ifttvar script
Posted: Thursday 18 February 2021 19:38
by pvklink
Some years ago, the forum made a script for me (many thanks to waaren) so i can send json data from the internet (google via IFTT) via a post to a domoticz uservariable.
The below script handles these json data and translate this data to domoticz actions, it works perfect for years.
I recently made a security configuration and i like to managed this by speak commands.
The json data for this script should be (i think)
[{"obj":"1728","act":"Disarm"}] or
[{"obj":1728,"act":"Disarm"}] ...
1728 is the idx of my securitypanel.
I get the msg that this isnt a device....
2021-02-18 19:18:57.856 Status: dzVents: Info: Handling variable-events for: "IFTTTvar", value: "[{"obj":1728,"act":"Disarm"}]"
2021-02-18 19:18:57.857 Status: dzVents: Info: ------ Start internal script: DZ_service_ifttt: Variable: "IFTTTvar" Index: 13
2021-02-18 19:18:57.870 Status: dzVents: Info: ------ Finished DZ_service_ifttt
2021-02-18 19:18:57.870 Error: dzVents: Error: (3.1.4) no device, scene, group or var found
syntax of JSON in uservar:
{"obj":"IFvar","set":"TestString"},
{"obj":"IFswitch","act":"On","fS":10,"aS":10,"si":true},
{"obj":IFswitchID,"type":"device","act":"On"},   if IFswitchID = numeric , type = device, group, etc mandatory
{"obj":"IFSelector","lbl":"Level1"},
{"obj":"IFScene","act":"On"}]
or
{"obj":"message from ifttt","msg":["message to all"]},
max. number of chars = 200
every action request in the json should have obj/object and max. one of (act/action, lbl/label, msg/message, set or upd/update, ).
Other controls (aS/afterSec, fS/ forSec, rAS/repeatAfterSec, si/silent are optional.
if message/msg is the requested action the object field is used as subject and subtable [{}]
            mandatory       line.object    message subject
            mandatory       line.message[1] message body
            optional or nil line.message[2] message priority  (-2=LOW, -1=MODERATE, 0=NORMAL, 1=HIGH, 2=EMERGENCY)
            optional or nil line.message[3] message sound (string like 'pushover','bike','none')
            optional or nil line.message[4] extra
            optional or nil line.message[5] subsystem or table with subsystems
            examples
            [{"obj":"message from ifttt","msg":["message to all notification systems with default priority"]}]
            [{"obj":"message from ifttt","msg":["message to pushover with high priority",1,null,null,"pushover"]}]
            [{"obj":"message from ifttt","msg":["message to pushover and gcm with low priority",-2,null,null,["pushover","gcm"] ]}]
if OSCommand/os is the requested action, the object field is used program / scriptname. name must be full qualified e.g. "/home/pi/scripts/myScript.sh"
local iftttvar = "IFTTTvar"
return
    on =
        variables = { iftttvar },
    execute = function(dz, item)
    _G.logLevel = dz.helpers.get_logtype(dz)    -- dz.log('debug test',dz.LOG_DEBUG) this will only make it to the log when LOG_DEBUG is set  AND dz.log('blabla',dz.LOG_FORCE) -- this will allways make it tp the log
    _G.logMarker = _G.moduleLabel -- marker wordt scriptnaam, _G.logMarker = info.scriptName is idem
    -- HIER START DE EXECUTIE
        local function makeLongKeys(str)
            local shortNames = {
                                    act="action",  -- optional: Can be On, Off or OS/OScommand:
                                                   -- On; valid for switches and groups and scenes and scenes; Off; valid for switches and groups
                                    aS="afterSec", -- optional:
                                    fS="forSec",   -- optional: Only valid for standard (On/Off) switches
                                    lbl="label",   -- optional: levelName or number for selector type switches
                                    msg="message", -- Optional: obj must be set to subject
                                    obj="object",  -- Mandatory and must be unique in domoticz: name for device, scene, group or uservariable.
                                    os="OSCommand", -- if os / OSCommand is the requested action, obj must be set to full qualified script /program.
                                    rAS="repeatAfterSec", -- optional: Only valid for standard (On/Off) switches
                                    set="set",  -- Optional: update uservariable
                                    si="silent",  -- Optional: use "si":true in JSON
                                    upd="update", -- Optional: Only valid for devices (set nValue, sValue)
            for short, long in pairs(shortNames) do
                str = str:gsub('%f[%a]' .. short .. '%f[%A]' ,long) -- this will only replace short with long if short is a whole word
            return str
        local function getBaseType(line)
            if line.type then return line.type, line.object end
            for i, tuple in ipairs(_G.domoticzData) do
                if tuple.name == line.object then
                    return tuple.baseType, tuple.id
        local function makeTarget(baseType, identifier)
            if baseType == 'device' then
                return dz.devices(identifier)
            elseif baseType == 'group' then
                return dz.groups(identifier)
            elseif baseType == 'scene' then
                return dz.scenes(identifier)
            elseif baseType == 'uservariable' then
                return dz.variables(identifier)
        local function doLabelVariant(line, target)
            if line.afterSec and line.silent then
                target.switchSelector(line.label).silent().afterSec(line.afterSec)
            elseif line.afterSec then
                target.switchSelector(line.label).afterSec(line.afterSec)
           elseif line.silent then
        local function doUpdateVariant(line, target)
                target.update(line.update).silent().afterSec(line.afterSec)
                target.update(line.update).afterSec(line.afterSec)
        local function doSetVariant(line, target)
                target.set(line.set).silent().afterSec(line.afterSec)
                target.set(line.set).afterSec(line.afterSec)
        local function doOnVariant(line, target)
            if line.afterSec and line.forSec and line.silent then
                target.switchOn().silent().afterSec(line.afterSec).forSec(line.forSec)
            elseif line.afterSec and line.repeatAfterSec and line.silent then
                target.switchOn().silent().afterSec(line.afterSec).repeatAfterSec(line.repeatAfterSec)
            elseif line.afterSec and line.silent then
            -- start pvk
            elseif line.afterSec and line.forSec then
                target.switchOn().afterSec(line.afterSec).forSec(line.forSec)
            elseif line.forSec then
                target.switchOn().forSec(line.forSec)
            -- einde pvk
                target.switchOn()
        local function doArmVariant(line, target)
            target.armAway().checkFirst()
        local function doOffVariant(line, target)
                target.switchOff().silent().afterSec(line.afterSec).forSec(line.forSec)
                target.switchOff().silent().afterSec(line.afterSec).repeatAfterSec(line.repeatAfterSec)
            -- pvk start
                target.switchOff().afterSec(line.afterSec).forSec(line.forSec)
                target.switchOff().forSec(line.forSec)
            -- pvk stop
                target.switchOff()
        local function doDisarmVariant(line, target)
            target.disarm()
        local function doStopVariant(line, target)
                target.stop().silent().afterSec(line.afterSec)
                target.stop().afterSec(line.afterSec)
                target.stop()
        local function doNotificationVariant(line)
            dz.notify(line.object,line.message[1],line.message[2] or nil,line.message[3] or nil,line.message[4] or nil,line.message[5] or nil)
        local function doOSVariant(osCommand)
            os.execute('sudo ' .. osCommand .. ' &')
            dz.utils.dumpTable(result)
        local function doTasks(result)
            for _, line in ipairs(result) do
                if line.message then
                elseif line.action == 'OSCommand' then
                    doOSVariant(line.object)
                    local baseType, idx = getBaseType(line)
                    target = makeTarget(baseType, line.object)
                    if not(target) then
                       dz.log('no device, scene, group or var found',dz.LOG_ERROR)
                       return
                    if line.action and line.action == 'Off' then -- for switch type devices and groups
                    elseif line.action and line.action == 'On' then -- for switch type devices, scenes and groups
                    elseif line.action and line.action == 'Arm' then -- for switch type devices, scenes and groups
                    elseif line.action and line.action == 'Disarm' then -- for switch type devices, scenes and groups
                    elseif line.action and line.action == 'OSCommand' then
                        doOSVariant(line, target)
                    elseif line.action and line.action == 'Stop' then -- for type blinds
                    elseif line.label then -- for selector type devices
                    elseif line.set then -- for uservariables
                    elseif line.update then -- for devices to set nValu, sValue
        -- main
        local result = dz.utils.fromJSON(makeLongKeys(item.value))
        doTasks(result)
Re: ifttvar script
Posted: Thursday 18 February 2021 22:08
by waaren
pvklink wrote: Thursday 18 February 2021 19:38 I recently made a security configuration and i like to managed this by speak commands.
The script does not work with idx but only with names. To control the security panel The var should look like
[{"obj":"Secure","act":"armAway" }] -- Replace "Secure" with the name of your securirity panel device, "act" can be disarm, armAway or armHome
or
or
{"obj":"Secure","act":"armAway"}   -- "obj" is name of securirity panel device, "act"  is disarm, armAway or armHome
            examples
return
    on =
            return str
            -- start pvk
            -- einde pvk
                target.switchOn()
            -- pvk start
            -- pvk stop
                target.switchOff()
        local function doSecurityVariant(line, target)
            if line.action == 'disarm' then target.disarm()
            elseif line.action == 'armAway' then target.armAway()
            elseif line.action == 'armHome' then target.armHome()
                target.stop()
                    if not(target) then
                       return
                    elseif line.action and ( line.action == 'armAway' or line.action == 'disarm' or line.action == 'armHome' ) then -- for Security panel
                        dz.log('eehhhhhhh',dz.LOG_FORCE)
        -- main
        doTasks(result)
Re: ifttvar script
Posted: Thursday 18 February 2021 22:14
by pvklink
thanks!
i will test it and describe this in the script!
Re: ifttvar script
Posted: Thursday 18 February 2021 22:29
by pvklink
ok, it works, but a little bit different, but it helped me enough !, thanks!
[{"obj":"Domoticz Security Panel","act":"Disarm"}] works
[{"obj":"Domoticz Security Panel","act":"Arm"}] works
armAway armHome dont
Re: ifttvar script
Posted: Thursday 18 February 2021 22:34
by pvklink
changed this
local function doarmHomeVariant(line, target)
target.armHome().checkFirst()
local function doarmAwayVariant(line, target)
and this part
elseif line.action and line.action == 'armHome' then -- for switch type devices, scenes and groups
elseif line.action and line.action == 'armAway' then -- for switch type devices, scenes and groups
Re: ifttvar script  [Solved]
Posted: Thursday 18 February 2021 23:02
by pvklink
Case closed!
Thanks again waaren.
This script is by far the most important part of my speech infra!
still very happy with it...
I used it icm with IFTT and NODE-RED
