Xiaomi sensor:attempt to index a nil value (field 'lastUpdate')
Posted: Wednesday 03 February 2021 13:27
by RezaRose
I made a script to turn the lights off after the lastUpdate more then xx
I have used this script succesfully with the Philips hue sensor, but is i use the Xioami sensor it gives a error on the last update:
timer = {'every 1 minutes'},
devices = {'Schuursensor'}
execute = function(dz, Sensor)
local Schuur = dz.devices('Schuur')
if Sensor.state == 'On' then
Schuur.switchOn().checkFirst()
print('Schuursensor is ' .. Sensor.state .. '. Schuur is aangezet omdat er beweging in de Schuur is. ')
elseif Sensor.lastUpdate.minutesAgo >= 5 and Schuur.state == 'On' then
Schuur.switchOff()
print('Schuurverlichting is uitgezet omdat er 5 minuten geen beweging in de Schuur is geweest')
print('Nothing changed. Schuursensor updated ' .. Sensor.lastUpdate.minutesAgo .. ' minutes ago')
When i look in Domoticz i can see the last update status was 31 minutes ago, so it is getting a value somewhere.
I tried to debug with Sensor.dump() but it gives a error with nil value on dump too. Why it is giving a nil value and can i do something about it?
Re: Xiaomi sensor:attempt to index a nil value (field 'lastUpdate')
Posted: Wednesday 03 February 2021 13:35
by jmleglise
=> devices = {'Schuursensor'}
=> local Schuur = dz.devices('Schuur')
is it the same device ? So what is the right name ?
Posted: Wednesday 03 February 2021 13:54
by waaren
RezaRose wrote: Wednesday 03 February 2021 13:27
Your script can be triggered by the timer or by the device but your code only take the device triggered version into account.
You should do something like below. (check the script logic around
if item.isDevice)
return
on =
timer =
'every minute',
devices =
'Schuursensor',
logging =
level = domoticz.LOG_DEBUG,
marker = 'schuur logic',
execute = function(dz, item)
local sensor = dz.devices('Schuursensor')
if item.isDevice then
if sensor.state == 'On' then
dz.log('Schuursensor is ' .. sensor.state .. '. Schuur is aangezet omdat er beweging in de Schuur is. ', dz.LOG_DEBUG)
dz.log('Schuursensor switched to ' .. sensor.state , dz.LOG_DEBUG)
elseif sensor.lastUpdate.minutesAgo >= 5 and Schuur.state == 'On' then
Schuur.switchOff()
dz.log('Schuurverlichting is uitgezet omdat er 5 minuten geen beweging in de Schuur is geweest', dz.LOG_DEBUG)
dz.log('Nothing changed. Schuursensor updated ' .. sensor.lastUpdate.minutesAgo .. ' minutes ago', dz.LOG_DEBUG)
Posted: Wednesday 03 February 2021 14:09
by RezaRose
waaren wrote: Wednesday 03 February 2021 13:54
if item.isDevice)
return
on =
timer =
'every minute',
devices =
'Schuursensor',
logging =
Schuur.switchOff()
Thanks I understand what it does, I put it in the script! But is does not fix the error
if Sensor.isDevice then
print('Schuursensor is ' .. Sensor.state .. '.. Schuur is aangezet omdat er beweging in de Schuur is. ')
Schuur.switchOff()
2021-02-03 14:07:00.330 Error: dzVents: Error: (3.1.4) An error occurred when calling event handler Schuursensor
2021-02-03 14:07:00.330 Error: dzVents: Error: (3.1.4) ...oticz/scripts/dzVents/generated_scripts/Schuursensor.lua:22: attempt to index a nil value (field 'lastUpdate')
Posted: Wednesday 03 February 2021 14:10
by RezaRose
jmleglise wrote: Wednesday 03 February 2021 13:35
Device 'Schuursensor' is renamed to sensor and it is the motiondetector.
Device Schuur is the lightbulb switch
Posted: Wednesday 03 February 2021 14:13
by waaren
RezaRose wrote: Wednesday 03 February 2021 14:09
You are not using the script I posted and merged it partially (and wrong) in yours. Please try the script I posted first in an unmodified form and when you see it works amend where needed.
Posted: Wednesday 03 February 2021 14:22
by RezaRose
I'm sorry, i thought did understand
2021-02-03 14:21:00.604 Status: dzVents: Info: schuur logic: ------ Start internal script: Script #2:, trigger: "every minute"
2021-02-03 14:21:00.629 Status: dzVents: Debug: schuur logic: Processing device-adapter for Schuur: RGB(W) device adapter
2021-02-03 14:21:00.630 Status: dzVents: Debug: schuur logic: Processing device-adapter for Schuur: Switch device adapter
2021-02-03 14:21:00.631 Status: dzVents: Debug: schuur logic: Processing device-adapter for Schuursensor: Switch device adapter
2021-02-03 14:21:00.631 Status: dzVents: Debug: schuur logic: Nothing changed. Schuursensor updated 3 minutes ago
2021-02-03 14:21:00.631 Status: dzVents: Info: schuur logic: ------ Finished Script #2
It worked! I will take a minute to figure out what is the difference.
Posted: Wednesday 03 February 2021 14:32
by waaren
RezaRose wrote: Wednesday 03 February 2021 14:22
No problem. The thing most people starting with dzVents find hard to get there minds to, are the first two parameters of the execute function.
The execute function is the "motor" of the script and to do something useful it needs at least one and most of the time two parameters.
A detailed description on how that works can be found
in this chapter of the dzVents wiki
some special attention for the line:
Since you can define multiple on-triggers in your script, it is not always clear what the type is of this second parameter. In your code you need to know this in order to properly respond to the different events. To help you inspect the object you can use these attributes like if (item.isDevice) then ... end:
Posted: Wednesday 03 February 2021 14:50
by RezaRose
Thanks! I merged it right now! ( i will look into the difference between dz.log and print later)
I thought i found in the video somewhere i could rename the function. But i did not used it properly because i have two triggers. I will stay with the variables untill i understand it better. Thank you for the help!
local Sensor = dz.devices('Schuursensor')
Schuur.switchOff()
