Erro attempt to concatenate a nil value (global 'device')
Posted: Saturday 20 February 2021 9:51
To check if my Zigbee devices are still the alive I implemented a script as described here.
Now and then an error appears in my Domoticz log and, despite of a lot of similar issues on the web I can't find what causes it:
The scripts triggers on time, as instructed. I tried to trigger on device, but that makes no difference I am wondering what can cause the error.
local devices = { "Achter beweging",
"Badkamer beweging",
"Overloop beweging",
"Badkamer temp en vocht",
"Douche temp en vocht",
"Plug koelkast",
"Plug vriezer" }
no_data_timer = 300 -- Date time-out in minutes
email_address = "[email protected]" -- Mailadres for e-mail notifications; empty for standard notifications
function datetimedifferencenow(s) -- Function to calculate difference between given timestamp (s) and current time
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
time = os.date("*t")
-- Once a failing device is detected (meaning no update received in the last <no_data_timer> minutes), this device is stored in the user variable "No update from sensor" and a notification is sent
-- To prevent a notification storm, no update is send out as long as the user variable contains a value
if (uservariables["No update from sensor"] ~= tostring("")) then
if (datetimedifferencenow(otherdevices_lastupdate[uservariables["No update from sensor"]]) < no_data_timer*60) then
commandArray["Variable:No update from sensor"] = tostring("")
if (email_address == tostring("")) then
commandArray["SendNotification"] = "Sensor \"" .. uservariables["No update from sensor"] .. "\" verstuurt weer data."
print ("Received data from sensor \"" .. uservariables["No update from sensor"] .. "\" again. Notification was sent.")
commandArray["SendEmail"]="Domoticz sensor waarschuwing#Sensor \"" .. device .. "\" verstuurt weer data.#" .. email_address
print ("Received data from sensor \"" .. uservariables["No update from sensor"] .. "\" again. Email was sent.")
-- If there is no device stored in the user variable "No update from sensor", all devices are checked if they send data in the last <no_data_timer> minutes.
if (uservariables["No update from sensor"] == tostring("")) then
for i,device in pairs(devices) do
-- If check device did not give an update in the last <no_data_timer> minutes then send notification and write device to user variable "No update from sensor".
if (datetimedifferencenow(otherdevices_lastupdate[device]) >= no_data_timer*60) then
commandArray["Variable:No update from sensor"] = tostring(device)
commandArray["SendNotification"] = "Sensor \"" .. device .. "\" heeft meer dan " .. no_data_timer .. " minuten geen data verstuurd."
print ("No data received from sensor \"" .. device .. "\" for more than " .. no_data_timer .. " minutes. Notification was sent.")
commandArray["SendEmail"]="Domoticz sensor time-out#Sensor \"" .. device .. "\" heeft meer dan " .. no_data_timer .. " minuten geen data verstuurd.#" .. email_address
print ("No data received from sensor \"" .. device .. "\" for more than " .. no_data_timer .. " minutes. Notification sent. Email was sent.")
break -- stop the for loop.
-- To make sure a failing sensor is not forgotten, every morning at 8:00 a notification is send if the sensor is failing for > 24 hours.
if (uservariables["No update from sensor"] ~= tostring("") and time.hour==8 and time.min==0) then
if (datetimedifferencenow(otherdevices_lastupdate[uservariables["No update from sensor"]]) >= 86400) then
commandArray["SendNotification"] = "Ter herinnering, sensor \"" .. uservariables["No update from sensor"] .. "\" verstuurt nog steeds geen data."
print ("Reminder notification was sent for sensor \"" .. uservariables["No update from sensor"] .. "\" that it is not sending data for more than 24 hours.")
commandArray["SendEmail"]="Domoticz sensor time-out reminder#Ter herinnering, sensor \"" .. uservariables["No update from sensor"] .. "\" verstuurt nog steeds geen data.#" .. email_address
print ("Reminder email was sent for sensor \"" .. uservariables["No update from sensor"] .. "\" that it is not sending data for more than 24 hours.")
return commandArrayCode: Select all
Error: EventSystem: in Status Zigbee sensors en plugs: [string "local devices = { "Achter beweging", ..."]:36: attempt to concatenate a nil value (global 'device')
