Hello, with is the correct Dial block configuration for a Netatmo Thermostat?
It has temperature, setpoint but also Away and Status switches....
Ty
Netatmo thermostat Topic is solved
Lokonli
Re: Netatmo thermostat
Can you post the Domoticz json output of the device?
http://domoticz-ip:port/json.htm?type=devices&rid=123
Replace 123 with your Domoticz device id.
Sure.
This is the thermostat device:
This is the SetPoint device:
This is the Away Switch device:
"ActTime" : 1612961208,
"AstrTwilightEnd" : "19:19",
"AstrTwilightStart" : "05:48",
"CivTwilightEnd" : "18:10",
"CivTwilightStart" : "06:57",
"DayLength" : "10:11",
"NautTwilightEnd" : "18:44",
"NautTwilightStart" : "06:22",
"ServerTime" : "2021-02-10 13:46:48",
"SunAtSouth" : "12:33",
"Sunrise" : "07:28",
"Sunset" : "17:39",
"app_version" : "2020.2 (build 12917)",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "20.2 C",
"Description" : "",
"Favorite" : 0,
"HardwareDisabled" : false,
"HardwareID" : 6,
"HardwareName" : "Termostato",
"HardwareType" : "Netatmo",
"HardwareTypeVal" : 54,
"HaveTimeout" : true,
"ID" : "0A95",
"LastUpdate" : "2021-02-10 11:11:35",
"Name" : "Temperatura Sala",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" :
0
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "LaCrosse TX3",
"Temp" : 20.199999999999999,
"Timers" : "false",
"Type" : "Temp",
"TypeImg" : "temperature",
"Unit" : 149,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "236",
"trend" : 1
"status" : "OK",
"title" : "Devices"
}Code: Select all
"ActTime" : 1612961265,
"ServerTime" : "2021-02-10 13:47:45",
"Sunset" : "17:39",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "20.5",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 6,
"ID" : "03E0A95",
"Name" : "SetPoint Riscaldamento",
"PlanID" : "0",
"PlanIDs" :
0
"SetPoint" : "20.5",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Thermostat",
"TypeImg" : "override_mini",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "237"
"status" : "OK",
"title" : "Devices"
}Code: Select all
"ActTime" : 1612961305,
"ServerTime" : "2021-02-10 13:48:25",
"Sunset" : "17:39",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 0,
"HardwareID" : 6,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "13E0A95",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2021-02-09 22:01:16",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "Away Riscaldamento",
"PlanID" : "0",
"PlanIDs" :
0
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "398"
"status" : "OK",
"title" : "Devices"
Lokonli
There is no specific Netatmo block in Dashticz.
You can combine the temperature and setpoint in one dial. You can use the same method as for a Toon thermostaat (for temp/thermostaat):
https://dashticz.readthedocs.io/en/beta ... thermostat
Your 'away' switch is a 'normal' switch. That means you can use a normal switch block or an on/off-dial:
https://dashticz.readthedocs.io/en/beta ... off-switch
As you can see the Toon thermostaat uses a selector-switch to set the state. You could create a selector-switch in Domoticz as well, and then with some scripting connect it to your Netatmo switches.
