Device script always loop!
Posted: Thursday 18 February 2021 17:08
by Nefsolive
I am trying to develop a script in which when the switchSelector ('On') is "Campainha", then the alarm sounds in the melody, etc! But the problem is that the Script does not put the switchSelector ('Off') and stop the alarm! The script is always looped!
There is some other simpler method to do, I've tried it in many ways, but I'm not able to stop the script loop! In the log does not give errors.
devices = {'Campainha', 'Alarme',}
logging = {
level = domoticz.LOG_DEBUG,
marker = 'Toca Campainha',
execute = function(dz)
if dz.devices('Campainha').switchSelector('On') then
dz.devices('Alarme Volume').dimTo(0)
dz.devices('Alarme Melodia').dimTo(20)
dz.devices('Alarme').switchOn()
dz.devices('Alarme').switchOff().aftersec(5)
elseif dz.devices('Alarme').state == 'Off' then
dz.devices('Campainha').dimTo(0)
Re: Device script always loop!
Posted: Thursday 18 February 2021 17:14
by waaren
Nefsolive wrote: Thursday 18 February 2021 17:08
Did you try with the option silent()?
logging = {
dz.devices('Alarme').switchOn().silent()
dz.devices('Alarme').switchOff().aftersec(5).silent()
dz.devices('Campainha').dimTo(0).silent()
Posted: Thursday 18 February 2021 17:42
by Nefsolive
waaren wrote: Thursday 18 February 2021 17:14
logging = {
Hello waaren,
Thanks for reply.
I try with .silent(), and still looping, "dz.devices('Campainha').switchSelector('On')", and just take me off the selector on switches page, wen i put Off the script!
Iff i dont take Off the script, is always loop On!
Strange!
Posted: Thursday 18 February 2021 18:20
by waaren
Nefsolive wrote: Thursday 18 February 2021 17:42
You are using switchSelector in an if statement but switchSelector is an action and not a state.
Please try again with below version and include the log if it does not work as expected.
logging = {
if dz.devices('Campainha').level ~= 0 then
Posted: Thursday 18 February 2021 19:07
by Nefsolive
waaren wrote: Thursday 18 February 2021 18:20
logging = {
Waaren,
Doesn´t work! They give me this on log;
2021-02-18 18:03:31.415 Status: dzVents: Info: Handling events for: "Campainha", value: "on"
2021-02-18 18:03:31.415 Status: dzVents: Info: Toca Campainha: ------ Start internal script: Script #1: Device: "Campainha (Zigbee2MQTT)", Index: 1556
2021-02-18 18:03:31.417 Status: dzVents: Debug: Toca Campainha: Processing device-adapter for Alarme Volume: Switch device adapter
2021-02-18 18:03:31.418 Status: dzVents: Debug: Toca Campainha: Constructed timed-command: Set Level 0
2021-02-18 18:03:31.421 Status: dzVents: Debug: Toca Campainha: Processing device-adapter for Alarme Melodia: Switch device adapter
2021-02-18 18:03:31.421 Status: dzVents: Debug: Toca Campainha: Constructed timed-command: Set Level 20
2021-02-18 18:03:31.423 Status: dzVents: Debug: Toca Campainha: Processing device-adapter for Alarme: Switch device adapter
2021-02-18 18:03:31.424 Status: dzVents: Debug: Toca Campainha: Constructed timed-command: On
2021-02-18 18:03:31.425 Status: dzVents: Debug: Toca Campainha: Constructed timed-command: On NOTRIGGER
2021-02-18 18:03:31.425 Status: dzVents: Debug: Toca Campainha: Constructed timed-command: Off
2021-02-18 18:03:31.425 Status: dzVents: Info: Toca Campainha: ------ Finished Script #1
2021-02-18 18:03:31.430 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-02-18 18:03:31.425 Error: dzVents: Error: (3.0.2) Toca Campainha: An error occurred when calling event handler Script #1
2021-02-18 18:03:31.425 Error: dzVents: Error: (3.0.2) Toca Campainha: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:17: attempt to call a nil value (field 'aftersec')
Posted: Thursday 18 February 2021 19:18
by waaren
Nefsolive wrote: Thursday 18 February 2021 19:07
2021-02-18 18:03:31.425 Error: dzVents: Error: (3.0.2) Toca Campainha: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:17: attempt to call a nil value (field 'aftersec')[/code]
aftersec does not exist.
the method is afterSec
Re: Device script always loop! [Solved]
Posted: Thursday 18 February 2021 21:39
by Nefsolive
waaren wrote: Thursday 18 February 2021 19:18
Yes! You right
my mistake! passed me.
Now no error on log!
i Take out the lines "elseif dz.devices('Alarme').state == 'Off'" and "dz.devices('Alarme').switchOff().afterSec(5).silent()", and now works great!
You always helping! Thank u. Cheers
