Behavior of last seen from philips hue motion
Posted: Tuesday 02 February 2021 10:29
by RezaRose
Can somebody explain what is happening?
I have a Philips hue outdoor motion sensor connected to my Zigate. I wanted to write a script with dzvents that turns the lights off after 5 min no motion. But if i use devices.lastupdate the devices.lastupdate resets after 4 minutes, even when there is no motion. Sometimes the device announces himself again after 4 min. I watched the log from last night, and a couple times the counter got to 5 of 9 min. But most of the time it only get till 4 min.
The cooldown for the motion sensor is 5 min. So if i write a script with lights off after 4 and we stay outside longer then that the lights go out for a minute, before motion is detected again.
Mayby i can get creative with a variable, but i like to know why it is behaving like this.
Daytime:
Daytime:
- Spoiler: show
- 2021-02-02 09:42:00.164 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:42:00.183 Status: dzVents: Buitensensor updated 3 minutes ago
2021-02-02 09:42:00.183 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:42:00.183 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:42:01.532 Status: Python Plugin System: (Zigate USB TLL) Device Annoucement: Buitensensor NwkId: 2940 Ieee: 001788010648e908 MacCap: 80
2021-02-02 09:43:00.167 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:43:00.186 Status: dzVents: Buitensensor updated 4 minutes ago
2021-02-02 09:43:00.186 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:43:00.186 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:44:00.231 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:44:00.250 Status: dzVents: Buitensensor updated 0 minutes ago
2021-02-02 09:44:00.250 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:44:00.251 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:45:00.226 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:45:00.246 Status: dzVents: Buitensensor updated 1 minutes ago
2021-02-02 09:45:00.246 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:45:00.246 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:46:00.262 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:46:00.280 Status: dzVents: Buitensensor updated 2 minutes ago
2021-02-02 09:46:00.280 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:46:00.280 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:46:35.144 Status: Python Plugin System: (Google Nest) Updated 5 units for 1 device(s)
2021-02-02 09:47:00.214 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:47:00.233 Status: dzVents: Buitensensor updated 3 minutes ago
2021-02-02 09:47:00.233 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:47:00.233 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:48:00.283 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:48:00.301 Status: dzVents: Buitensensor updated 4 minutes ago
2021-02-02 09:48:00.301 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:48:00.301 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:49:00.295 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:49:00.317 Status: dzVents: Buitensensor updated 0 minutes ago
2021-02-02 09:49:00.317 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:49:00.317 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:50:00.296 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:50:00.315 Status: dzVents: Buitensensor updated 1 minutes ago
2021-02-02 09:50:00.315 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:50:00.315 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:51:00.281 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:51:00.299 Status: dzVents: Buitensensor updated 2 minutes ago
2021-02-02 09:51:00.299 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:51:00.299 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:51:35.286 Status: Python Plugin System: (Google Nest) Updated 5 units for 1 device(s)
2021-02-02 09:52:00.332 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:52:00.350 Status: dzVents: Buitensensor updated 3 minutes ago
2021-02-02 09:52:00.350 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:52:00.351 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:53:00.360 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:53:00.387 Status: dzVents: Buitensensor updated 4 minutes ago
2021-02-02 09:53:00.387 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:53:00.387 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:54:00.349 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:54:00.370 Status: dzVents: Buitensensor updated 0 minutes ago
2021-02-02 09:54:00.370 Status: dzVents: Tuinverlichting state is Off
2021-02-02 09:54:00.370 Status: dzVents: Info: ------ Finished Buiten verlichting uit bij geen beweging
2021-02-02 09:55:00.321 Status: dzVents: Info: ------ Start internal script: Buiten verlichting uit bij geen beweging:, trigger: "every 1 minutes"
2021-02-02 09:55:00.339 Status: dzVents: Buitensensor updated 1 minutes ago
2021-02-02 09:55:00.339 Status: dzVents: Tuinverlichting state is Off
