how to call a dzvents script from within another? [Solved]
lastofthejediknights
- Domoticz version: 2021.1
The issue I wish to solve is this.
A switch that represents my shower pump state.
A dimmer that is the power level of a heated towel rail.
I wish to turn the towel rail on, but only after the pump has been running for say 3 mins.
I could do this within a script that runs frequently, storing the time of status change from low to high, with a persistent variable, then turning the towel rail on when the condition is met.
This seems a bit wasteful of resources to me, and would not trigger as soon as the state changes.
So could I have a script trigger on the device, and have it call another script on a Delay of 3 mins say, and check within this second script that the pump is still active, and turn on the towel rail.
Suggestions or other ideas gratefully entertained.
- Domoticz version: 2026.3
Re: how to call a dzvents script from within another?
You can use a scene for this: switch on shower pump and after 3 minutes switch on towel rail.
Or you can make a dzvents script that switches on the shower pump and use the .afterMin(3) extension on the towel rail device to switch it 3 minutes later. No extra script needed
- waaren
Do you only want to check if the pump was started 3 minutes ago? Then a simple afterMin(3) would do it.lastofthejediknights wrote: Tuesday 02 February 2021 22:52 I wish to turn the towel rail on, but only after the pump has been running for say 3 mins.
or do you want to ensure the pump has been running for at least 3 minutes since it started (taking paused periods into account)? In that case you would need extra triggers ( on = { devices = { 'pump'}, customEvents = {'pumpExecution '} } and some timekeeping for which you could use dzVents persistent historical API
Hi, yes I only want to turn on the towel rail AFTER the pump has been running for 3 mins continuously,.
Not just a 3 min delay, as could be solved by the scenes method.
Wouldn't the historical or persistent date still require including it into a frequently timed event?
I suppose I could use the device trigger and look at the time elapsed between the on and off, but this would be the time taken to say fill the bath in its entirety, rather than say the first 3 mins. Practically not much difference.
I could use a dummy switch, activated by the pump script on a
switchOn().afterMin(3) basis, and check the state of the pump at that point, switching the rail as appropriate.
- waaren
Not if you calculate the minimal remaining time to get to the three minutes and use domoticz.emitEvent() to trigger the script based on the named customEvent .lastofthejediknights wrote: Wednesday 03 February 2021 1:00 Wouldn't the historical or persistent date still require including it into a frequently timed event?
so initially right after starting the pump you would do something like emitEvent('lookAtPump' ).afterSec(180) and when this script checks the pump active time and determine is was active for only 110 seconds during these 3 minutes, it would send another emitEvent('lookAtPump' ).afterSec(180 - 110) and repeat these steps until the pumps total active time becomes >= 180
Ok, Many thanks for the help. As a first pass solution, simply looking at the status after some elapsed time, rather than tracking the actual time the device is actually switched on, I have the following two scripts.
1___ Called by the ShowerPump input
and 2____ the Custom Event script - CheckPumpRun'
This is tested and working fine.
Again, any suggestions or improvements gratefully received.
devices = {
'Shower Pump'
emitEvent('CheckPumpRun').afterSec(120)
domoticz.log('Device ' .. device.name .. ' called PumpRun Script', domoticz.LOG_INFO)
customEvents = {
'CheckPumpRun' -- event triggered by emitEvent
data = {},
logging = {},
execute = function(domoticz, triggeredItem)
if (triggeredItem.isCustomEvent) then
if((domoticz.devices('Shower Pump').state == 'On') ) then -- if pump running after time
domoticz.devices('TowelRail Boost').switchOn()-- turn on the towelrail for a bit
domoticz.log(' Pump running, turned on Towelrail ' , domoticz.LOG_INFO)
domoticz.log(' Pump NOT running, do nothing ' , domoticz.LOG_INFO)
--domoticz.utils._.print(triggeredItem.data)
-- second parameter can be anything, number, string, boolean or table
--domoticz.emitEvent('MyEvent', 'Some data')
- waaren
Great !lastofthejediknights wrote: Wednesday 03 February 2021 11:41 This is tested and working fine.
you could consider to merge the two scripts together.
local scriptVar = 'CheckPumpRun'
return
on =
devices =
'Shower Pump',
customEvents =
scriptVar,
logging =
level = domoticz.LOG_DEBUG,
marker = scriptVar,
execute = function(dz, item)
if item.isDevice and item.active then
dz.emitEvent(scriptVar).afterSec(120)
dz.log('Device ' .. item.name .. ' called customEvent ' .. scriptVar, dz.LOG_INFO)
elseif item.isCustomEvent then
if dz.devices('Shower Pump').active then
dz.devices('TowelRail Boost').switchOn()-- turn on the towelrail for a bit
dz.log(' Pump running, turned on Towelrail ' , dz.LOG_DEBUG)
dz.log(' Pump NOT running, do nothing ' , dz.LOG_DEBUG)
dz.log(' Pump NOT active, do nothing ' , dz.LOG_DEBUG)
Re: how to call a dzvents script from within another? [Solved]
Many thanks for the education.
I had to change the line
to
to get it to run, Odd that the omission of "domoticz" in the otherwise identical line in my two seperate script solution ran ok.
In any event, thank you for the help.
P.S. I don't see how to mark this as "Solved" but it is!
regards
Nigel
emitEvent(scriptVar).afterSec(120)Code: Select all
dz.emitEvent(scriptVar).afterSec(120)In any event, thank you for the help.
regards
Nigel
