Yamaha Radio CRX N560D control script
Posted: Friday 29 January 2021 21:05
by marcovz
I have made a script to control my Yamaha CRX N560D radio which might be useful for others. This radio does not feature the Musiccast protocol but can be controlled over ethernet by http post. For FHEM a Perl module is available with all the commands and status requests. https://github.com/mhop/fhem-mirror/blo ... MAHA_NP.pm. Other models that might work are NP-S2000, CD-N500, CD-N301, R-N500, R-N301. The radio can be controlled by Yahama Network Controller app for IOS and Android.
I only used the commands for the functions I want to control in Domoticz. Power On/Off, select inputs Dig1 and Tuner/DAB, Volume control and select DAB presets. For the basic commands I use a selector switch (idx 678) and another selector switch for the DAB presets (idx 693). The status of the radio is requested every minute by a timer. Power, Volume, Input and preset info are stored in user variables and send to a text sensor (idx 685). The name of levels in the selector switch (678) need to match the name in the script. For the preset selector the first 2 characters are used for the preset number, character 5 and further for the station name and can be set according your preset list. Furthermore I set different volume levels when switching inputs to match the source.
Create variables for:
inputname = domoticz.variables(1).value
volume = domoticz.variables(2).value
presetname = domoticz.variables(4).value
preset = domoticz.variables(6).value
presetinfo = domoticz.variables(7).value
power = domoticz.variables(8).value
and change the variables numbers in the script accordingly. Create 2 (dummy) selector switches
Switch to control with following levels:
- Off
- TV
- DAB
- Mute
- Vol-
- Vol+
Switch for DAB preset levelnames starting with preset number:
- 01
- 02
- 03
and so on. The rest of the levelname can be used for station name is and is discarded in the script.
Create a text sensor which is used as display and change the idx (685 in the code) to your idx numer.
Create a new script in DZvents with following code and change your idx numbers and ip adres of your Yamaha:
		devices = {
			678, 693
		timer = { 'every minute' },
        httpResponses = { 'statusresponse', 'statusplayinfo' }
	logging = {
    level = domoticz.LOG_DEBUG,
    marker = "yamaha_script"
	        yamahaip = '192.168.20.20/YamahaRemoteControl/ctrl'
	        head = {['Content-Type'] = 'application/xml; charset=UTF-8'}
	        xml_get_status = [[<YAMAHA_AV cmd="GET"><System><Basic_Status>GetParam</Basic_Status></System></YAMAHA_AV>]]
	        xml_get_playinfo = [[<YAMAHA_AV cmd="GET"><Tuner><Play_Info>GetParam</Play_Info></Tuner></YAMAHA_AV>]]
	        if device.idx == 678 then
	            xml_put_power_on = [[<YAMAHA_AV cmd="PUT"><System><Power_Control><Power>On</Power></Power_Control></System></YAMAHA_AV>]]
	            xml_put_power_standby = [[<YAMAHA_AV cmd="PUT"><System><Power_Control><Power>Standby</Power></Power_Control></System></YAMAHA_AV>]]
	            xml_put_vol_up = [[<YAMAHA_AV cmd="PUT"><System><Volume><Lvl>Up</Lvl></Volume></System></YAMAHA_AV>]]
	            xml_put_vol_down = [[<YAMAHA_AV cmd="PUT"><System><Volume><Lvl>Down</Lvl></Volume></System></YAMAHA_AV>]]
	            xml_put_vol_mute = [[<YAMAHA_AV cmd="PUT"><System><Volume><Mute>On</Mute></Volume></System></YAMAHA_AV>]]
	            xml_put_vol_level_12 = [[<YAMAHA_AV cmd="PUT"><System><Volume><Lvl>12</Lvl></Volume></System></YAMAHA_AV>]]
                xml_put_vol_level_25 = [[<YAMAHA_AV cmd="PUT"><System><Volume><Lvl>25</Lvl></Volume></System></YAMAHA_AV>]]
                xml_put_input_dig1 = [[<YAMAHA_AV cmd="PUT"><System><Input><Input_Sel>DIGITAL1</Input_Sel></Input></System></YAMAHA_AV>]]
                xml_put_input_tuner = [[<YAMAHA_AV cmd="PUT"><System><Input><Input_Sel>TUNER</Input_Sel></Input></System></YAMAHA_AV>]]
                xml_put_band_dab = [[<YAMAHA_AV cmd="PUT"><Tuner><Play_Control><Band>DAB</Band></Play_Control></Tuner></YAMAHA_AV>]]
                if device.levelName == 'Vol +' and power == 'On' then
	                domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_vol_up})
	                volume = volume+1
	            if device.levelName == 'Vol -' and power == 'On' then
	                domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_vol_down})
	                volume = volume-1
	            if device.levelName == 'Mute' and power == 'On' then
	                domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_vol_mute})
	           if device.levelName == 'Off' then
	                domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_vol_level_12})
	                domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_power_standby})
	                volume = 12
	                power = 'Standby'
	           if device.levelName == 'TV' then
	               if power == 'On' then
	                    domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_input_dig1})
	               if power == 'Standby' then
	                   domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_power_on})
	                   domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_input_dig1}).afterSec(1)
	                   power = 'On'
	               domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_vol_level_25}).afterSec(1)
	               inputname = 'Digital 1 - TV'
	               volume = 25
	           if device.levelName == 'DAB' then
	                    domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_input_tuner})
	                   domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_input_tuner}).afterSec(1)
	                   domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_vol_level_12}).afterSec(1)
	                   power = 'On'
	               domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_band_dab})
	               domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_get_playinfo, callback = 'statusplayinfo'}).afterSec(10)
    	           volume = 12
    	           inputname = 'DAB'
            if device.idx == 693 then
                PresetPre = [[<YAMAHA_AV cmd="PUT"><Tuner><Play_Control><Preset><DAB><Preset_Sel>]]
                PresetSuf = [[</Preset_Sel></DAB></Preset></Play_Control></Tuner></YAMAHA_AV>]]
                preset = string.sub(device.levelName,1,2)
                presetname = string.sub(device.levelName,5)
                presetinfo = ' '
                xml_put_tuner_preset = PresetPre .. preset .. PresetSuf
	            domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_put_tuner_preset})
	            domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_get_playinfo, callback = 'statusplayinfo'}).afterSec(3)
	        if (device.isTimer) then
	                domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_get_status, callback = 'statusresponse'}).afterSec(1)
				    domoticz.openURL({url = yamahaip, method = 'POST', headers =  head, postData = xml_get_playinfo, callback = 'statusplayinfo'}).afterSec(8)
	        if (device.isHTTPResponse) then
                responsestatus = string.match(tostring(device.data), "<System><(%a+)_" )
                responseplayinfo = string.match(tostring(device.data), "<Tuner><(%a+)_" )
                if responsestatus == 'Basic' then
                    yamahastatus = tostring(device.data)
                    power = string.match(yamahastatus, "<Power>(%a+)</Power><" )
                    inputname = string.match(yamahastatus, "<Input><Input_Sel>(.*)</Input_Sel>" )
                    volume = string.match (yamahastatus, "<Lvl>(%d+)</Lvl>" )
                    mute = string.match(yamahastatus, "<Mute>(%a+)</Mute><" )
                    if inputname == 'TUNER' then
                        inputname = 'DAB'
                    if inputname == 'DIGITAL1' then
                if responseplayinfo == 'Play' then
                    yamahaplayinfo = tostring(device.data)
                    preset = string.match(yamahaplayinfo, "<DAB><Preset><Preset_Sel>(%d+)</Preset_Sel>" )
                    presetselector = string.sub(domoticz.devices(693).levelName,1,2)
                --    domoticz.log('preset is ' .. tonumber(preset) .. ' presetselector is ' .. tonumber(presetselector) , domoticz.LOG_INFO)
                    if tonumber(preset) ~= tonumber(presetselector) then
                        domoticz.devices(693).switchSelector(preset*10).silent()
                        presetname = string.match(yamahaplayinfo, "<Service_Label>(.*)</Service_Label>" )
                        presetinfo = string.match(yamahaplayinfo, "<DLS>(.*)</DLS>" )
                inputname = 'Standby'
	        domoticz.variables(1).set(inputname)
	        domoticz.variables(2).set(volume)
	        domoticz.variables(6).set(preset)
	        domoticz.variables(4).set(presetname)
	        domoticz.variables(7).set(presetinfo)
	        domoticz.variables(8).set(power)
	        input2 = inputname
	        if inputname == 'DAB' then
	            input2 = tostring(inputname .. ' ' .. preset .. ' ' .. presetname .. ' | ' .. presetinfo)
	        display = domoticz.utils.urlEncode('Vol ' ..  tostring(volume) .. ' | ' .. input2)
	        domoticz.devices(685).setValues('0', display)
Have fun!
