Problem with 'UpdateDevice'
Posted: Friday 12 February 2021 13:03
I am trying to update the status of a switch when the associated device (lamp) has been switched over by another actuator.
This is my script:
The first part of the code works fine on its own, but adding the 'update' code introduces an infinite loop of firing commands, leaving switch and device deaf to any user intervention.
What am I doing wrong?
This is my script:
-- control Lantern with LanternSwitch
if devicechanged['LanternSwitch'] == 'On' then commandArray['Lantern'] = 'On'
elseif devicechanged['LanternSwitch'] == 'Off' then commandArray['Lantern'] = 'Off'
-- update LanternSwitch status if Lantern has been switched over
if devicechanged['Lantern'] == 'On' then commandArray['UpdateDevice'] = tostring(otherdevices_idx['LanternSwitch']) .. '|1|On'
elseif devicechanged['Lantern'] == 'Off' then commandArray['UpdateDevice'] = tostring(otherdevices_idx['LanternSwitch']) .. '|0|Off'
