampli Input)
i'm trying to add dz.log('i am here') to determin if i enter into condition but domoticz seems not apreciate that :
"attempt to index a nil value (global 'dz')"
Re: Need help for understand dzVents
Posted: Monday 22 February 2021 17:20
by waaren
albebert wrote: Monday 22 February 2021 16:33 i'm trying to add dz.log('i am here') to determin if i enter into condition but domoticz seems not apreciate that :
Please share the script that causes this error so I can help.
Posted: Monday 22 February 2021 17:23
by albebert
        timer =
        devices =
            'Ampli - Zone 1',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
        local volume = dz.devices('Ampli - Zone 1') -- switch (dimmer)
        local input = dz.devices('Ampli Input') -- selector switch with all possible input strings as levels
            dz.log('i am here ?')
            dz.openURL({
                url = 'http://192.168.200.67/YamahaExtendedControl/v1/main/getStatus',
        return
            dz.log('or here ?')
            dz.openURL('http://192.168.200.67/YamahaExtendedControl/v1/main/setVolume?volume=' .. (math.floor( item.level * maxVolume / 100) ))
            dz.log('or another here ?')
for information my script working without trying to control dimmer :
        timer =
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
        local testing = false
            dz.openURL({
            return
        if testing then
            item.json = dz.utils.fromJSON('{"response_code":0,"power":"standby","sleep":0,"volume":80,"mute":false,"max_volume":161,"input":"hdmi5","distribution_enable":true,"sound_program":"surr_decoder","surr_decoder_type":"dts_neo6_cinema","direct":false,"enhancer":true,"tone_control":{"mode":"manual","bass":3,"treble":0},"link_control":"standard","link_audio_delay":"audio_sync","link_audio_quality":"uncompressed","disable_flags":0,"actual_volume":{"mode":"db","value":-42.5,"unit":"dB"},"contents_display":false}')
        if item.isHTTPResponse and item.json and item.json.power == 'on' then
            --volume.quietOn()
            volume.quietOff()
Posted: Monday 22 February 2021 18:55
by waaren
albebert wrote: Monday 22 February 2021 17:23 for information my script working without trying to control dimmer :
Can you try this one? (first without changing anything please)
        timer =
        devices =
            'Ampli - Zone 1',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
            dz.openURL({
            dz.log('or another here ?', dz.LOG_DEBUG)
            volume.dimTo(math.floor(item.json.volume / maxVolume * 100)).silent()
Posted: Monday 22 February 2021 19:02
by albebert
I try this tomorow.
Wife and Kids heure now, c'ant make test with the amp xD
edit : finaly take 2 minutes to test and seems to work.
amp don"t power off and volume control work.
need to test further tomorow :)
many thanks and send me your paypal adresse in PM wan't to offer you a beer :)
edit 2 : seems to power on , i think that i need to add condition (if .power = standby do nothing)
Posted: Tuesday 23 February 2021 0:26
by waaren
albebert wrote: Monday 22 February 2021 19:02 many thanks and send me your paypal adres in PM wan't to offer you a beer :)
Very kind of you but not needed.
