Domoticz stopped and does not start anymore
Posted: Sunday 31 January 2021 1:23
by Ptje
My Domoticz installation has stopped and does not start anymore. I can't find what the problem is. I attached my Domoticz crashlog. Does someone can help my to see what the problem could by ? I hope I don't have to do a full new installation and configuration.......
Greetings,
Peter
Re: Domoticz stopped and does not start anymore
Posted: Sunday 31 January 2021 9:33
by Ptje
When I start Domoticz I see the following,
2021-01-31 09:30:48.122 Status: Domoticz V2020.2 (build 12896) (c)2012-2021 GizMoCuz
2021-01-31 09:30:48.122 Status: Build Hash: d5c2e6a46-modified, Date: 2021-01-30 10:52:18
2021-01-31 09:30:48.122 Status: Startup Path: /home/pi/domoticz/
2021-01-31 09:30:48.169 Sunrise: 08:17:00 SunSet: 17:25:00
2021-01-31 09:30:48.169 Day length: 09:07:00 Sun at south: 12:51:00
2021-01-31 09:30:48.169 Civil twilight start: 07:41:00 Civil twilight end: 18:01:00
2021-01-31 09:30:48.169 Nautical twilight start: 07:01:00 Nautical twilight end: 18:41:00
2021-01-31 09:30:48.170 Astronomical twilight start: 06:21:00 Astronomical twilight end: 19:21:00
2021-01-31 09:30:48.242 Status: PluginSystem: Started, Python version '3.7.3'.
2021-01-31 09:30:48.247 Active notification Subsystems: email, fcm (2/13)
2021-01-31 09:30:48.251 Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8080: bind: Address already in use
2021-01-31 09:30:48.251 Error: WebServer(HTTP) check if no other application is using port: 8080
2021-01-31 09:30:48.263 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2021-01-31 09:30:48.263 Error: WebServer(SSL) check privileges for opening ports below 1024
2021-01-31 09:30:48.264 Error: No servers are configured. Hence mydomoticz will not be started either (if configured)
terminate called without an active exception
2021-01-31 09:30:48.264 Error: Domoticz(pid:2461, tid:2461('domoticz')) received fatal signal 6 (Aborted)
2021-01-31 09:30:48.264 Error: siginfo address=0x99d, address=0xffffffff
2021-01-31 09:30:52.027 Error: Thread 1 (Thread 0x76018010 (LWP 2461)):
2021-01-31 09:30:52.027 Error: #0 __waitpid (options=0, stat_loc=0x7edef920, pid=2466) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2021-01-31 09:30:52.027 Error: #1 __waitpid (pid=2466, stat_loc=0x7edef920, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2021-01-31 09:30:52.027 Error: #2 0x002cd4cc in dumpstack_gdb(bool) ()
2021-01-31 09:30:52.027 Error: #3 0x002cda98 in signal_handler(int, siginfo_t*, void*) ()
2021-01-31 09:30:52.027 Error: #4 <signal handler called>
2021-01-31 09:30:52.027 Error: #5 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2021-01-31 09:30:52.027 Error: #6 0x769b8230 in __GI_abort () at abort.c:79
2021-01-31 09:30:52.027 Error: #7 0x009cc084 in __gnu_cxx::__verbose_terminate_handler() ()
2021-01-31 09:30:52.028 Error: #8 0x0092f43c in __cxxabiv1::__terminate(void (*)()) ()
2021-01-31 09:30:52.028 Error: #9 0x0092f4b0 in std::terminate() ()
2021-01-31 09:30:52.028 Error: #10 0x001f17e4 in main ()
Aborted
But I don't see what is running on port 8080 or 443
Greetings,
Peter
Posted: Sunday 31 January 2021 11:26
by waaren
Ptje wrote: Sunday 31 January 2021 9:33
...but I don't see what is running on port 8080 or 443
sudo netstat -tulpn | grep '8080\|433'
Will show you what is on these ports.
Most of the time a
before a
does work
Posted: Sunday 31 January 2021 13:52
by erem
sometimes rasbian gets confused.
i believe a reboot of your pi will clear up the process that occupies port 8080
Posted: Sunday 31 January 2021 14:50
by Ptje
waaren wrote: Sunday 31 January 2021 11:26
pi@raspberrypi:~ $ sudo netstat -tulpn | grep '8080\|433'
tcp6 0 0 :::8080 :::* LISTEN 551/domoticz
I see this at my fathers Domoticz.
tcp 0 0 127.0.0.1:8080 0.0.0.0:* LISTEN 430/motion
I see this at my Domoticz.
I don`t know of this is normal.
Greetings,
Peter
Posted: Sunday 31 January 2021 16:17
by AllesVanZelf
Well, it looks like you have motion running on 8080.
Motion is surveillance software. Motion detection.
You could change the port Domoticz is using in /etc/init.d/domoticz.sh
fir example:
DAEMON_ARGS="$DAEMON_ARGS -www 8090"
Posted: Sunday 31 January 2021 16:33
by Ptje
Maybe I see ghosts, but I did watch yesterday a not official stream of Rico Verhoeven. During the match, I received a message from Monit, that Domoticz was stopped. It is not possible that something is installed with a script on my raspberry ?
I don't use motion software. And I did not change anything on my Raspberry myself..........
Greetings.
Posted: Sunday 31 January 2021 17:21
by AllesVanZelf
In that case: check if motion is installed indead:
sudo apt list --installed |grep motion
Do you have a camera attached to your raspberry?
Posted: Sunday 31 January 2021 17:49
by Ptje
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
motion/stable,now 4.1.1-1.1+b2 armhf [installed]
So it is installed. I have no camera attached to the raspberry Pi
Greetings,
Peter
Posted: Sunday 31 January 2021 18:00
by AllesVanZelf
Then I would have removed motion. But have a close look on dependencies before saying yes to removal.
If you can remove motion without dependency problems, you should find out why motion is installed in the first place.
But without motion, Domoticz should be able to start.
Posted: Thursday 04 February 2021 21:31
by Ptje
After the removal from "Motion" The port 8080 error was gone. I even had to place a old database back to get it running. I think that I killed soms stuff while trying to make Domoticz work. Thanks for the help !!
Greetings,
Peter
Posted: Monday 10 April 2023 13:10
by monette999
Hi I have a similar issue.see attachment.
Are you still online and can help?
Gesendet von meinem CPH2343 mit Tapatalk
