Power failure: how to make sure that RPi is nicely shutdown
Posted: Friday 12 February 2021 11:36
Hello to all,
I'd like to report a solution I setup for 3 RPI running Domoticz. The idea is to hook up an inexpensive solution as an alternative to a UPS when this is not really needed. What does this HAT: when a main power failure condition arises, after 10 seconds it triggers a shutdown. When the power resumes (including during shutdown sequence), it will send a hardware signal to wake up RPi. We all know that having to proper shutdown sequence avoid the high probability to corrupt the SD card. I have a forth Domotiz running on a NUC Intel gear, that is acting as the master. This one is connected to a large UPS. However, I cannot guarantee there will be enough juice time before main power supply resumes. I'm currently setting up a 4th Domoticz whose sole role will be to manage power down sequence of all equipment connected to UPS's.
So far I bought 5 unit to Thomas Giegling http://safe-power.appspot.com/. Thomas is a very nice fellow, very prompt to answer questions.
