Download page broken (Error 404) Can't install Domoticz
Posted: Wednesday 03 February 2021 21:23
by gielie
Hi, im trying to reinstall a new Domoticz with curl -L
https://install.domoticz.com | bash but I. get this error.
::: Destination folder=/home/pi/domoticz
--2021-02-03 21:11:41-- http://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... 104.21.10.127, 172.67.190.40, 2606:4700:3031::6815:a7f, ...
Connecting to www.domoticz.com (www.domoticz.com)|104.21.10.127|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l [following]
--2021-02-03 21:11:41-- https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Connecting to www.domoticz.com (www.domoticz.com)|104.21.10.127|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://releases.domoticz.com/releases/release/domoticz_linux_armv7l.tgz [following]
--2021-02-03 21:11:42-- https://releases.domoticz.com/releases/release/domoticz_linux_armv7l.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 146.185.159.228, 2a03:b0c0:0:1010::480:1001
Connecting to releases.domoticz.com (releases.domoticz.com)|146.185.159.228|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2021-02-03 21:11:42 ERROR 404: Not Found.
Im not able to download Domoticz from the main site, I get an 404 error.
Is there something wrong with the easy install method?
Re: Download page broken (Error 404) Can't install Domoticz
Posted: Wednesday 03 February 2021 21:35
by robson
I am experiencing the same error at the moment.
Posted: Wednesday 03 February 2021 21:42
by mrbrown38
Someone delete the file on accident
? Having the same issue.
Posted: Wednesday 03 February 2021 22:46
by Rub87
I run domoticz for years but thought lets make a frsh install on buster. got a spare SD card, installed latest distro, so far so good. when trying to install domoticz the easy way I get:
pi@Domoticz:~ $ curl -L install.domoticz.com | sudo bash % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 178 100 178 0 0 1893 0 --:--:-- --:--:-- --:--:-- 1893
100 16569 100 16569 0 0 80432 0 --:--:-- --:--:-- --:--:-- 80432
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 8080
--2021-02-03 22:16:55-- http://www.domoticz.com/download.php?channel=release&ty pe=release&system=linux&machine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... 172.67.190.40, 104.21.10.127, 2 606:4700:3031::6815:a7f, ...
Connecting to www.domoticz.com (www.domoticz.com)|172.67.190.40|:80... connected .
Location: https://www.domoticz.com/download.php?channel=release&type=release&sys tem=linux&machine=armv7l [following]
--2021-02-03 22:16:56-- https://www.domoticz.com/download.php?channel=release&t ype=release&system=linux&machine=armv7l
Connecting to www.domoticz.com (www.domoticz.com)|172.67.190.40|:443... connecte d.
Location: https://releases.domoticz.com/releases/release/domoticz_linux_armv7l.t gz [following]
--2021-02-03 22:16:56-- https://releases.domoticz.com/releases/release/domoticz _linux_armv7l.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 146.185.159.228, 2a03 :b0c0:0:1010::480:1001
Connecting to releases.domoticz.com (releases.domoticz.com)|146.185.159.228|:443 ... connected.
2021-02-03 22:16:56 ERROR 404: Not Found.
I then tried the other way as explained on the domoticz faq compiling it form source, but then I get an error saying my cmake version is outdated. Which is strange as I just only installed it and updated it an theres no newer version found..
CMake 3.16.0 or higher is required. You are running version 3.13.4
Posted: Wednesday 03 February 2021 22:47
by lost1
Same issue over here..
Posted: Wednesday 03 February 2021 23:09
by dlkbay
same over here. also the link:
https://www.domoticz.com/downloads/ gives a 404
Posted: Wednesday 03 February 2021 23:12
by waaren
Rub87 wrote: Wednesday 03 February 2021 22:46
Looks like the domoticz download server currently does have a problem
From the wiki
To compile/install CMake issue the following commands:
Remove any previous CMake installation
sudo apt remove --purge --auto-remove cmake
Go to the official CMake site and download the latest source: http://www.cmake.org/download
The following will assume version 3.19.3 is the latest version
wget https://github.com/Kitware/CMake/releases/download/v3.19.3/cmake-3.19.3.tar.gz
tar -xzvf cmake-3.19.3.tar.gz
rm cmake-3.19.3.tar.gz
cd cmake-3.19.3
./bootstrap
make
sudo make install
cd ..
rm -Rf cmake-3.19.3
Verify you are on the correct version with
cmake --version
Results of cmake --version:
cmake version 3.16.xx
CMake suite maintained and supported by Kitware (kitware.com/cmake).
Posted: Wednesday 03 February 2021 23:13
by waaren
The domoticz download server does seem to have some problems.
Reported on github
issue 4613
Posted: Thursday 04 February 2021 9:55
by gizmocuz
The problem where some folder permissions on the server. All should be working again
Posted: Thursday 04 February 2021 10:06
by robson
Yep, it is working again!
Posted: Thursday 04 February 2021 10:42
by waaren
Please note that the command has changed some time ago and is now
curl -sSL install.domoticz.com | sudo bash
Posted: Monday 09 January 2023 10:20
by Vicheadmiral
пробовал и sudo bash -c "$(curl -sSfL
https://install.domoticz.com)" и curl -sSL install.domoticz.com | sudo bash
Результат один:HTTP request sent, awaiting response... 301 Moved Permanently
GnuTLS: Error in the pull function.
Unable to establish SSL connection
Если компилировать по туриллу с домотиз то порты так и не открывается
