No temperature visible at Qubino ZMNHND1 Flush 1D relay+
Posted: Thursday 11 February 2021 23:48
I had a Qubino ZMNHND1 Flush 1D relay+ I want it to use for a heater in the garage. That was no problem. I can switch it on and off. Now I added a original temperature sensor to use is for temperature control.
I can't see no temperature at the hardware tab. I did exclude the node and include it again with a connected temperature sensor. There is no temperature visible in the hardware tab.
I see,
649 Controller 0005532C 1 Heat Light/Switch Switch Off - - 2021-02-10 22:00:32
648 Controller 00055300 1 Sensor Light/Switch Switch Off - - 2021-02-10 22:00:32
647 Controller 00055301 1 Switch Light/Switch Switch Off - - 2021-02-10 22:00:32
I bought the sensor at robbshop and send them a mail why it does not work. The tell they don't support open source projects and that I have to search at forums.
Is here someone who can and will help me ?
Greetings,
Peter
I see,
Greetings,
Peter
