zigbee2mqtt: big delay in processing
Posted: Sunday 14 February 2021 11:32
Hi Forum,
at first, thank you for the knowledgebase here, i found much soulutions for my problems with domoticz.
i wrote the first dzvents scripts and use the zigbee2mqtt bridge.
while changing device states, sometimes domoticz need until around 20 seconds to change the state on gui.
here some events from my aquara cube with the output from mosquitto_sub. Each Block is one z2m event with the time beween mosquitto message and Statechange in Domoticz. In this tests, most are faster than 100msec, but there are also some until 5 seconds
is this delay normal?
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 11:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Uptime: 1 Days, 2 Hours, 26 Minutes, 15 Seconds
<plugin key="Zigbee2MQTT" name="Zigbee2MQTT" version="3.0.0">
zigbee2mqtt v.1.17.0 (zStack3x0 20201026)
Running in LXC Container with Proxmox on AMD Ryzen 7 PRO 4750G
best regards,
Max
Version: 2020.2
best regards,
Max
54.576 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"tap\",\"action_side\":0,\"angle\":-4.72,\"battery\":80,\"linkquality\":141,\"side\":0,\"voltage\":2965}'"}
54.577 zigbee2mqtt/aquara_cube1 {"action":"tap","action_side":0,"angle":-4.72,"battery":80,"linkquality":141,"side":0,"voltage":2965}
54.591 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:141 sValue:141
54.592 Debug: SQLH HandleOnOffAction: OnAction:
54.592 Debug: SQLH UpdateValueInt aquara_cube1_cube HwID:3 DevID:0x00158d00051e1723_cube Type:244 sType:62 nValue:1 sValue:30
54.593 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:0 sValue:0
54.611 Status: dzVents: Info: ------ Finished cube1
54.611 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
54.611 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "141"
54.631 Status: dzVents: Info: ------ Finished cube1
54.631 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_cube (z2m)", Index: 27
54.631 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
54.631 Status: dzVents: Info: Handling events for: "aquara_cube1_cube", value: "Tap"
54.631 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "0"
54.631 Status: dzVents: Info: side 0
5,35
29.589 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":1,\"action_side\":0,\"action_to_side\":0,\"angle\":-4.72,\"battery\":80,\"from_side\":1,\"linkquality\":135,\"side\":0,\"to_side\":0,\"voltage\":2965}'"}
29.591 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":1,"action_side":0,"action_to_side":0,"angle":-4.72,"battery":80,"from_side":1,"linkquality":135,"side":0,"to_side":0,"voltage":2965}
34.941 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:135 sValue:135
34.942 Debug: SQLH HandleOnOffAction: OnAction:
34.943 Debug: SQLH UpdateValueInt aquara_cube1_cube HwID:3 DevID:0x00158d00051e1723_cube Type:244 sType:62 nValue:1 sValue:10
34.960 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
34.960 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "135"
34.961 Status: dzVents: Info: ------ Finished cube1
34.980 Status: dzVents: Info: ------ Finished cube1
34.980 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_cube (z2m)", Index: 27
34.980 Status: dzVents: Info: Handling events for: "aquara_cube1_cube", value: "Flip 90"
2,086
48.374 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":0,\"action_side\":1,\"action_to_side\":1,\"angle\":-4.72,\"battery\":80,\"from_side\":0,\"linkquality\":138,\"side\":1,\"to_side\":1,\"voltage\":2965}'"}
48.375 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":0,"action_side":1,"action_to_side":1,"angle":-4.72,"battery":80,"from_side":0,"linkquality":138,"side":1,"to_side":1,"voltage":2965}
50.461 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:138 sValue:138
50.462 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:1 sValue:1
50.481 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "138"
50.482 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
50.489 Status: dzVents: Info: ------ Finished cube1
50.508 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "1"
50.509 Status: dzVents: Info: ------ Finished cube1
50.509 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
50.509 Status: dzVents: Info: side 1
0,001
56.874 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":1,\"action_side\":0,\"action_to_side\":0,\"angle\":-4.72,\"battery\":80,\"from_side\":1,\"linkquality\":114,\"side\":0,\"to_side\":0,\"voltage\":2965}'"}
56.875 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:114 sValue:114
56.876 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:0 sValue:0
56.876 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":1,"action_side":0,"action_to_side":0,"angle":-4.72,"battery":80,"from_side":1,"linkquality":114,"side":0,"to_side":0,"voltage":2965}
56.894 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "114"
56.895 Status: dzVents: Info: ------ Finished cube1
56.895 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
56.915 Status: dzVents: Info: ------ Finished cube1
56.915 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
56.915 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "0"
56.915 Status: dzVents: Info: side 0
0,008
07.378 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":0,\"action_side\":1,\"action_to_side\":1,\"angle\":-4.72,\"battery\":80,\"from_side\":0,\"linkquality\":132,\"side\":1,\"to_side\":1,\"voltage\":2965}'"}
07.379 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":0,"action_side":1,"action_to_side":1,"angle":-4.72,"battery":80,"from_side":0,"linkquality":132,"side":1,"to_side":1,"voltage":2965}
07.387 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:132 sValue:132
07.388 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:1 sValue:1
07.407 Status: dzVents: Info: ------ Finished cube1
07.407 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
07.407 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "132"
07.427 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
07.427 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "1"
07.427 Status: dzVents: Info: side 1
07.428 Status: dzVents: Info: ------ Finished cube1
2,294
19.211 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":1,\"action_side\":0,\"action_to_side\":0,\"angle\":-4.72,\"battery\":80,\"from_side\":1,\"linkquality\":114,\"side\":0,\"to_side\":0,\"voltage\":2965}'"}
19.212 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":1,"action_side":0,"action_to_side":0,"angle":-4.72,"battery":80,"from_side":1,"linkquality":114,"side":0,"to_side":0,"voltage":2965}
21.506 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:114 sValue:114
21.508 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:0 sValue:0
21.526 Status: dzVents: Info: ------ Finished cube1
21.526 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
21.526 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "114"
21.545 Status: dzVents: Info: ------ Finished cube1
21.545 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
21.545 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "0"
21.545 Status: dzVents: Info: side 0
0,041
30.431 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":0,\"action_side\":1,\"action_to_side\":1,\"angle\":-4.72,\"battery\":80,\"from_side\":0,\"linkquality\":123,\"side\":1,\"to_side\":1,\"voltage\":2965}'"}
30.432 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":0,"action_side":1,"action_to_side":1,"angle":-4.72,"battery":80,"from_side":0,"linkquality":123,"side":1,"to_side":1,"voltage":2965}
30.473 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:123 sValue:123
30.474 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:1 sValue:1
30.493 Status: dzVents: Info: ------ Finished cube1
30.493 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
30.493 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "123"
30.513 Status: dzVents: Info: ------ Finished cube1
30.513 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
30.513 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "1"
30.513 Status: dzVents: Info: side 1
0,046
42.742 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":1,\"action_side\":0,\"action_to_side\":0,\"angle\":-4.72,\"battery\":80,\"from_side\":1,\"linkquality\":111,\"side\":0,\"to_side\":0,\"voltage\":2965}'"}
42.743 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":1,"action_side":0,"action_to_side":0,"angle":-4.72,"battery":80,"from_side":1,"linkquality":111,"side":0,"to_side":0,"voltage":2965}
42.789 Debug: SQLH UpdateValueInt aquara_cube1_signal HwID:3 DevID:0x00158d00051e1723_signal Type:243 sType:31 nValue:111 sValue:111
42.791 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:0 sValue:0
42.810 Status: dzVents: Info: ------ Finished cube1
42.810 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_signal (z2m)", Index: 24
42.810 Status: dzVents: Info: Handling events for: "aquara_cube1_signal", value: "111"
42.829 Status: dzVents: Info: ------ Finished cube1
42.829 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
42.829 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "0"
42.829 Status: dzVents: Info: side 0
0,031
55.626 zigbee2mqtt/bridge/logging {"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/aquara_cube1', payload '{\"action\":\"flip90\",\"action_from_side\":0,\"action_side\":1,\"action_to_side\":1,\"angle\":-4.72,\"battery\":80,\"from_side\":0,\"linkquality\":111,\"side\":1,\"to_side\":1,\"voltage\":2965}'"}
55.628 zigbee2mqtt/aquara_cube1 {"action":"flip90","action_from_side":0,"action_side":1,"action_to_side":1,"angle":-4.72,"battery":80,"from_side":0,"linkquality":111,"side":1,"to_side":1,"voltage":2965}
55.659 Debug: SQLH UpdateValueInt aquara_cube1_side HwID:3 DevID:0x00158d00051e1723_side Type:243 sType:31 nValue:1 sValue:1
55.678 Status: dzVents: Info: ------ Start internal script: cube1: Device: "aquara_cube1_side (z2m)", Index: 29
55.678 Status: dzVents: Info: Handling events for: "aquara_cube1_side", value: "1"
55.679 Status: dzVents: Info: ------ Finished cube1
55.679 Status: dzVents: Info: side 1
